Everything posted by matto
2lb rounding hammer
Dave I'm with you but a little hoof rasp and sand paper go along way in making a handle fit your hand. I have had this hammer for a week now and have almost 70 hrs using it. If I did not make it fit my hand I would probably have half the hours do to fatigue. or I would of started with it and then quite using it because the handle was to big or hurt my arm or hand.
Horse number 3
Scrapartoz if you don't mind me asking how many hours do you have in a piece? And is this what you do for a living??
2lb rounding hammer
New anvil, unable to identify
You can see alittle of the rim around the bottom and the 6 stamped under the horn by the handling hole is classic hay Budden.
2lb rounding hammer
JHCC the swelling spot in the handle is great. I have been using one of crazy Ivan's hammers for about a week now and love the bulge. I fit the handle to what I like and cleaned up the bulge some so it fit inbetween my fingers comfortably. It is a great reference point for me to know where the hammer is during forging with out having to look. It has no effect on my ability to chock up on the handle. It really acts like a gear and cog. Your hand is the gear the swell is the cog. Pete puts a nice not to big button on the bottom of his handles too. Again helps with the knowing where your hammer is in your hand with out looking at the hammer. And the piece of mind that it should not sail out of your hand in a full swing.
- Taking others' ideas...is it OK?
Steel walls
Thanks Steve and ausfire!
Steel walls
The wife is pleased I think that is all that matters.
Steel walls
Looks a lot better in person. Dang window lets a lot of light in. Sucks for pictures. The top is an alder root burl.
Steel walls
Got some 4140
That is what I was thinking. Said that stick had been there since he bought the shop 16 years ago. He also said he has some others there that he will give a good deal on to because they have been there longer than that piece.
Look what came in the mail today
Can't what to here how the hammer works. Is it from fiery furnace? Have a couple hot cuts from them like them.
Steel walls
Ausfire will get a better pic of the table for you. It is 2.5" thick seats 8.
Good looking hammer! Maybe with this one you will find out that your thumb does not help in between your hammer and what you are striking.
Got some 4140
Got 13' of 1 5/8" round 4140 for $45, what are some good uses for it??
Steel walls
Hope this goes here. One wall in my house. Steel sheet textured and 3 coated satin clear coat. Trimmed with 1", 2.5" and 3" strapping.
- Wood & Iron Pot Rack
Hammer Maintance
Nebraska during ww1 had more hemp fields than corn fields. They are also re-looking a the benefits of hemp.
A tree
bent washer in back top of trunk to hook on a wall anchor. if o remember it is about 24" tall and 36" wide. biggest one i have done is about 72" by 96".
Stake tree
was thinking LED up lighting.
A tree
Here is one of my trees. Some of the ones I do clients hange pics of the family on the roots and branches.
New flower arrangement
I really try to keep as organic of a flow and look as I can when doing flowers and trees. All ways helps to have a flower sitting by the anvil when forging one. Have nice landscaping out side the shop to help with the natural look when forging.
What is the attraction of the post/leg vise?
Frosty thanks for going a little more in depth.
Black Iron Pipe?
Frosty would make a great YouTube video. One other trick with pipe is stuff a wet rag in the end you are holding. Saves from the steam and heat traveling up and into your face.
Stake tree
Just. Wanted them to take up less floor space and not be scattered around but all in one spot.
