dogblazer9598 Posted November 12, 2018 Share Posted November 12, 2018 can anyone give me the proper procedure to anneal a store bought hammer to use on my fuller tool? thank you doug Quote Link to comment Share on other sites More sharing options...
arkie Posted November 12, 2018 Share Posted November 12, 2018 I would not think you need to do anything to your hammer. I use several hammers from my stash, all of which have some degree of heat treating to preserve the hammer face. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 12, 2018 Share Posted November 12, 2018 Can you tell me how hard/brittle my hammer is and how hard my fuller is? What alloy my hammer is made from? Quote Link to comment Share on other sites More sharing options...
dogblazer9598 Posted November 12, 2018 Author Share Posted November 12, 2018 it is for my guillotine tool which the fuller bar is just 1018 and am trying to slow the strike point down from mushrooming . thanks doug Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 12, 2018 Share Posted November 12, 2018 Take the head off the handle, heat the head to above critical temperature, allow to cool veeeeeeeeeerrrrrrrryyyyy slowly in vermiculite, wood ashes, or powdered lime. Re-handle. Mark the handle SOFT. Quote Link to comment Share on other sites More sharing options...
dogblazer9598 Posted November 12, 2018 Author Share Posted November 12, 2018 appreciate the reply but I do have a dumb question .how do I find the critical temp ? pardon my ignorance but im very new to this . thank you doug Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted November 13, 2018 Share Posted November 13, 2018 what was not clear about that in the heat treating sticky post? you didnt specify Quote Link to comment Share on other sites More sharing options...
Latticino Posted November 13, 2018 Share Posted November 13, 2018 22 hours ago, dogblazer9598 said: how do I find the critical temp For more critical applications, like blademaking with thin crossections where you need to limit grain growth and are planning on hardening it is more difficult as you need to be very accurate. For making a soft hammer head, I would just temper it very soft using a sub-critical anneal (in the 1275 deg. F range). If you work in very dim lighting and bring it up to a point where it is just showing a little bit of red, then hold it there until the heat soaks all the way through the hammer head, I think you should be fine. As John mentioned, then let it cool very slowly in an insulated container. The difficulty will be holding it at the low temperature until it is thoroughly heated. Fortunately since grain growth isn't really an issue you can exceed the dull red temperature on the surface if necessary. Your other alternatives are to use a brass or copper striking hammer (Harbor Freight has a cheap brass one for around $25, and you can sometimes find them at flea markets) or weld a sacrificial piece of mild steel to the top of your fuller or guillotine tool. Personally I prefer not to have soft steel hammer heads in my shop, but each to his own. Quote Link to comment Share on other sites More sharing options...
dogblazer9598 Posted November 13, 2018 Author Share Posted November 13, 2018 thank you for your help it is much appreciated .i see your in upstate ny too .are you getting snow ? thank you doug Quote Link to comment Share on other sites More sharing options...
Latticino Posted November 13, 2018 Share Posted November 13, 2018 No snow yet today, but they say it is on the way. If you are in Upstate NY I hope you have looked into joining the NYSDB group: http://www.nysdb.org/ . Monthly meetings and good info shared. Quote Link to comment Share on other sites More sharing options...
dogblazer9598 Posted November 13, 2018 Author Share Posted November 13, 2018 latticino I am going to join when I attend a meeting next month . Quote Link to comment Share on other sites More sharing options...
JME1149 Posted November 14, 2018 Share Posted November 14, 2018 Here's another direction you may want to consider. Rather than softening a hammer, depending on the design of your guillotine, you could weld a small slug to the top edge for a consumable contact point. This would focus the impact. Or you could just take the top die out when it begins to mushroom, throw it in the forge and re-shape the top surface back to flat. Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 14, 2018 Share Posted November 14, 2018 I have a sacrificial piece of round stock welded to the impact area of the top dies. Keep the edges dressed if they mush over and replace them if needed. Quote Link to comment Share on other sites More sharing options...
arkie Posted November 15, 2018 Share Posted November 15, 2018 Like this? Quote Link to comment Share on other sites More sharing options...
Glenn Posted November 15, 2018 Share Posted November 15, 2018 Arkie, yes, only mine is a guillotine fuller. Each top die has a sacrificial piece of round stock welded on. It makes a great target for the hammer (grin) To answer a previous question, try Heat Treating, general discussion A2 is the transition point where when heated metal becomes non-magnetic. You can find this by hanging a magnet from a thin wire and bringing the heated metal CLOSE to the magnet. If the magnet is attracted to the metal, you are not at A2 yet. If the magnet is not attracted to the metal, you are at A2 or above. Quote Link to comment Share on other sites More sharing options...
arkie Posted November 15, 2018 Share Posted November 15, 2018 I need to make a guillotine fuller. Sometimes the angles on the scissor type create problems. Straight up-and-down works better on lots of things. Quote Link to comment Share on other sites More sharing options...
