Steve Sells
Administrators
    9,162
Everything posted by Steve Sells
  1. also its hard to have or make your own "custom tools" before you have any idea if the function it needs to perform.
  2. This is a heck of an accusation to make! Many, myself included make blades that can hold an edge, and it does not take me very long to sharpen a blade. Why do you accuse this of being a fake? That evidence do you have?
  3. I have found that steel works wonderfully, Read through the forum and you may get more ideas.
  4. I am glad to see that you have joined in at the Forum, as well as the chat. We enjoyed speaking with you last night. I am sure you will find many things to perk your interest here as well.
  5. I should add, in case you don't already, while still clamped, bake your mokume billet for about an hour at 100F below the lowest melting point of the metals you are using.
  6. they WHY would he post it in a blacksmithing section?
  7. news paper works, used to use it a lot, still do on occasion. Lately I grab a few chunk from the BBQ and light the charcoal with the propane torch head. it lights fast, and while it burning pile the leftover coal/coke from the previous forge session. and start cranking.
  8. If you are serious about learning swords, then "the $50 knife shop, by Wayne Goddard" is one of the best for starting out with out getting a major bank loan. Even the price of the book is a good deal at $9.95 at Amazon, last I looked.
  9. I am in Fort Wayne, I can always use tongs, and electric blower. I have apprentices that need most of their own things still, such as a certain 16 year old boy. SO I can safely say most any shop equipment you have to sell. WILL find a home through IFI
  10. welcome to the I Forge Iron site.
  11. Welcome, many people here of many facets of this hobby/trade/passion called smithing. you have good company here.
  12. After translating your post; I see that you would be ashamed (and in another post state "insulted") that I explain swords work differently than knives, but you have no shame to confuse a sword with chisels, hammers, etc, and then post here before doing any research on your own part, expecting outlandish things with no facts nor reference outside of video games or television shows? I am having a hard time deciding if this is for real or you are just trolling. I have tried to give you a break. If you want to run with the big boys and make a real sword, at least try to learn a few things on your own (books, internet, or try to search this site in previous posts) and you may understand why you have been getting so much flack for your proposals.
  13. Is that a typo or did you really make it one half of a US standard inch thick? :o
  14. I may be REMISS, but isn't it time for a reply from jimmy SEALE :)
  15. the low temp salts are NOT sodium, some are calcium based. much safer that NaCl.
  16. most people do not use table salt because of this, calcium is much less hazardous, plus there are commercial mixes available, see browning or the Ellis website for low temp salts.
  17. There are various ways to scientificaly examine blades. In repeatable methods, that are commonly used around the world. Place a cold blade, after heat treatment in a vice, and see how far it can be bent over before failure, most quality blades will go over 90 degrees with little cracking. The point where a blade fails is measurable in degrees to compare to different methods and materials. a Rockwell tester: impacts the blade with a known item at a known pressure to compare hardness. A round bar (5/8 inch is fine) placed in a vice, cutting edge is pressed sideways into the bar until we see a deformation of the cutting edge, then released. hopefully the deformed steel will return to place. showing resiliency. The problem with Hitting a rock, is not all rocks are the same, and How much force was used? a human arm can swing with varying degrees of force. The idea of testing, is to have a test that can be repeated over and over again, by most anyone, and getting the exact same results with the exact same item, therefore being able to Honestly compare non-exact items in a meaningful way.
  18. lol woody that's why I like you :)
  19. Nothing wrong with wanting to make a blade, but a sword is not a thing you can just jump in and make the first day out. there is a lot more behind swords than just shaping the blade too. because a sword is much more than just a large knife, there are vibration dynamics that have to be accounted for in the construction as well as balance. and we have not even talked about what metal to use or how to heat treat it. If swords are your goal, I suggest that you begin by learning about the general forging that is common to all forms of iron work. As attempting to start with a sword is like trying to win a NASCAR race before you have a drivers license. There are many fine books and teachers on the subject, as well as a sword section in the forum, which perhaps is where you should have posted this to begin. Read all you can before jumping in, and you will have a better chance of getting where you wish to be.
  20. Aggressive flux as well as an Oxygen-free environment is a must to forge weld SS, either argon injection to the gasser or many use "cans" to keep air from the metals. Not for beginners. Good luck
  21. NO paper masks wont stop anything but small particulates. They will do nothing for gasses. Leave the zink alone, and you will live longer. PLEASE
  22. Welcome to I Forge Iron, great place to learn as well as make friends.
