170# Trenton Anvil Questions
Possibly, there is some give by the softer body material after a long hard life in most anvil brands.  However some start with a bit of a lean too as anvils were freehanded under powerhammers and so not guaranteed dead straight/orthogonal at the start, especially older ones.
22 minutes ago, Michael Gendron said:
Is it normal for the anvil to sag or lean more to one side?
These were forged bodies so they typically are not perfect like you would see with a cast anvil. It's nothing to worry about. Nice job on the clean up.
  • 1 year later...
On 5/25/2016 at 8:50 AM, Michael Gendron said:
Thanks i just put it back in the tank to get the last of the rust off then i will coat it with the boiled linseed oil
Michael,
Did you ever get a date on your anvil? I just bought a 185# Trenton a couple of months ago that was made in 1911 according to AIA. It looks like it could be your anvil's brother.
Nice job on the restoration. I have not done anything to mine except a little wire brushing (manual) and beating some hot metal on it. I may give the electrolisis a shot.
I really dig my Trenton.
Congrats on the great find.
Thank you for your service.
3 hours ago, Black Frog said:
Shady,
Can you post a closeup of the side logo stamp, and another of the serial number?  I'd like to add it to the Trenton logo database.  Every new entry helps!
Sure can, I will try to do so this evening when I get home.
On 10/23/2017 at 6:58 AM, Black Frog said:
Shady,
Sorry Black Frog, I got busy and forgot to post these.
11 hours ago, Black Frog said:
Thank you! This is toward the very end of the 2nd style of U.S.-based logo stamp that Trenton used.
For that serial AIA indicates 1911.
Can you make out the maker’s mark? I can’t tell for sure if it is a lazy Z (on its side), an M, or an N... or??
