Hand forged tongs from rebar
Thank you, What is your specific question concerning the  bottom blast lawn mower deck forge with a brake rotor in your photos?
  • Replies 582
  • Views 71k
I really don't have any questions on it people just said we need pics and I kind of promised id get em out.
Without questions, may I suggest that you fire up the bottom blast lawn mower deck forge with a brake rotor in your photos, using your solid fuel of choice, and then tell us how it worked for you. Photos will go a long way in understanding what you are doing and how the forge is working.
Thank you for your patience in this discussion.
Have a great Thanksgiving.
 yeah got to wait till Friday schedule got pushed back
and you have a good thanksgiving too
I got 5 squirrels cooking
I thank you Glenn for at least getting close to where I could not. I will take that into account as a learning experience.
you find the captions useful sorry the pics were not good I took them at dark.
goodnight everybody see ya tomorrow.
Ryan, before you fire up the forge, you're going to need something to reduce the size of the hole in the middle of the rotor. You don't need much: just something to keep the fuel from falling down. For example, look at the second picture in THIS POST or the fourth photo in THIS ONE. Even a piece of heavy plate with a couple of slots torched in it would be better than what you've got. (Also, slots are better than holes, because you can clean them by sticking in the point of a poker and running it back and forth.)
yeah I thought about using some bolts to do it
Good idea. Make sure that they are NOT plated, though: hexavalent chrome will make you sick, sick, sick.
I heard vinager will take the coating off of galvanized coats
You mean the bolts you don't have to bolt the pipe to the rotor?  :)
And yes, vinegar will remove the zinc coating from galvanized objects.  However, I don't think vinegar will remove chrome coating.  Just make sure you know what you have before you get started.  You're so close now.  We'd hate to see you get sick right off the bat.
Geriatric eunuch bolts? Yes, that should work well.
I use a 1/4 inch piece of angle iron drilled a bunch of holes and now I have to make it fit
Y'all having a good Thanksgiving
1 hour ago, ryancrowe92 said:
I have old rusty bolts with no nuts
All joking aside, rusty is better here anyway.  If the bolts are rusty you know they aren't coated with something that will make you sick when they get hot.  If you have taps you can make your own threads, but a couple dollars should get you enough appropriate nuts at your local hardware store.  If those are galvanized then you'll want to soak them in some vinegar for a few hours to remove the zinc if they will be close to the fire.
hey guys know it has been a while so here we go.
well the forge has worked better than any thing i have built but i have a slight problem you know the thing that keeps the ashes in and the coals in well it kinda melted.
1/4 inch and melted it had holes drilled in it in a ribbon burner pattern. i have to blow torch it out.
but the forge worked 100%  little problems other than the pipe getting clogged up so i got to figure something for that might have to get a caulk tube of that refractory cement
but i got good heats on the rebar and have to run down on the bar a little bit more then i can begin the bending.
also coal didnt come
Well if you sketched or got a picture of this to explain what you meant by it, and how you installed it, we probably would know why it burned up.
No idea what you are talking about with the " ribbon burner pattern".
Working 100% must mean something different to me. Lol.
Got pictures?
Thanks for the update; sounds like things are moving in the right direction.
Well, there’s your problem: TOO THIN and TOO MANY HOLES.
Remember, all other things being equal, MORE AIR = MORE HEAT. For a forge this size, you don’t need more than a single 3/4” hole or four 3/16” holes. Any more than that, and the fire gets too hot. With such a thin plate, there’s not enough mass to prevent overheating and burning out.
 The solution is simple: either replace your grate with a couple of heavy bolts welded across, or get a thicker plate (3/8” or more) with hole(s) as described above.
solution weld two of those plates together and drill 4, 3/16 holes right.
I have used a grate of less then 1/4" for over 3 years without it burning up. Holes in mine are half inch and 3/8". It will need changed out eventually ( and is getting close to that point)  but if it was done right right it sure shouldn't burn up in a few days. Which tells me something wasn't done right ( and there are many right ways to do it.)
then its probably the ash grate which im gonna fix
Das, You are also burning soft cold, while Ryan is burning anthracite. That might be making a difference. Furthermore, you have the speed control on your blower to regulate the blast quite delicately, but I don’t remember what Ryan is using right now
actually wood. coal didn't come
and it burns fast faster than i can make it
and how does the chunks not fall off in the holes
Hmm.  Can we get some pictures of your current setup, with captions?
phones dead and forge is in shop for repairs
