swashbuckler_ Posted December 2, 2021 Share Posted December 2, 2021 new guy here! been messing with the forge off and on for awhile found this site a few months ago and been reading thru it and recently a good buddy of mine gave me a stack of farrier rasps (heller i believe) and i quenched one and slapped it with a hammer and it broke so im making a chef knife for my first knife. my question is, i have it ground down and i think im almost ready to quench and temper it but im not sure how far to grind it down before i go about tempering, i have it down to 2ish mm maybe a little less and going off of what i read i shouldnt take it down anymore until after temper. after temper it seems like it will take a little bit to get sharp and im worried about messing with the temper so whats the right way/ideal way of finishing it up im using a 2x72 belt grinder and wondering what grit to start and process, keep blade wet? i apologize if this has been answered numerous times ive read a bunch but i cant use the search with much success ...pictures soon Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 2, 2021 Share Posted December 2, 2021 We always held the blade in our fingers and dipped it in water after every pass over the belt. What grit to start depends on the alloy and how thick it was. Note that finer grits tend to heat the edge more in my experience. I might start with a 120 belt for creating the edge and then go up 220, 400, etc till you get to honing readiness. Others may have their own methods. Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 2, 2021 Author Share Posted December 2, 2021 Ok that makes sense! I guess holding it with your hands tells you everything you need to know thanks for the reply Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 2, 2021 Share Posted December 2, 2021 How will you keep food residue out of that "kitchen knife"? Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 2, 2021 Author Share Posted December 2, 2021 Haha I was thinking that, but as it’s my first one and I’m not one for building things without a need it’s staying outside with my hibachi grill Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 2, 2021 Share Posted December 2, 2021 I see, and you are not planning to use it on food outside with the grill? Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 2, 2021 Author Share Posted December 2, 2021 Well whatever the dog doesn’t lick off I was planning on using a dish brush same thing I use on the cutting boards but I’m open to suggestions Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted December 2, 2021 Share Posted December 2, 2021 Grind smooth so that there are no places for the food to get embedded. Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 2, 2021 Author Share Posted December 2, 2021 Ok probably a good idea the food thing didn’t register as a big deal until he brought it up Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 2, 2021 Share Posted December 2, 2021 Consult with someone in commercial food prep that has to undergo regular inspections---a crack in a coffee cup can get them dinged! Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted December 2, 2021 Share Posted December 2, 2021 Besides all that has been said, a chefs knife should be a lot thinner than a rasp. Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 2, 2021 Author Share Posted December 2, 2021 Ok suppose it’s not ready to go, I’ll grind it down some more Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 2, 2021 Share Posted December 2, 2021 By hold it in your fingers, that means BARE fingers. Two reasons, first is safety, a light touch on a grinding belt with bare fingers will inspire you to pay closer attention. A touch on a belt with a glove can catch and drag as much of you into the moving parts as the device can. Reason two is the point of the suggestion above, your bare fingers will tell you it's TOO HOT to hold well before it's hot enough to damage the temper. Water doesn't soak into bare skin like a glove and there are no burns like a skald, especially if your hand, foot, whatever is trapped in contact with boiling water and you can't get it out. That's B A D N E S S indeed. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 3, 2021 Share Posted December 3, 2021 Surgical gloves are a good option, as they keep the grinder grit out of your pores and let you feel the temperature easily without presenting any safety hazards. Quote Link to comment Share on other sites More sharing options...
swashbuckler_ Posted December 3, 2021 Author Share Posted December 3, 2021 Thanks for the solid advice and exactly what I was looking for.. I’m used to always wearing my tig gloves on everything and I’m wondering how to tell if it gets too hot. Simple and best solution! Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted December 3, 2021 Share Posted December 3, 2021 Never wear gloves around rotating equipment, as they can catch and suck your hand in. Quote Link to comment Share on other sites More sharing options...
Bob Brandl Posted January 29, 2022 Share Posted January 29, 2022 I wrap electrical tape around my index fingers a couple of times and use them as a "shelf" for the spine to rest on, seeing as you're applying pressure to the blade with your thumbs anyway. Quote Link to comment Share on other sites More sharing options...
