Everything posted by Reversepolarity
Found another one
Thanks for the info. my first trenton. Really liking it.
Special swage block
That block is a dandy!
Found another one
Found another one
It is a cast base. what year would that put this anvil at?
Found another one
The logo stamp is pretty worn. I can tell that the N is not like an X like most Trentons that I have seen. As far as the serial number goes, I cannot tell if the first number is a one. Or if it is just a weird spot on the foot. What age would you put on this anvil?
Found another one
I am not worried about the face at all. Rings fine, and rebounds at 75-80% Maybe the paint exagerates the line. Serial number is 165236
Found another one
Stopped by a flea market over the weekend. After inquiring about blacksmith tools. A vendor mentioned he had some stuff at home. After meeting at his place, and a little negotiating. I walked away with a 123 pound Trenton, Warren tool 3/4 fuller, and 3 pairs of tongs. Someone had painted it silver at some point. But it cleaned up easy enough.
Making a compass
Nice job! How long are those, and are you getting any flex? I work in an industrial sheetmetal shop. We hand layout all fittings , and parts. My dividers are my most used hand tool.
Vertical weld at floor level
As was mentioned clamp the rod in the end of the stinger, or bend the rod as needed. Straight in is fine for rod angle. Hold longer on the edges, and move quickly throught the middle. That will flatten the bead out. 7018 is to be ran vertical up. Also swivel the rod to aim at the edges, don't just weave side to side. Your 6010 rod would also be suitable.
How's this for a vise?
That Prentiss is a DANDY!
What electrode to use on wrought iron?
Very true. Most guys at welding supply stores have no experience. I have had great luck stick welding wrought iron. I use a small rod 3/32" 7014 or 7018 Also run at the low end of the heat. Just enough amperage to keep the rod from sticking. Really watch the puddle and react accordingly. The slag formation behind the puddle will be a little different than welding mild steel, but you will get the hang of it. Another key thing I have found repairing wrought iron is the prep work. Clean the joint with a wire wheel. The cleaner the better.
Post vise score! ID help?
Indeed those are the weight, and date stamps
Swage block
I paid $300, I was happy at $2 per pound There is one for sale right now (Craigslist) in Seattle right now for $400 also The last few I have seen for sale around here were $600-$800 for this size, and they sold at those prices. Patience always pays off.
Swage block
Finally found an AFFORDABLE swage block on Craigslist. 15"x15"x4" Got the stand put together today, just have to paint it.
Without a makers mark on it. It is pretty hard to ID. Looks to be in great shape
Question for the Peter Wright guys
I totally agree, most Peter Wrights I see have been rode pretty hard. I do like this anvil. And the large working area of the face. But I much prefer my Hay Budden anvil. And as was mentioned. The weight stamp is 212 pounds. But even with the face damage it tips the scale at 213.9
Odd vise
Works out great for me. I had been looking for an 8" leg vise for a couple of years. Most of my work is making obsolete parts (heavy work) for loggers, and farmers. This vise being offset is a great bonus for long work. I also like the depth of the jaws, they hold work very nice for file work. The best part was the price $60
Thanks guys. The lack of Solid Wrought stamp has always made me wonder.
I know that it makes no difference to most of you.But I would like to get a rough idea of the age of one of my anvils. It is stamped Peter Wright Patent, but it does not have the stamp of solid wrought. Does this help age it? actual weight is 213.9 pound
Odd vise
Tore the vise down tonight to wire wheel, and wipe down with linseed oil. Whoever made did a great job. No electric welds anywhere. Wonder how old this thing is.
Bending jig ideas
Here is the bending plate I made. I use a hold fast on the anvil, or clamp it in a vise. It is 5/8" plate. Square upset hole adjustable mandrel bender, various sizes adjustable bending fork And an oval hole for drifting
Odd vise
I am always looking for different tools. Came across this leg vise. Seems to have been home made. But was made VERY well. It is offset, and will be great for long work. It has 8 1/2" wide jaws, and closes very straight and tight. The rear jaw is the movable jaw.
leg vise repair
I coat them with boiled linseed oil
leg vise repair
I wish I had a press. No such luck The U bolt will get turned around when I mount the vise. I just put it on quickly to test spring pressure.
leg vise repair
This entire process took just under 3 hours. With a little work. Most of these old vises still have alot of serviceable working life in them.
