Everything posted by coltpax
- File knife 3
File knife 3
- File knife 2
- File knife 2
- Ex file
Ex file
Paracord wrap
Paracord wrap
My personal burglary
The sound of firing a round can also solve a "problem" as well. So can the experience of being on the wrong end of that round.
Wow, small world. Police dont show up here either. My Grandma lives in the middle of the town, and the police have only shown up once, and then it was three hours after she called them. Now, I dont have any fancy guns like the police shotgun or an AR, but I think a double barrel is just almost as frightening. But just recently, somebody broke into the autoshop right beside the fire station. Wasnt even 10 yards away. Thats just plain dumb. Just remember, Shoot to kill because a dead man tales no tales, and also, a dead man can't sue ya (but watch out for the family).
Kinfe Makers What Do You Think????
I think it looks good. I wouldnt change a , except to maybe put a lanyard hole in that piece sticking out the back.
Practical Projects for the Blacksmith
My friend found this book at a yard sale and got it for a few dollars, then decided to give it to me (dont know if its a compliment or an insult), but either way, I got a decent book. Good for some ideas, and i would have never thought about making a goat yoke.
Matte Finish
k. thx. i think there maybe some gun blue around here.
Matte Finish
I like mirror finishes, but I'm making a tactical knife, and tacticals dont usually consist of mirror finish blades. I dont have access to a bead or sand blaster, but I could try the scotch brite wheel.
if you had a lathe what would you do?
I believe i would make a black powder .22 cane gun. After building a new shop to put the lathe in because I'm all out of room in my garage.
Matte Finish
Okay, i've got a knife all polished and would probably be fine right now to use. However, I want to put a matte finish on it. i would like to know a good spray paint that can take alot of wear without rubbing off, or how i would put a matte finish on plain metal. Thanks, Colton
blade finishes
What you probably saw was gun blueing.
blade finishes
just wash it. it should be fine to use as an eating utensil after you was it. Or, If your gonna store it in a dry place, you wont even have to do that. Just make sure you clean and dry it after use. As long as it stays dry while not in use, it should be fine.
I'm doing a great job of melting my work
yea, just put plug up about half of your blower.
punch making
no, you only dip in water at a dull read heat. You can still forge the punch at the normal forging temperatures, just dont dip it in the water until it is at a dull red.
Shop Mottos
"set your goals low to avoid disappointment" Thats the one I seem to be using lately.
How much fuel (charcoal, coal, coke, propane) do you have on hand?
I have one 20lb propane tank that gets filled up when its empty. Just about every gas station around here fills them, so Its fairly easy to get filled. I only have about 60lbs of coal around because I have to drive an hour just to go get it, and then its $7 for a 40 lb. bag. Also, I dont have alot of coal around because I prefer propane unless I'm demoing.
mercury
Mercury BAD Motor Oil GOOD And I know you said not to ask, but how did you get it?
A couple for the Blade West show...
Beautiful and interesting pattern on that bowie. Never seen a pattern like that.
Help, starting off.
I got all my metal from helping clean up a mechanic's shop. Forge looks like a good design to me. By what I've read, sounds like your wanting to make blades. If you know a sawmill worker, you can get sawmill blades, if you know a farmer, you can get disc plow blades, or if you know a mechanic you can get leaf or coil springs. Even your neighbor might have an old lawnmower blade to spare. My best advice is to ask around, and your bound to find something.
