January 23, 20188 yr DuEulear , I made a similar table with the addition of a fan in the space below the cutting grate to suck out the vaporized metal dust coming out of the plasma cut as well as a door to reach in and pick up parts that drop between the bars. Anvil, I never intended to come across as saying that my way is ''the way'' , just being forthright about sharing some things that have worked for me over the years and for wide range of different projects. Maybe I'm too old school to really ''get'' emoticons. Of course I don't take down set ups for a specific job until I'm done with it . I do pick up tools or parts I'm not using if they are not needed or in the way, off to the side within reach if I'm going to be using them again soon or back to their usual place if not. The whole point of this thread was started by Glenn on ideas on how to set a useful layout / work table . I linked another thread that I had started about how a dedicated layout table was a valuable asset to a blacksmith shop. I included ideas and pictures of my shop set up and what I have found to be useful or not and why. You or anyone else are free to critique how my shop is set up, I do it myself regularly to see what I can do to improve the whole process. One or several, big or small , messy or neat a dedicated layout/ work table is a great addition to have .
January 30, 20233 yr I would love to see this thread resurrected and be able to see y’all’s benches or work stations. I figure, like me, it will also give you an excuse to clean off your bench! Mine is made from all scrap wood, and was recently made much, much more sturdy by a friend who threw some plywood under the 2x4s and who also added some braces. Underneath is all my non-ferrous scrap storage.
January 30, 20233 yr Here is mine for vise. OTher one is hybrid woodworking and machinist vise on it . REason why this workbench is cut diagonaly is becasue it is easier to walk from outside to room. Its tight spot between door and two benches. About vises i like having like bench for it where i can throw tools when iam done with working around vise, and it is faster to grab file hammer from table, or to put grinder on it, even they dont recomend instaling post vise to workbench, i designed this workbench this way and its is a litle bit lower then machinist vise workbench. I will see to weld better stem to postvise, becasue this one is bend that i welded on.
January 30, 20233 yr Yes. Pretty much. Everything has its place and I’m one that when I finish using a tool I reach and put it back in its spot.
January 31, 20233 yr My ADHD turns every last flat surface into storage, and my focus is equivalent to a sawed off punt gun shot. I do generally put things in the same place but short of having specific plans or goals, my pile of in progress projects has spilled from the rack by my anvil to my tablesaw, grinder table, top of my forge, on my coal forge, the floor under the forge, and any other flat surface including in my kitchen and kitchen table. I have the room and will be putting in some dedicated work benches but propane is currently expensive...
January 31, 20233 yr On 1/31/2023 at 8:58 AM, natkova said: I had that U shape workbench design before, there are pros and cons to that. I love mine. What are the cons?
January 31, 20233 yr 52 minutes ago, Randy Griffin said: I love mine. What are the cons? You loose space . You only have now workbench on three sides if you want to install shelfs or chest or something in that wall you can't. And if shop is small you kinda can't walk nice it's not comfortable for me I tied L to be honest and I like when I have separated stuff.
January 31, 20233 yr I like this thread when i set up i bring out the gear i need after that i'm not responsible for where it ends up and how it ended up like that but the best thing i did was put wheels on my 4x4 table along with a post vice.
January 31, 20233 yr 56 minutes ago, natkova said: You loose space . I can see that. I have a large area in the back for a lot of stuff. All the forging, grinding and cutting is done there. This part is only for knives. Design and assembly, tempering, fine tuning, leather work, sanding and polishing. I can’t stand for long so everything I do I must be sitting and so far this has been the best for me. A few things I will change but overall it works.
April 2, 20233 yr This is my work table. Finished it last week. Closing in on having my back yard shop in operation.
April 17, 20233 yr Here is the new outside one. If I need a flat surface I have some loose pieces of plate to lay on it or for cold work plenty of plywood. I can't control the wind, all I can do is adjust my sails. ~ Semper Paratus
April 24, 20233 yr I found a few photos from my old shop on a computer disc. You can kind of see one my welding bench's in one, to the right, barely make out another work table under the debris piled on it. I had a passion for making and designing them. I take photos of "everything" now....
April 24, 20233 yr Nice tables. I have some somewhere. I have tried to clean, I Need to do some work but lately Im just to tired or exhausted. Little by little. Then maybe there will be a boom of work. But first this mess needs organized. There have been periods of organization and messes but at the moment I blame having kids on the state of my shop lol. Wouldn't trade them for the world, tho. sometimes they test my resolve on that. I title these, "what work table?"
April 26, 20233 yr I would feel right comfortable in there. I like organization but it doesn't last long. Besides I don't feel too energized or creative in a spotless, austere shop...
May 20, 20233 yr Should I demolish my old table which is made of wood and build iron one ? I have issue with space too, where usually chop saw goes, does it need it stand like I made for my drill press
