Everything posted by trinculo
Lets talk pneumatics: I need comprehensive info on air hammers
I have a homemade "bull style" hammer with a 2.5" cylinder @ 110lbs. At the same air pressure it is considerably more sluggish than my 75 pound Iron kiss with a 3.5" cylinder. The Iron Kiss runs great down to 60lbs pressure. The 110lb doesn't come into it's own until >100 psi. fwiw I make brazil type hammers solo both slitting and upsetting into a rounding die under the iron kiss and I made a set of narrow fullers for cheeking on the home-brew hammer. I do agree that two hammers are great for setting up different tooling for using often times under the same heat. I still drift manually on the anvil using a set of"camelbacks". I am really impressed with the videos of KZ 150 and it's control. Ken told me it has something like 14" of stoke. If it is built anywhere near the robustness of John's hammers that's the way I would go. I've looked at the numbers for building my own hammer and just can't compete with what you can get from either John or Ken.
- KZ150 Power Hammer
Boxing kangaroo sequence
you have a gift. Thanks for sharing this. dw
How to silence a power hammer
I use a BMW motorcycle muffler. I have two power hammers y'd into it and it works great.
Advice needed on Three Legged anvil stand
My humble recommendations are to go with <10 vertical offset and bolt it down. Expand the footprint by using the 1/2" plates for feet on the bottom to gain another 3 or 4" outside the legs. Please post pictures when your done.
HiFi Rack
Curious as to how this project is coming. Would love to see pictures.
pics of my air hammer build in progress
Anvil is 6" solid round.
Here are some pictures of my home brew hammer. The frame is a reclaimed bull reject pulled from a scrap yard in Asheville. The rest is junkyard trail and error. The tup is about 110 lbs. I'm still working on the control mech although it can do single blow and cycles ~ 120 bpm. I can't claim all the work on this. I purchased it from another smith who had welded the head and tup up and had a not so functional control system throttling the intake air. I the replumbed and rebuilt the control system and added another 600lb or so to the base. I'm fortunate enough to have an Iron Kiss that is my main hammer, but it is very nice to have both hammers side by side with different dies. I often use both in the same heat. But make no mistake this frankenhammer is no match for the Iron Kiss in most regards.
Looks Good. What is the hammer weight going to be? From your description I'm not clear if it's going to reciprocate or not. I live just over the line in Asheville. If you want to come see my homebuilt hammer and the plumbing you are welcome to.
What type of power hammer do you use?
I have an iron kiss "75". The tup weighed in at 93 pounds w/o dies. John rates his hammers conservatively apparently. Also a bull inspired homemade 112 pound hammer Hope to get a larger mechanical at some point. Murray or Beaudry appeals to me although I don't have much experience with them.
Some file work i did last night....
wow. beautiful work. Thanks for sharing this.
Tempering flatter from 4140
Would love to see some pictures of the process.
HiFi Rack
Very cool. This is the kind of thing I wish I had more time to do.
3 new blades
Those are gorgeous pieces of steel. Someday I hope to make something that approches this level of beauty.
- forged sledge hammer
feather chef blade
Beautiful pattern! Well done.
kitchen knives
beautiful craftsmanship!! Well done.
hammer for the jury
Do you use a cupping tool on the PH as well? Do you have cheeking dies? I would love to see some pictures of your hammer making tooling for the Power hammer(s). Nice looking bunch of hammers you've made recently.
hammer for the jury
SInce Trip was gone, did you make it with your power hammer or did you have another striker?
Hotcut hardy
trinculo replied to brianbrazealblacksmith's topic in Hot Cuts, Anvil devils, metal cutting on the anvil.For the first year of forging I used a straight hardy of excellent quality from OCP tool. It was shouldered and mostly flat on top. Since Brian taught me and helped me make a hardy of his design I haven't used the straight hardy again. I can cut thicker stock faster than I ever could before. It's amazing how tight the taper holds until you give it a sideways tap while hiding the other side and then it comes out very easily every time. Until forging with Brian for three days, I had no idea how much I didn't know. I am looking forward to the next time I can stand across the anvil from him.
hinges for the wood stove
Cool project Dave. Thanks for taking the time to keep us up to date.
Making a Butcher Guillotine
How do you copyright a tool? Patent maybe, but copyright?
Marking Tool for Punching from Two Sides
What is a strike line die? How is it diff than a center punch? Cool tool.
A pair of short bush swords
Stormcrow, I would love to see the process for the way you make the intergral handles, particularly how to center them to the blade. Always like to click on your latests works.
Garden hoe head
What was the dimension of the parent stock? Nice work as always stormcrow. I really like your style.
