Take rhino anvils for example. They are cast steel (similar to rock crusher plates) and the hardness/toughness is the same all the way to the core. If the deck is badly damaged you can mill it down to flat again and still have the same hardness as it started with
What I need is a small shed. still getting that figured out with the land lord. For now the driveway is working ok. Would love a wind break and a roof over my head
I just liked the pic. With the forge glowing in the back ground. Was too dark to take pic of the progress, so I took a pic of my setup. The tongs are on the vice. When you can no longer see where you set the hammer it's time to call it a night.
Every mig tip is going to be slightly different. I have 2 T burners that are identical in parts and build but both work very differently! Funny part is the one that's the most imperfect works the best in my forge. The other is as close to concentric as I can measure ( 0.0015") but dosent work as well as the crooked one. Changing tips in the crooked one made it burn very poorly. That same tip that messed up that one made the centered burner improve. All where the same size and from the same package. Remember these tips were made to feed wire to a welder. Not as gas nozzles.
Just my experiences and thoughts
the leak theory sounds plausible. Either run the higher preasure or try all the tips you have
I did straighten the last one on a stump some as I remember TP talking about doing that. But I don't have a wood hammer yet. I'll try using a hunk of wood like you said. I have used my vice to straighten before but it sucks the heat out fast on this little stock. All the steak flippers started life as a nail salvaged from a rail tie wall we tore out at work. I think part of the bending problem is I'm twisting with a crescent wrench. I need to weld a handle on it to use 2 hands. Maybe I just need to forge some twisting wrenches.
Your pun foo is strong
I think my twisting is improving. The steak flippers go in order left to right from the 2nd one to the 4th. May do some twisting practice today before I make anymore flippers
Did some heavy hammering today. Got my hardy cut 1 3/4" deep to square. Then made a hardy horn(?) from 1 3/8" axel 5" long. Then had some time left so I did few more steak flippers
Made my first chisel from the coil spring to finish off my hardy a bit deeper . After normalizing 3x Brought it back up to critical and Quenched in peanut oil then cleaned up one side real quick with a file and watched the colors run slowly
