Bowie for a buddie
CreekSideForge
After a stupid amount of time and a restart, this is done. Started with a blade of 1084 that worked just fine up until the point where I decided to do the heat treat again because I wasn't satisfied with the first one. Bad idea because it was too thin by that point and the edge looked like it was Lake Michigan on a windy day:(.
Restarted the blade using 80crv2, which worked just fine. Forging, heat treat and grinding went well.
Anyway, the guard is 1084/15n20 with 12 layers twisted. The handle goes tiger striped maple, wenge and bubinga with a length of 4.5". It is finished with several coats of Tung oil and I will be putting wax on there also. The blade is 8 3/16" long by 1 3/8" wide and 1/8" thick.
My friend loves it so I think it's a job well done.
  • 1 month later...
