Jim Coke Posted September 26, 2017 Share Posted September 26, 2017 Greetings All, I decided to make a tool to hold items horizontally in the vise. A sheet metal Visegrip welded to an angle iron does the job quite well.. It works great for sharpening lawn mower blades and I am sure it will come in handy for blade smith work. It works super for holding flat stock for fileing because you can adjust it to verious angles.. I found another version at Tractor Supply that also works well . I think the original intent for the tool was to pick up heavier flat stock. Note the loops.. Just 10 bucks.. I have made up several because everyone that sees me use it wants one bad.. Great gift.. Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
VaughnT Posted September 26, 2017 Share Posted September 26, 2017 Very sweet ideas. Those split-jaw grips are great when you want to hold a hook in place while you plug weld from the back. Never thought about welding one to some angle iron, though.... Quote Link to comment Share on other sites More sharing options...
Hotshoein4 (Mark) Posted September 26, 2017 Share Posted September 26, 2017 They market something very similar to farriers and they fit into the hardy hole. Pretty dang handy Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 26, 2017 Share Posted September 26, 2017 Nice Jim! Thanks. I'll have to check out the farrier's supply now too, thanks Mark. I love handy tools, they make me smile just imagining what I can do with them. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted September 26, 2017 Share Posted September 26, 2017 Good ideas Jim. I have the second pair with the loops at work for light sheet metal pulls with a slide hammer and a hook on the end. I also use it to pull multiple weld on pins/ studs. They work great. Hadn't thought of chucking them in a vise. Great, now I need another one for at home Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted September 27, 2017 Share Posted September 27, 2017 Jim, from what I can see from your pictures, You're shop is to clean for a blacksmith. Years ago a smith in Atlanta was hosting an Alex Bealer Blacksmith Association meeting. He always kept his shop clean with everything in it's place. The demonstrator came in and said, "This shop is to clean for me to demonstrate in." He then picked up a hand full of gravel and dirt and threw it on the floor. Everyone in attendance laughed and thought that it was very funny. That was the end of the meeting. All in attendance were immediately ordered to leave, especially the demonstrator. Let me know if I can help you. Wayne Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted September 29, 2017 Share Posted September 29, 2017 Good ideas. Something we've done in the past to hold flat pieces horizontally is to clamp the fixed jaw of the drill press vise in the leg vise, screw handle at the top. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted September 29, 2017 Author Share Posted September 29, 2017 Greetings Wayne, Yep I like a clean shop but that's only my demo no power shop .. One of my other shops where the bigger things get done clean not so much.. I hope things are going well for you.. Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
JerryCarroll Posted September 29, 2017 Share Posted September 29, 2017 The modified vise grips are a great idea! Years ago when my sons were in high school and taking welding that was available then, a project was a drill press vise made from different sizes angle iron. Not very pretty but functional. I have used them in my bench and post vises for a number of projects for years by doing what Frank Turley suggests--thanks Frank Jerry Quote Link to comment Share on other sites More sharing options...
