eyrian Posted April 23, 2008 Share Posted April 23, 2008 Ever since I got started with welding, I've been doing all my hot work outside on my stone porch for fire resistance/safety. However, I've really gotten tired of lugging my tanks about 100' uphill from the shed/shop, and I really don't want to contemplate moving around the forge I'm building. The shed is large enough to work as a smithy as well (Is that going to be a problem? Should I just install a sawdust collector?), but it has a wooden plank floor, and I'm worried about fire resistance. I'd rather save my money for steel and a nice anvil. What is the cheapest way I can install a functional, fireproof floor? I've got about an inch of clearance to install the floor in before I start running awry of doors and such. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted April 23, 2008 Share Posted April 23, 2008 why not compacted Clay ? Quote Link to comment Share on other sites More sharing options...
Mills Posted April 23, 2008 Share Posted April 23, 2008 I use sheet rock. stinks some when the paper burns. Has to be replaced occassionally, easy to stand on, too, I like it better than a rubber mat for that purpose. Quote Link to comment Share on other sites More sharing options...
MooseRidge Posted April 24, 2008 Share Posted April 24, 2008 Mine's gravel over plastic sheet......Gives good support, but doesn't hurt my back and knees the way concrete or brick does.... Quote Link to comment Share on other sites More sharing options...
chyancarrek Posted April 24, 2008 Share Posted April 24, 2008 I just lay down concrete board around my hot drop areas when I'm doing a demo in a parking lot, wooden floor or on grass the host doesn't want burned. I don't worry about the rest o' the areas where hot drop isn't a problem. Chasing an errant piece and retrieving it quick enough won't present a fire hazard. Quote Link to comment Share on other sites More sharing options...
welder19 Posted April 24, 2008 Share Posted April 24, 2008 Sheetmetal is probably the easiest way to go, the last time I bought any was a 4' x 8' 16ga and I think it was around $28. I don't know how big of a floor you need to cover, you could always just spread some sand over it . Welding isn't too bad, it's torch cutting that creates the biggest fire hazzard. welder19 Quote Link to comment Share on other sites More sharing options...
ertwdan Posted April 24, 2008 Share Posted April 24, 2008 I used 22ga 4 x 8 sheets to cover the floor and the first 48" of my walls. Best $100 I've spent. I also share the space with my woodworking equipment, but I try to move it outside and keep the metal work indoors where the noise won't bother the neighbours. Another method I used for a while was "quilting" a floor together with scraps from the sheet metal shop at work. Stitching these little pieces for my floor helped improve my tacking and sheet metal skills. I covered about 100 sq ft this way for the cost of some welding wire (maybe $1.00) Quote Link to comment Share on other sites More sharing options...
eyrian Posted April 24, 2008 Author Share Posted April 24, 2008 Thanks for the replies, guys. I'm gonna check out sheet metal/tread prices. If not that, then I think I'll probably go for concrete board with some fire-resistant paint. That sounds cheap. Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 24, 2008 Share Posted April 24, 2008 Make sure whatever you put on the floor is not slick when it gets a little dust on it. As you lay down on your back, with your knees behind your ears, and just after you are able to breathe again, it becomes important remember where you tossed that hot piece of metal. Quote Link to comment Share on other sites More sharing options...
Finnr Posted April 24, 2008 Share Posted April 24, 2008 Glenn? is this the voice of experience talking? Finnr Quote Link to comment Share on other sites More sharing options...
Glenn Posted April 25, 2008 Share Posted April 25, 2008 Finnr, I would never do something like that intentionally. (grin) And it was a bit of water, but dust, dirt, sand, are just as dangerous. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted April 25, 2008 Share Posted April 25, 2008 4 x 8 sheet 16 ga recent purchase ( last week ). $ 51.- and it will get worse for a while. I go through a fair bit of sheet. Hoping to find better prices this fall but hard to say. Stainless is plain stupid in price. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 25, 2008 Share Posted April 25, 2008 if it's an old wood floor have you though of a nice borax solution soak on it? Won't help with the sawdust issues but will help fireproof it from minor exposures. Just like the borax soak on cotton shop aprons will help and then help clean them when they are to be washed---and then need resoaking. Old galvanized roofing may be a cheaper side wall protector. Quote Link to comment Share on other sites More sharing options...
Caius Posted March 31, 2011 Share Posted March 31, 2011 i got dirt. but i did set dust on fire before by droppin a hot knife.. Quote Link to comment Share on other sites More sharing options...
Ed Steinkirchner Posted May 3, 2011 Share Posted May 3, 2011 my floor is shale over plastic sheet as well, but the walls have old corrugated roofing tin, with the ridges horizontal, on them. Fire proof, and with some primer and white paint, almost makes the shop bright! Anyway, i would think that standard mild steel sheet would be appropriate on a wooden floor, as long as no oil gets spilled on it! I am not a fan of clay, because if it gets wet it sticks to boots enough to stick ya in place at the anvil. Just my opinion on the matter. Ed Steinkirchner Quote Link to comment Share on other sites More sharing options...
