Yann Kastell Posted November 22, 2021 Share Posted November 22, 2021 Greetings, after a long time lurking on this forum, I finally decide to post, unfortunately because I have a problem. I am trying to reproduce a dagger from a movie as a Christmas gift, and as I was grinding it, I discovered many, many marks on the blade. I managed to grind a lot of them while maintaining a homogeneous thickness, but there are parts where I just cannot get rid of them. I used a brush before and after working the hot blade, and always wiped the anvil to remove the scales, yet it is still badly damaged. Is there any solutions to fix this issue ? Should I put it back in the forge to try to correct it, or is it irredeemable ? I am a beginner ; I've built my first forge a year ago with bits and pieces, but barely had the time to work. Thanks to unemployment, I work at the forge nearly everyday since early September, but I am still learning on my own, though with all the resources on this forum and elsewhere. By the way, this is a good opportunity to thank you all deeply for all the knowledge here ! Thank you very much in advance for your insight ! Link to comment Share on other sites More sharing options...
Frazer Posted November 22, 2021 Share Posted November 22, 2021 I looks like those are places where the steel was overheated (possibly in an oxidizing fire) and produced excess scale. The way I see it you have 3 options: leave them there, continue to grind them out, or reheat the blade to a planishing heat and smooth them out with a hammer/flatter. I would probably pick the last option if it were me. By the way, cool blade, what movie is it from? It looks sort of elvish to me. Link to comment Share on other sites More sharing options...
Yann Kastell Posted November 22, 2021 Author Share Posted November 22, 2021 Thank you for your answer. I indeed discovered only recently that I might have been inserting the steel too deep into the forge, though I never saw this blade melt. Perhaps it caused some damage nonetheless. I think I'll heat it back and try to do as you said. You saw correctly, it's Aragorn's dagger from Lord of the Ring My brother and I deeply appreciate these movies / books and I wanted to craft him a dagger from the movie. This one seemed amongst the least difficult to recreate. It's been quite challenging so far, but now I feel much more confortable forging a classic knife. If by happenstance some might be interested in seeing the result of the planishing - or even the final result - I can update this post later. Thank you again ! Link to comment Share on other sites More sharing options...
Frazer Posted November 22, 2021 Share Posted November 22, 2021 Even if it didn't burn, all the excess oxygen will make a lot of scale and cause that sort of pitting. It will also degrade the steel so it should be avoided whenever possible. Ah okay, nice. Great movies/books. Certainly, feel free to share some pictures along the way. We like pictures. Link to comment Share on other sites More sharing options...
Yann Kastell Posted November 24, 2021 Author Share Posted November 24, 2021 Well, I tried throughout the day to flatten it, unsuccessfully. I'm a bit disappointed after getting this far into it, but I guess I've learned my mistake. Link to comment Share on other sites More sharing options...
Frazer Posted November 24, 2021 Share Posted November 24, 2021 So it seems like you're left with option 1 or 2 (or some combination of the two). Even if it isn't as flat as you originally planned I wouldn't call it a total loss. I've never tried to make a knife that long, but I doubt they all turn out how you originally planned. Especially when you're just starting out. What kind of steel is it made of? What's your plan for hardening and tempering? Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted November 24, 2021 Share Posted November 24, 2021 This is why the adage of "Forge thick, and grind thin" was adopted. When looking for a flat surface I use light hammering and work the whole surface over to get it as even as I can. You really need to watch the impact spots when hammering and adjust as you go to avoid dents and waves. It takes a lot of practice, but keep at it. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 25, 2021 Share Posted November 25, 2021 Joseph Moxon, "Mechanick Exercises", published 1703: "He that would a good edge win, must forge thick and grind thin." Sound Doctrine! Link to comment Share on other sites More sharing options...
