Steven Bronstein Posted October 28, 2022 Share Posted October 28, 2022 Well, I am a blacksmith with 40 years experience and I still have a lot to learn. We had a shop fire 5 years ago. I was able to recover nearly all of my tools out of the ashes. One lingering problem was I was not able to successfully retemper my hammers. I retempered my chisels and could easily temper new hammers. The old ones would go through the process and still come out soft. I went on multiple forums and discussed this problem with friends to no avail. I described my process as follows: Heated them to bright red and let them cool slowly to normalize Heated them to above magnetic and quench in oil ( tried both Canola and Parks) They would not harden. I finally gave up and handled them and just resigned myself to the fact that they were some how negatively affected in the heat of the fire and that was it. I was playing with tempering some new hammers, out of old drive axles, and got to thinking that I tend to work with mystery tool steel so I use a magnet to let me know when I am at the critical temperature. I realized that for reasons I cannot explain ( I think because I was so worried about saving my favorite hammers and doing it correctly ) when I retempered my old hammers I put them back in the forge after they reached critical temperature, just to soak " a little bit more" to make sure I had it right. Well....I have realized that what I was doing was raising them up too high above the critical temperature so that when I quench them, they were not cooling off fast enough to achieve a hardened state, so they stayed soft. I went back a retempered all of my old hammers, when I reached the non-magnetic state I quenched them and they hardened just as they were supposed to. Tempered to a dark straw and they are perfect. I was thinking too much, worrying too much, and could have save myself a lot of trouble if I had just followed the directions. Quote Link to comment Share on other sites More sharing options...
anvil Posted October 28, 2022 Share Posted October 28, 2022 Great Post! And a great lesson for all. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted October 28, 2022 Share Posted October 28, 2022 You may want to correct your usage of the term tempering to hardening, They are not the same thing, and its confusing to use a technical term incorrectly in a technical format Quote Link to comment Share on other sites More sharing options...
Steven Bronstein Posted November 2, 2022 Author Share Posted November 2, 2022 On 10/28/2022 at 10:57 AM, Steve Sells said: correct your usage of the term tempering to hardening I understand what you are saying. My meaning was I wanted to get to the point that I could retemper my tools. I think if I said I wanted to harden my tools folks would say I forgot that I still needed to temper them. I could have said I wanted to harden and retemper my tools, which is absolutely correct but thought that was implied but I guess not. Quote Link to comment Share on other sites More sharing options...
NoGoodWithUsernames Posted November 2, 2022 Share Posted November 2, 2022 Learned something new thank you. I've not done much hardening/tempering as of yet so I had no idea you could "overheat" and quench resulting in a soft part still. Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 2, 2022 Share Posted November 2, 2022 Yes, indeed. The problem arises from how steel behaves when quenched at different speeds. To dramatically oversimplify, steel heated to above the critical temperature needs to be quenched relatively quickly, otherwise the austenite crystals turn into soft pearlite rather than hard martensite. If the workpiece is too hot, it can't lose heat fast enough to keep pearlite from being formed, so it ends up relatively soft. (Overheating also increases the grain size, so even if the piece does harden successfully, its large grains won't be as strong as a finer grain structure..) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 2, 2022 Share Posted November 2, 2022 If you need a term encompassing it all "heat treating" works fairly well. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 2, 2022 Share Posted November 2, 2022 It's understandable Steven it takes a while to know at a gut level there are more than 60,000 subscribed members spread around the planet, the majority with little or no experience at the anvil let alone heat treating. I ignored your misuse of "tempering" but I've been working metal my whole darned life and blacksmithing as a hobby for close to 50 years. We really need to keep in mind people reading our posts may not know steel from aluminum or know heat treating from cooking gumbo. Too many people believe the urban myth that people knew more 100+ years ago than we do now so just because someone in 18th century Europe used Temper for virtually all heat treatment doesn't help folk today. We haven't forgotten how it was done back when, mostly it's been supplanted by better materials, equipment, methods and technique. We're not really dog piling on you, you seem to be a pretty knowledgeable guy, we're just trying to tailor the forum to a world wide web full of first timers. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 2, 2022 Share Posted November 2, 2022 John; what's the correct temperature to draw a Clavier to? J.S.Bach must have known! Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 2, 2022 Share Posted November 2, 2022 Bach did all his clavier tempering in a well. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted November 2, 2022 Share Posted November 2, 2022 Remember Frosty that not everyone that reads this forum is reading it in English. Translations can go weird when incorrect terms are used Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 2, 2022 Share Posted November 2, 2022 I didn't mention that too? <sigh> Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 3, 2022 Share Posted November 3, 2022 (And his Clavier was well tempered in that well as well!). Time to break out my vinyl copy of E Power Biggs plays Bach in the Thomaskirche; nothing like a bit of Toccata and Fugue in D minor to set a great Halloween mood! Quote Link to comment Share on other sites More sharing options...
Steven Bronstein Posted November 28, 2022 Author Share Posted November 28, 2022 I really value iforgeiron as a resource. Thank you all for your generous sharing of your expertise. Quote Link to comment Share on other sites More sharing options...
