1,017 -
Everything posted by K. Bryan Morgan
That looks like a decent anvil in ok shape. I would buy it if the price were right.
Your making great knives. Your an inspiration to aspiring makers. Keep em coming.
Real or not: the famous viking women knife
K. Bryan Morgan replied to Herdebreid's topic in Historical Blades
I searched for several hours and found nothing but modern representations. Nothing in the archeological record at all. Every reference to Viking knives were two types. The Seax and the Puko. -
http://www.iforgeiron.com/gallery/image/34623-626/ This is what I did.
I did some research on those anvils in your picture and I believe its a cast steel anvil from India. I found several sites that show that exact shape and that's where they say they come from. Found on Amazon.com. That was a couple of years ago and I didn't see them there now.
Wrecking some padlocks
K. Bryan Morgan replied to Stormcrow's topic in Axes, Hatchets, Hawks, Choppers, etc
You should send your results to Master Lock and see what they say. I would be interesting to see what they think about it. Just my thoughts. As usual your product is durable and strong. Well done. Looking forward to seeing the video. -
That is really nicely done. And thank you for showing the unassembled parts. Helps me understand the processes better.
I own a Diamondback 2 burner Blacksmiths model and am very happy with it. I can hit welding temps at 10 psi, its easy on fuel and warms up quickly. I run it at 5 to 7 psi for normal operations. I have never regretted my purchase.
Stainless steel bowl of the appropriate size would be my first thought. They are cheap and easy to find. Any of the big box stores would have them or your local restaurant supply.
Chasing and repousse video tutorials
K. Bryan Morgan replied to saign charlestein's topic in Repousse
I've seen Saign Charlestein's work on another site and have been following him for quite a while. Your work is nothing short of inspirational. Besides the fact you made armor for one of my all time favorite movies, The Chronicles of Ridick. I'll never get that good. But I'll sure enjoy watching yours. -
I use a cheap dimmer switch on my shop vac to power my forge and it works great. It most definitely will get to forge welding temps. No problem. I burn up steel in mine on a regular basis when my attention wonders for a moment. If someone can get welding temps with a hand cranked forge blower, using a shop vac will definitely get it there.
- 27 replies
- solid fuel
- coal
(and 2 more)
Ya the more I think about it the more I think its a Kohlswa. He's gonna love it. He is a professional machinist and makes knifes for a living. Quite a nice person.
Try draw filing. Clamp your knife blank to a board, so the tip don't poke you in the belly, it does happen, then put the tang of the file in your left hand. Pull the file towards you. If you put the tang in your right hand you have to push, not pull. But then that's not draw filing. You can really hog some material in a short period of time this way. With some practice, practice, practice, I've seen some very nice bevels made this way. There just aren't any short cuts when it comes to hand filing. Its all about technique and consistency.
Really nicely done. They look great.
Peter Wright found in Alaksa
K. Bryan Morgan replied to K. Bryan Morgan's topic in Anvils, Swage Blocks, and Mandrels
Thanks, It will be nice to have both anvils. My large 242 lb Rhino and this 60 lb PW. Sometimes I need a smaller face and the beginners RR track anvil I have, just wasn't big enough to do much on without just wearing out my arm hitting so hard. -
Leaf Springs for Ax Stock?
K. Bryan Morgan replied to teenylittlemetalguy's topic in Axes, Hatchets, Hawks, Choppers, etc
Yes it is lots of fun. And Rich is so right. Gotta do It and keep doing it and then do it some more. -
I made an axe with a mild steel body and a leaf spring bit a couple of years ago and welding it up was pretty easy going. I didn't have any issues and it went rather smoothly. I did use lots of flux to keep the evil oxygen out. Jake P and I did it in a very crude and simple forge made from a steel desk drawer lined with kitty litter. Worked great. -
Sometimes you just get lucky. I was in the right place at the right time and had the money in close order. I'm very happy with the purchase. -
Well it wasn't 75 lbs, it was 60, but its a Peter Wright. So I didn't care. '?do=embed' frameborder='0' data-embedContent>>
That sounds about right then...it weighs in at 55-57 lbs on my bathroom scale...and that could easily be off that much. -
I am so sorry to hear this Steve. Prayers sent.
Well I found me a Peter Wright. 55-57 lbs by the bathroom scale. No idea what year it was made. Paid $200 and figured it was a deal. Anvils are rare as hens teeth up here. It will make a dandy light use, small item anvil and I plan to use it well. Some one did some grinding on it, but I think the plate is intact. I bounced a ball peen hammer around on the face and it bounced really nicely for a small anvil. The edges are also in pretty good shape. I'm pleased as punch.
I was one of the respondents on that other thread. I like pretty much everything about my Rhino but one thing. The horn doesn't come to a smaller diameter point. It stops about the one inch range. Which is fine if your only making one inch or larger rings, loops ect. I wish it came down to a finer point. Not necessarily a pointy point, if you get what I mean, but smaller would be nice for small rings, loops ect.
