New Anvil radius the edges, how much
Just received my New Holland Anvil! I will need  to radius the edges. How much, the same full Length?
Thanks
Take a look at this:
And also this:
The radii depend on how YOU are going to use it; what methods YOU employ and what items YOU will be making.  Did I miss where YOU provided that info?
If it were mine, I wouldn't do it all in one go. I'd start with a somewhat small radius, use it for a while, and then make the decision on whether or not to make the radius larger. You can always take more off, but you can't put it back.
Leave the anvil as is and make a hardie tool that has the radius you are considering.  In fact make several, each with a different radius. In a year (2000 hours) you can tell by the wear on the hardie tools which radius you use most. THAT will be the radius to put on the anvil ONLY IF you do a lot of that type work and plan to continue to do that work in the future.
Just be sure you do not do anything that you want to undo later. It is your anvil and you may modify it s you wish.
I round mine from 3/8" to zero. 3/8" at the step, and I end the taper before the hardy hole,, somewhere around  where the heel begins.
My anvils have several radii all over. I know on the old one pretty much where what radius is, on the new one not so much yet. I don't think I could work with one uniform radius all over. It would look better though.
Mvg Bart
As I use old anvils I've never had to grind a radius on a sharp edge.  Now at times I have been known to switch from one anvil to another as I like the radius on it better for a particularly task...
I'm thinking of making a 4 radius hardy block just to show students how to get around an anvil's worn edges.  Picked up the 16# block at the fleamarket a couple of weekends ago for US$2 Now just wondering if I should go 90 deg, 1/8", 1/4", 3/8" or 1/8",1/4", 3/8", 1/2" radii
Or punch and drift a square hole in it and make a drop in hardy stem and make it so you can flip it over and have 8 different edges to use!  Its 4.75"x4.75"x2.5"
Hi Everyone
Thanks for your replies. I decided to just ease the corners a tiny bit. I can  take more off later, but putting more on might be harder! (lol)
Thanks for your thoughts
Larry
