Okay Guys I need some help!
You may find a cross pein hammer more useful for forging, but in your circumstance, anything is better than nothing! I only used two 11/2lb ball pein hammers (just like my tutor did for all his eighteenth century style work) for my first four or five years. One hammer was flat and the other was full faced. In combination with the flat, the bick and the edge of the anvil you can get at most forms. The main specialist hammer was a long bodied narrow cross pein hammer for water leaf forming and crimping in a vee tool. Good luck! Alan
Forging stainless steel
Not bragging...just aching!
My experience is with 316L grade and I have not found it any more susceptible to hot short/crumbling from over heating than ordinary mild steel. The problems I have encountered are at the other end of the working temperature range. If you do work it too cold under a power hammer it can split, which I would describe as a cold shut. I reckon you have to hit it at least twice as hard to move it as mild steel. Given the shorter working time per heat, because it is really springy and resilient at even red heat (risky if working a larger piece under the power hammer), you should allow almost four times the mild steel forging time...I usually forget when it comes to pricing! Small stuff like bottle openers and spoons I heat with oxy acetylene torch right beside the anvil/hammer. I have a gas economiser on the bottle set / torch so it will automatically shut off the torch when I hang it up which saves vital seconds of prime forging time. Alan, (who has aching wrists and forearms having this week forged two 3500mm (11'6") octagonal tapers from 2800mm (9') of Ø50mm (Ø2") 316L SS. 49mm to 35mmAF (2" to1 3/8" AF))
Coal or coke?
Certainly with coke you need more than just newspaper and air. I used to use paper and split up some kindling, scoop out a nest in front of the back blast tue and as that burned and formed a heart introduce the coke gradually. I used to break up the kindling wood by holding it in the vice and using palm heel Karate blows, then splitting it further on the anvil hot set. If I could light the fire with one match I reckoned I would likely have a good day, not for any superstitious reasons I hasten to add, but because if I was concentrating enough to light the fire efficiently that degree of focus meant the work would go well! After a decade or so of occasional cuts and bruises I started lighting the fire by turning on the air and playing the rose bud torch directly onto the coke...much faster! Alan
swage block
After twenty years as a professional smith I bought my first swage block because somebody turned up with it in the back of their car. I thought as a blacksmith I really ought to have one. That was twenty years ago and it has sat by the door where I offloaded it ever since...apart from using its bulk to set up a series of supporting pillars for assembling one job. I know some people find swage blocks very useful, but if you are starting out and budgets are limited, I would use your money to buy tools for the project in hand and wait for opportunities to buy speculative equipment when it turns up cheap. I might even sell you mine when you actually need one! Alan
Size Is Everything
I would explore cleaving out the handles following the grain rather than rip sawing them out. The greener the wood the easier but even with seasoned and planked timber you can rip saw oversize following the grain and then split off the excess with a drawknife or froe or similar, the handles will be much stronger. Alan
Grease or Oil for Post Vise Screw?
To clean out the female threads in the box I bend the tip of a bit of 10mm (3/8") bar at right angles and grind the bit to a chisel/scraper to fit the thread groove then rotate it in and out as a thread follower. I bend the other end in the opposite direction to form a handle and an indicator of the the direction of cutter tool. I use graphite grease, I have too many bits of kit to maintain a regular oil maintenance schedule, so they are checked before and during use on an ad hoc basis.
Traditional spit roast
In case the pm does not get to you...20mm worked fine, can you see the images I tried to post? I can only suggest that you do not make a crank handle but follow my windlass and tube system. Trying to turn and hold an eccentric load for 4 or 5 hours would not be much fun. Much better to give it a quarter turn, lock off, leave for ten minutes and turn again...
silicon bronze
Why are you using cast iron for your mould? The basic process/principle of casting is that you pour molten metal into a sacrificial mould from sand or clay which can then be broken off easily. What you are doing is a form of brazing where brass is melted onto the work pieces to effect a joint. The whole point of which is that it should stick... the problem arises if it does not. Your original post asked for advice about the temperature it could be worked at. On a forging forum context "working" implied forging. Were you actually wanting information about casting? Alan
Unknown Twist
Dick Quinnell used it quite a lot. He referred to it as "water twist". He made it using a gas torch to isolate the heat as well. As far as I remember he just held one end of the bar in the vice and with a twisting bar or wrench on the other end just heated and twisted one way and then heated again and twisted the other way rather than gripping in the middle and trying to do two together. I think that avoided getting any bruises from the wrench. Alan
silicon bronze
If you experiment with it so that you can find the upper limit you can then work safely below that. I find it works just like butter compared to steel's cheese and stainless' Parmesan! You can move it very radically in one heat so you do not need to push the heat limit. In my forge I can see that it is red before it gets too hot, but as Fe Wood says the ambient light levels of your workplace are specific even at different times of day.
@ Olly, You are of course very welcome to borrow those bits for your event if you can make use of them
The smallest leg vise
@ Timothy Miller I have just dug this out from the pile of "to be tidied up one day" in the old forge. It has a much longer leg than yours, or any of my others come to that. But the actual body of it is an inch or so shorter than yours. I picked up probably over twenty years ago and it still has a 15 pounds price label on it! I only noticed the mounting plate and spring were attached to the wrong side when I took the photo!
@ Timothy Miller I have just dug this out from the pile of "to be tidied up one day" in the old forge. It has a much longer leg than yours, or any of my others come to that. But the actual body of it is about the same as yours. I picked it up probably over twenty years ago and it still has a 15 pounds price label on it! I only noticed the mounting plate and spring were attached to the wrong side when I took the photo!
