_Jake_ Posted August 16, 2009 Posted August 16, 2009 So I have a whole bunch of cast iron weights from old windows. For anybody who hasn't seen what Im talking about they are about 16 inches long and 1 and 1/4 inch wide cast iron and are from windows about 75 years old and were recently replaced. My question is: Is this essentially wrought iron? I was considering turning them into new curtain rods for the newly renovated windows. Quote
orgtwister Posted August 16, 2009 Posted August 16, 2009 i would say there not wrought iron the ones i have come across in jersey were cast iron and there is a difference between the two like when people say they have a wrought iron railing on there house it usally plain steel Quote
arftist Posted August 16, 2009 Posted August 16, 2009 Most are an especialy low grade cast iron, but there could be wrought iron ones. The cast should have a noticable parting line and a finnish similar to sand. Quote
dkunkler Posted August 16, 2009 Posted August 16, 2009 All sash weights I've seen have been cast iron,high silicon high carbon brittle cast iron.Can't forge it. Quote
welder19 Posted August 16, 2009 Posted August 16, 2009 I have seen a lot of them and have nver seen any that were wrought iron or even forged for that matter, they are cast iron and are the bottom of the barrel iron at that, they were made of whatever junk they had laying around since they were neither structural or cosmetic in nature. About all they are good for is using them for weights for something or toss them in the next load of junk going to the junkyard. welder19 Quote
_Jake_ Posted August 16, 2009 Author Posted August 16, 2009 Great thanks guys. I guess Il have to use something else. But what would happen if I did try to forge them? are they just brittle and difficult? or is there some sort of risk involved? Quote
Finnr Posted August 16, 2009 Posted August 16, 2009 Cast is not forgable . once it gets hot it will crumble . Ya got some great trotline weights though. Finnr Quote
CBrann Posted August 16, 2009 Posted August 16, 2009 imagine red hot popcorn flying around your shop. thats what cast iron does when you hit it after heating.... Then you can spend a couple hours on fire watch... and put out smoldering stuff... And get a hot foot when a small bit lands on your shoe and burns its way through..... How do I now this?..... I admit nothing!!!... but you can do whatever you want, good luck Cliff Quote
Drifter Posted August 16, 2009 Posted August 16, 2009 I'm with Finnr on the trotline wieghts. If you don't trotline trade em for dressed fish to someone that does. Drifter Quote
ThomasPowers Posted August 17, 2009 Posted August 17, 2009 Well you can also get cast iron up to melting temp in a forge and then it sorta "splashes" when you hit it with a hammer... Quote
Doug C Posted August 19, 2009 Posted August 19, 2009 I use them to hang on tree branches to help shape the tree. Quote
Sweany Posted August 19, 2009 Posted August 19, 2009 build one of thesehttp://gottatopic.com/wp-content/uploads/2008/03/trebuchet_copy.jpg Quote
Francis Trez Cole Posted August 21, 2009 Posted August 21, 2009 I make firepots and I cut them in pieces and use them as clinkerbreakers the work very well. Quote
Charlotte Posted August 21, 2009 Posted August 21, 2009 If you slice them up into thin sections, polish and acid etch, the often show very pretty patterns. Drill an hole and coat with auto clear coat or blue repolish and coat and you could sell them as jewelry. Quote
Michael Posted August 21, 2009 Posted August 21, 2009 I've read, somewhere, that if you ever find square sectioned weights in the pile of cast sash weights, those are wrought. That said, a couple years of picking thru scrap piles has never turned up a single square sectioned sash weight. Quote
Frank Turley Posted September 22, 2009 Posted September 22, 2009 Use them for sheet metal stakes.Turley Forge and Blacksmithing School : The Granddaddy of Blacksmithing Schools Quote
MadHatter Posted October 11, 2009 Posted October 11, 2009 Couple years ago I watched a demo by Maria Cristali making a small jewelry box out of what she claimed was wrought iron window weights. Gorgeous material, and beautiful finished product. Keep your eyes peeled, guys and gals. :cool: Chad Quote
wapiti_forge Posted October 11, 2009 Posted October 11, 2009 If they are round they are probably cast iron. They'll also have obvious marks from the sand casting. The wrought iron window weights that I have seen were square. That's a good starting point. Regardless of the shape, you won't know until you do a break test to see if it is fibrous or not. Good luck. Quote
