JHCC
2023 Donor
    20,936
About JHCC
Profile Information
  • Gender
    Male
  • Location
     Oberlin, Ohio
Recent Profile Visitors
33,221 profile views
  1. This is only worth doing if you can get full penetration on your welds; any gaps will act as shock absorbers and reduce the effectiveness of your anvil. Someone suggested on here once that rather than putting the various pieces together and welding around the edges, putting a piece of 3/8" (or thereabouts) rod as a spacer and then filling the resulting gap by building up beads from the inside out. Since your consumables are paid for, this actually might be not so unrealistic. It would certainly give you plenty of practice running beads. (NB: While the sketch above shows the setup to weld the face onto the body, you could do the same thing to join together the pieces that make up the body itself.)
  2. It’s often the things that go without saying that most need to be said.
  3. While in southern New Hampshire on business, I stopped by a couple of favorite tool stores and found a few goodies. From the Tool Liquidation Center in Derry: And from the Vintage Tool Shoppe in Fremont: Total expenditure: $41.
  4. That's quite interesting. I've heard about the trick for estimating the correct forging temperature for aluminum, where you rub it with a pine stick and see what kind of mark it leaves: brown needs more heat, black is just right. I wonder if anyone's compared the stick trick with the Sharpie trick to see how they compare.
  5. Leaving aside historical methods, you can get a thin layer of brass on a steel piece by heating it and scrubbing it with a brass brush. At the correct heat, a small amount of brass will melt off the brush and adhere to the steel. Here's an example from the Ukrainian armorsmith Vyacheslav Perepelitsa (who, interestingly, uses a rotary brush mounted in an electric drill to great effect):
  6. Picked up a few more items from the scrap bin today, including an old shotgun barrel. Thinking of creative applications….
  7. A lot of better-quality anvils and swage blocks in current and recent production are made from ductile cast iron, which has additional elements (usually magnesium or silicon, I believe) that cause the excess carbon to form spherical nodules that are more resistant to cracking than the usual flat flakes. Malleable iron similarly has the extra carbon in a nodular structure, but that's a product of casting in white iron and carefully managing the subsequent heat treatment. Ductile iron was developed in the mid-20th century, and I doubt that Fisher would have bothered to change from a proven material to a comparatively new one unless it offered a significant benefit at a comparable cost. That's just my speculation, though. "Gun iron", by the way, was a form of cast iron created by reheating pig iron in a finery furnace, not -- as with the production of wrought iron -- to burn off the excess carbon in order to produce wrought iron, but to oxidize the excess phosphorus that would otherwise weaken the cast object.
  8. I like the handle for moving the anvil around.
  9. Yea, it is a hefty tome.
  10. Dropping in at the town metal recycling bin yielded a big lug wrench, a chunk of 1-1/2” schedule 40 black pipe, a four foot length of 3/8” round, and this beastie: Whatever it is, it’s 3” in diameter and just under 14” long. One end is drilled for a cotter pin or something, but I don’t know why the other end should have a couple of tapped holes and be fitted with what appears to be a zerk.
  11. Also make sure to read the READ THIS FIRST page first.
  12. Bienvenido! You've got the right approach, starting with what you have and working from there. If you're using the weights as an anvil, you should mount one of them on edge, to give more mass underneath the hammer blows. If forging on a rounded surface seems odd to you, consider that this is how traditional Chinese "turtle" anvils have been used for centuries!
  13. To follow onto Larry's thoughts, if you think seriously about what locations you would use a moveable hammer, you may find that there are only two or three places that really make sense. In that case, it might be possible to create a series of mounting blocks (with their tops even with the floor surface, obviously) that you could rotate the hammer between. That gives the advantage of mobility (if needed) and the advantage of more solid mounting (which is always a plus). I don't know how the mounting bolts on your hammer are set up, but you might be able to use the same kind of setup as Torbjörn Åhman's for his Bêché 75kg hammer. I've linked this video about the foundation bolts to start at the moment that demonstrates how they work: (The full playlist of him preparing the foundations and mounting his hammer can be found HERE.)
  14. Specifically, 2H₃PO₄ (phosphoric acid) + Fe₂O₃ (iron oxide/hematite) = 2FePO₄ (ferric phosphate) + 3H₂O (water). Phosphoric acid also reacts with Fe₃O₄ (iron oxide/magnetite), but the formula is a bit complicated.
  15. Addendum: Raw linseed oil (often sold as "flax seed oil") can be used as a finish for cooking utensils; boiled linseed oil with chemical additives (e.g., metallic dryers) cannot.
