how did you put the heardy and pitral holes in that? i got a peace of metal i would like to put those in to be a more effective anvil
First, I drilled a 1/2" hole, then I had to heat it up and drift it. It would have been better to drill a 3/4" hole, then drift, but 1/2" was the best I had. It took more heats than it should have because I didn't drill it to the optimal hole. Then I planed the piece with a 7" grinder with a new hard disk with a 36 grit sticky disk glued to it, then progressively went down from there until I had a flat nice surface. Then I drilled the pritchel hole. After I finished the face by draw filing it, then sanding it with a 2" strip of metal and progressive sand paper, I heated it up to almost orange then quenched it in a 2" pan of water that I kept a hose running to cool it off as fast as possible. It did harden up a bit, but it would be better to start with a piece of tool steel. We tested it out today, and it preformed as expected. It does need to be anchored, but so does every anvil, in my opinion.
Hi Brian. This is a really nice piece of work, and it looks very functional. When I put a 1" hardy hole in a 3/4" plate, I had plenty of time to think about drifting it hot while I was chiseling and filing. At least I learned how to use the cold chisel effectively. How long did it take to get hot through and through?
As for rebound, it is overrated. Most blacksmith forging is done in the coefficient of restitution range of .1 to .2, and the influence of rebound is much less. Up into the .8 to .9 range, which is finish forging, it becomes a lot more important. Same for the hammer anvil ratio for heavy forging. As long as one isn't hitting cold metal, or hitting over a thin spot (more of these with a smaller anvil), it is not so bad. I saw a nice new anvil get dinged by a striker who missed and hit the edge. It removed a fairly sizable chip. I took a look at one of the Brazeal mild steel easysmith anvils at a demo. Even though lots of participants were being invited to use them, they were relatively ding free.
  • 4 months later...
  • 2 months later...
Hi Brian,
I just wanted to ask something about the anvil, because I'm in the process of making one.
In the new pictures I saw a chain around the legs. Is it to quiet the ring?
It also seems like it now has a weld in the front and back. Is that so?
The legs are angled at 15 degrees?
Thank you.
Rubén
Hi Brian,
Thank you.
Rubén
Yes, the chain is to quiet it, and the welds are to keep the bolts underneath from vibrating out. I'm not sure what the exact angle of the legs is, but I don't like them splayed out. I want them to back the anvil. I'm not worried about it tipping over because I mount it to the floor or ground.
Maybe it`s because you always anchor it somehow but you`re not worried at all about the legs bending and climbing out under heavy hammering?
I see the 3 legged stands with angled legs and wonder why there`s no lower stretchers tying the legs in.They`d make a handy place for a shelf or rack if nothing else.
