Dale M.
Everything posted by Dale M.
  1. I would NOT weld drum into top plate, i would bolt it in.... IF you ever have to change out drum or want to change forge design, bolts come apart easier than welds.... Here is how I did it.... Not saying it is a perfect design, but it works well for me and so far there is not much I would change .... Dale
  2. Simplistically it all sounds good..... But as the say , the devil is in the details.... Dale
  3. For the average "joe", probably Oxygen/Acetylene rig with big cutting tip..... If you have something similar to a 12 inch capacity cutoff saw (which most of us don't) that would work... Anything smaller is a exercise in futility.... Dale
  4. Excuse me!!!! Do not actually have to make anything (BUT I DO) to recognize something on verge of being reckless.... IF you don't want to be criticized quit posting these type of things and quit defending something that was pretty close to stupid and getting some one hurt.... You can not defend the action that all of us see, your mistake was not recognizing a problem and dealing with it but also going public with the foolish action .... I spend 38 years in "industry" and the place I worked had a rule, ANYBODY who saw something unsafe could SHUT DOWN ANY OPERATION if a unsafe condition was observes.... Don't yell "EXPERIENCE" to me!... Dale
  5. Don't think anybody that criticized actions of anvil is out of line ...The bobble and weave of anvil is some what disturbing.... At 43 second mark in video I would be inclined to stop and get better base for anvil.... Also in my mind anvil was a little small for such heavy striking.... Anyway glad nobody got hurt.... Dale
  6. Visit resale shops and look at hair driers kind of noisy but its a really cheap blower.... Other solution is visit HVAC shop and try to talk to boys in back... Might have small blower out of heater thet might work.... I also found a nice little blower on back of a dishwasher that was in junk pile.... 25mm is only about 1 inch... its pretty small.... You want volume but not much pressure... As size goes down, pressure has to go up to move same volume.... In my mind bigger tube is better.... Dale
  7. To those critical of my references to web sources of information... I have been on the web since its inception, and have logged hundreds of hours of research on various subjects.... Seems that the things I am specifically interested in have least information or least creditable information available... I chose to display these sources so people would know where my questions were based from... NOT to recommend or validate them.... I am a believer of researching things from many sources and hopefully making a intelligent or informed decision from all available information presented.... Even in this tread some of the abstract comments are valid proof on the lack of validity of information ... Some of the comments here ( in this set of message thread) have the same unsubstantiated information from vague sources that people critical of Wikipedia are expounding as truths.... So enough of the grumbling on the validity of the reference material and lets get to what people have actually used and what works for them... Dale it was wikipedia that caused the confussion between boraxo and borax, the point has been made, maybe some confusion could have been avoided by reading this pinned thread first
  8. Whine!!!.... Still can't see it... Dale
  9. Guess I should also not use GOOGLE or BING or manufacturers web site either.... Most times I have found Wikipedia to be accurate enough to at least get a handle on information I need and usually is accurate enough to set me off in a direction I can go to validate it at ANY OTHER SOURCE of information... Sorry if my reference material source does not conform to your standards.... Do you believe everything you see on Youtube? Respectful to your comment just the same... Dale
  10. Gads... Why couldn't I find this thread earlier, would have saved some bandwidth ...
  11. Ahem.... I already have this... Is not BORAXO and 20 Mule Team Borax not basically the same stuff? "20 Mule Team Borax" is 99.5 % "sodium tetraborate"... http://www.20muleteamlaundry.com/about/what-is-borax/ "Boraxo" is "sodium tetraborax decahydrate" https://en.wikipedia.org/wiki/Borax And anybody explain the difference? Dale This post was moved and added here from yet another thread.
