April 16, 200818 yr The gentleman that has it for sale told me it was dated, 1903. 355 lbs actual weight. He just had it weighed. Says the top is level and clean. It is on a metal stand. Asking, a little under 2 dollars a lb. How do you access an anvil? Its a two and a half hour drive; what do you think? Thanks in advance for your replies, Fred
April 16, 200818 yr good brand I would like one. Hit it with a hammer and look for the bounce, checking for problems like, is this an anvil a fire survivor that ruined the heat treat? are their cracks in it? Price sounds good too. 2 thumbs up.
April 16, 200818 yr Sounds like a good deal. Take a ballpein hammer with you and strike the face of the anvil, the hammer should rebound back at you. CAUTION: DO NOT STRIKE HARD! it could cause damage to all four of you. 1-YOU, 2-the SALER, 3-anvil, and 4-hammer. Shoot, 2.5hrs away, make a day trip and see the sights....on the way back! Post pictures when you get it.
April 16, 200818 yr For that price I'd consider re-heat treating if necessary. If it's lost it's heat treat in a fire I'd use it as a bargaining chip. Then again I live a couple thousand miles from good anvil deals so my perspective may be skewed. Yeah yeah, okay, my perspective is naturally skewed but I'd buy it. Frosty
April 16, 200818 yr I`d Buy iT !!! LOL sounds like a good deal like Thomas said take ya a ball peen and see if its got rebound . I think theres a bp on IFI or on anvilfire
April 16, 200818 yr Author Thank you for all the informative hints. I'll take my camera and post a pick. Fred
April 16, 200818 yr Fred, keep in mind, you're making knives. If there is some sway in the face, you can work around that. You don't need as much surface area to work on. Big anvils are fun to work .
April 16, 200818 yr Test rebound. If that is good buy it. Wonderful size and a good price. What more do you want?
April 16, 200818 yr Fisher anvils remain flat because the body is cast iron. They're quieter, too. With a little luck your anvil to be will have nothing but a few small edge chips, which is no big deal. A level and clean face would be what I would expect from a good Fisher that hasn't been abused. I have a small Fisher that I like, but if I was to upgrade, another Fisher in the three-hundred pound range would be precisely what I would want. Good going.
April 16, 200818 yr I have a large Fisher, (500+ pounds), and I love it! Check that there are no cracks around the hardy and horn. Check rebound---http://www.anvilfire.com/FAQs/index.htm Anvil 5 Testing Rebound for instructions. Sounds like a good deal if the condition is good.
April 17, 200818 yr Fishers are great anvils but do not ring - one of the reasons old smiths sometimes steered away from them. I had a 250 for a while and thoroughly enjoyed using it.
April 17, 200818 yr Sometimes you can get good deals on fishers since they do not ring. An anvil that should ring---but doesn't is a *STAY* *AWAY* and so folks who don't know fishers will sometimes think there is a problem. Sure makes a difference to the ears after a long day in the shop. However I don't like Fishers as demo anvils as the sound of the anvil ringing out helps draw people in---good idea to wear ear plugs though...