Smallest flypress
On stones of course! Though maybe rating it in half-pints would be more commensurate with its stature! Yes the frame is cast and the thread and lever are steel. The corrosion pits are because it was dumped in a quarry after my Grandmother died and I dug it up ten years later after a chance remark by my father when he saw my first fly press. "I chucked a little one of those away when I was clearing out her house" It is spring lifted and the spring is either bronze or gunmetal, perfect condition when I got it apart. Alan In this area of the Cotswolds they call the wall crest stones "cocks and hens". Just thought you might like to know that!
Tue Iron Help.
@ mainly Jeremiah Well I have to admit that I went onto the bottom blast in part because the 5 gallon oil drum I was using rotted away and in part because I acquired a power hammer and wanted longer length heats. If you're starting out and going to be mainly using hand hammer then a back or side blast with a "swan's nest" fire is probably the most advantageous, have a look for the thread earlier where John B and I shared ideas with OllyO, I posted a sketch of the hearth layout. http://www.iforgeiron.com/topic/28704-alcosa-forge-dimensions/page-3 @ Jeremiah and lupiphile The bottom blast I made is not like any other I have seen. It consists of a sheet metal rectangular funnel underneath the hearth which the air blast fed into, there was a counter weighted drop out at the bottom for the ash. Mk I was a piece of flat 12mm (1/2") plate sat on top of the funnel and had a double row of OA torch cut holes running along like a domestic gas oven burner. I plunge cut these with the torch and discovered they were tapering holes larger on the side I cut them from, so I flipped the plate to put the small size on top so if any crud got into the hole it would fall right through. Mark II I fabricated from some 60x30mm (2 1/2"x1 1/4")bar set on edge with a 3 or 4mm slot between. I will measure it when I am at the forge next if you're interested. It was from rubbish lozenge shaped bar so I again used the angle to form a tapered slot for the crud to fall through. I manage to get a 500/600mm (20/24") heat with it and if I want a short heat I just drop a couple of bits of plate over the air blast slots. I also made a couple of banana shaped chumps which enabled me to contain the fire if I needed to reduce the spread and increase the depth of the fire (back to the swan's nest) for fire-welding or punching. The fire is kept not very high generally, nothing like the Lillico fire pot, the bananas are only from 50mm (2") square I think. I seem to remember that the Lillico pot was a heat source and that the workpieces were set on the ledge around the fire rather than in the fire itself, I have a couple of amazing Italian films of shovel and bucket forging with a water wheel powered hammer which uses a similar ledge type enclosed fire/furnace. So as far as the stuff getting stuck on the joint surface it sounds from your description like there is not enough breeze/ fire-heart between the air blast and the workpieces, but with a 9'depth there should be plenty. Are the workpieces being heated in the flame above the fire or in the fire itself? You are not just burning a small fire in the bottom of the box are you? The coke is not spitting is it? If it is try and bank it up around the fire so it will dry out before use. Try making up a fire plate and dropping it on top of your box and see how you get on. Use the box like my funnel. I found using the blanking plates and bananas useful to contain the fire for lighting and then when it was under way make the fire shape I needed by adjusting the loose bits. My final confession is that I have not lit the coke fire for 7 or 8 years, I have made a number of gas furnaces and they are all I use now. The last time I lit it was to show a student how to fireweld!
Combination L/R Quarter Pein?
I found that style of hammer the best for drawing out and spreading before I acquired a power hammer. The one I used for hot forging I bought at a used tool place. I was told it was a saw setters hammer. Used for truing up the saw blade on a big band mill. It weighs 1800gm (4lbs). I discovered the advantage of the twisted cross pein when I was using my teachers home made raising hammer when silversmithing. I noticed the hammer was much nicer to use on one of its faces and realised it was because of the twist. I then made all of my cross pein silversmithing hammers with a twist deliberately. And it also made me aware of the potential when I spotted the saw setting hammer in the junk shop. One good thing that has happened thanks to your thread, I have given my hammers a wire brush and wax in order to take the photo. They have been in the drawer unused and going rusty since I stopped the silver work in the late Seventies! So on behalf of my hammers, thank you! Alan
Smallest flypress
Following on from the littlest leg vice thread, here is my contender for the smallest fly press! It was used by my grandmother for riveting the poppers onto her leatherwork. The spike on the front was used to assemble the components and push the leather onto them. A double ended bottom block was used for the different sides, male or female. I have been using it as nut cracker.
I remembered I had another little hinged vice in the shed at home. This one is complete and fully working.
I thought I was going to win until I saw twodogzz post! The little pin vice was my Grandmother's and it came with a small fly press of which I will post a photograph some time.. Pair of 5 inch leg vices Another pair of 5 inch leg vices
Tue Iron Help.
More of a cooling fin than a baffle then? The heat source is up against the end of the tue rather than the air pipe so possibly concentric rings welded onto the back/inside surface of the end plate would be more effective for heat exchanging. The only part of my home made tue that burnt away was the end of the air pipe which I had stupidly projected out of the end plate and put a fillet weld around, of course that became the hottest part and was eroded. Your drawing shows it flush so should avoid that problem. However I would still go for a dry bottom blast set up!
Picture of a lock. How is the finish obtained?
I also thought bead blast at first but if you zoom in you can see some longitudinal marks on the back plate, running in the same direction as the wood grain. So I would think probably just fine wet and dry or similar (crocus paper, rouge paper), wrapped around a stick or block. May even have been Water of Ayre stone. Then either oiled or waxed. Does the book give any clues as to what it is made from? Of course it might have been made out of brass and been chemically patinated....it looks very similar to a silvered clock face, treated with silver nitrate.