  12. Anybody have any good home brew recipes for flux for forge welding... I am about to venture into this area and at the moment just have Boraxo hand soap available to me... Been told it is workable, and also it was mentioned the by adding salt to Borax it helps process ( but how much) .... Yes I know I can order many fluxes online but that is not what I want to do at the moment.... So what's your favorite mix of common household items ... Dale
  13. ACK!..... My secret is out..... Hi Jake.... Dale
  14. Odd... Because I can logged into Facebook and I still cant see it!!!! Dale
  15. No offense taken, but if one can building something on the fly such as I did, the "plan" changes as build progresses... I believe in the fact that one can adapt a design to fit his needs to what one has available in a somewhat limit source of supply.... I did not plan to build a coal/brake drum forge in beginning, I was experimenting with making gas burners for a gas fired forge when I happened by a pile of junk where that had a old gas water heater and some old furnaces, while I was intent on salvaging burners if they were adaptable I also realized junk pile also had the old gas BBQ and buried down in pile was brake drum.... Didn't take but a few second to completely change directions and concieve a plan for forge... Mental picture/plan of forge came blinding fast and didn't even need to put it on paper it was so simple... Construction followed only a couple days behind .... I guess my point is why spend hours engineering something and spend hours laboring over it if something that is quite acceptable may be sitting there staring you in the face, IE: Gas grill cart.... Now I am on the lookout for another gas grill base (many are not acceptable due to cheap construction) and am thinking of using plow disk as bowl similar to open hearth forge... Gas burner is still on shelf, propane tank and regulator in now in storage and I am happily heating steel.... IF I were to purchase everything new and follow precise plan, new coal forge or gas forge probably would have cost me $600-800... But I have less than $100 invested and it may not rival fancy "store bought" forge but it gets the metal just as hot... IF one wants to create a detailed drawing and buy all new materials and assemble with rigid adherence to master plan, its ok... But when every dime counts, I would rather spend the saved dimes (from adaptive construction) on tongs and hammers and books on blacksmithing, maybe even on a few lessons from a master... Dale
  16. Is permissions set to viewing by general public (not restricted)? Dale
  17. Well... Sorry but I didn't really mean "junk" as useless... I meant it as steel that has inferior grade and may not be as useable or desirable as to steel with better pedigree for particular application..... Dale
  18. I realized later that It would have been a lot cheaper to simply manufacture the tyree from tubing, but was caught up in all the "brake drum" forges I had seen on Youtube and was sort of caught inside the box for the use of pipe, and thinking at the time heat was going to be issue (which it is not) and tyree had to be more robust, probably will manufacture next tyree from tubing for dimes on the dollars I spent in pipe for this one.... Since I am at least 40 miles from any muffler shops I sort of made a shopping list for parts needed and spent a day in the "city" shopping for forge parts and lots other things my back woods community does not have... The fan is a auxiliary blower fan from Datsun 240 Z and is sealed 12Volt DC permanent magnet motor so ventilation of motor is not needed ... And yes the damper is on inlet.... At the time it seemed simplest way to go... Can't see any reason to change it (yet) but have given it some thought... Already have foot switch for fan, just have not got around it installing a relay and the switch (and switch bypass)... Motivational issues I guess... OR maybe its if it is working, don't fix it... Dale
  19. Why are you spending so much time and effort and reinventing the wheel when simply a few scrounged parts and a Saturday in the shop will build you a great forge for $50- $100 ( or maybe less) ... '?do=embed' frameborder='0' data-embedContent>> Dale
  20. Quite frankly, I would do away with old material that is difficult to work with, and replace it with newer materials, IF you are good enough smith, person that is contracting work will never ever know.... And once you have taken something "old" and reformed it to newer shapes it looses it validity as a authentic antique piece... Antique piece is probably something at least 75 years old, has some sort of patina and hopefully a provenance,.. IF you heat, bend, hammer or change finish (patina) it's no longer original and is probably now just "junk".... Dale
  21. If one wants the fold down ability for storage space, and retains hand truck use then yes go for it... If you want purely portable (for doing off site demos) I still think putting forge fold down on front side is more practical... If one wants "just portability" then a wheeled cart aka: used bbq cart with bbq junk (hood/pan) removed and fire pot added... Dale
  22. IF you are going to have motorized blower go to a resale shop and just spend $3 for used hair drier and disconnect heating element.... IF you want mechanical blower some like of squirrel cage (car heater fan) with 4:1 or 5:1 dear ration will do fine.... Auto turbos rely on really high rpm to create air pressure.... Its more work and bulk than its worth, but if that is what you want ..Go go it... Dale
  23. Nothing wrong in teaching them skills, they will be survivors, the kids that are TV/video game "heads" will be first to need help from skilled people.. We have a young lady in our blacksmithing group, she is probably in mid 20's and puts a lot of the guys to shame at the entry level where she is at... Really have to admire her... Dale
  24. Other option is not try and uncoil spring but to cut off length needed and heat and hammer till its in shape needed... In pic bar on left is spring stock (approx 1/2 of a coil) Next is center punch Cold chisel Slitting chisel "Eye" punch (center is hollow for eye in "horse head" art hoof pics) 6 inch ruler Dale
  25. I have uses suspension coil springs to make basic punch, center punches and cold chisels and slitting chisels and basic punches.... IF you tempered item properly after heating and hammering (shaping) they are excellent tools you can make.... Dale