Yann Kastell Posted November 25, 2021 Author Share Posted November 25, 2021 I had planished it at 4mm of thickness, so that I could grind it without too much worrying. The issue is that I tried to forge the bevel (don't know if that's the proper word) instead of fully grinding the edge, and I shouldn't have done this, since the edge have pits aswell. My other problem is that I use a very old and worn-out belt grinder, and the belt is discontinued on the market. It makes the grinding process very long since the belt is exhausted, combined with a lack of power. I do not know what kind of steel it is. I know how dumb it sounds, but I started by gathering remains from the house and from friends. I've been throwing away a lot of steel as I discovered how bad some of it was (some cracked in many thin layers as I heated and worked it ; other simply never hardened after quenching, ...). I am a bit worried actually, because I'm running out of good steel and I simply cannot find a way to purchase some. I visited and contacted many companies dealing in steel around where I lived, whether it was second-hand material or industrial distributor, and no one sells steel capable of sustaining thermal treatment ... Some professionals even have never heard of the type of steel I've been looking for (french / european standard : XC75. And the industry apparently only deals with S235). And to finish answering you, Frazer, I'm not sure what you imply by "plan for hardening". I use vegetable oil (sunflower) for the quenching, and temper it once in the oven. Since I lack a lot of knowledge in metallurgy (in fact I am lacking in many other aspects), I adopt an empirical approach : 220°C for 2 hours in the oven, and observe the results. If I feel it didn't work, I change the parameters for the same steel on future projects. Link to comment Share on other sites More sharing options...
Latticino Posted November 25, 2021 Share Posted November 25, 2021 You might consider going to an automotive spring shop and asking them for some cut offs. Both coil and leaf spring can be made into quality knives, longer blades like you are making in particular. If your grinder doesn't cut you can always go the hand finishing route. Anneal your finished forging in a barrel of wood ash. When cold soak overnight in white vinegar to dissolve scale. Draw file bevels with first a coarse 12" bastard file then a finer tooth one. Hand sand to 120 grit with sanding block. Heat treat using the proper normalization, quench and tempering process for your steel (probably 5160 or 9160 will work). Final sand to at least 300 grit with sanding block and put on a handle. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 26, 2021 Share Posted November 26, 2021 I know that there are several places in the USA that will make custom length belts for grinders that are no longer supported. You may want to ask around for a similar business in the EU. I second the suggestion about buying "drops" from a spring place. You can pass the ABS Journeyman's test with a 5160 (spring) blade! Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 27, 2021 Share Posted November 27, 2021 Also if you can find longer belts, you can cut and shorten them by splicing. Link to comment Share on other sites More sharing options...
Yann Kastell Posted November 30, 2021 Author Share Posted November 30, 2021 Thank you very much everyone for your advice ! There's a car scrapyard nearby, I'll go visit them and ask about springs and coils. About cooling the steel into wood ash, can I use sand instead ; or perhaps it doesn't have the same properties ? I've got plenty of it, and was already using it to "store" hot pieces. Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 30, 2021 Share Posted November 30, 2021 Wood ash is a much slower cool than sand. Anyone having a bonfire in their backyard? Fireplace? Wood stove? Link to comment Share on other sites More sharing options...
Latticino Posted November 30, 2021 Share Posted November 30, 2021 Vermiculite from a garden store is another good source for a slow anneal. Honestly these days I don't do many full anneals, settling for a subcritical tempering at around 1200 deg. F to soften the steel instead. Of course I have a good 2 x 72 grinder and ceramic belts. If I were draw filing I'd do whatever I could to get a spherodizing anneal for the stock. Link to comment Share on other sites More sharing options...
Yann Kastell Posted March 29, 2022 Author Share Posted March 29, 2022 Sorry for necromancy. The project was finished 2 month ago, but I thought I'd update the post with the finished blade as I said I would, even though not many might care. With new belts purchased online, I managed to get a decent finish, but a keen eye will spot many flaws here. The badly forged bevels were saved with a guided file and a lot of elbow grease, but I didn't achieve a nice, distinctive ridge because of prior mistakes. I'm still satisfied with how it turned out nonetheless. The quenching was a failure because my forge is too small to heat the whole blade ; but I'm planning to craft a fireplace big enough specifically for heating with coal prior to the quenching. I couldn't find at all how to craft the pommel as on the original piece, but since time was lacking, I went for a (much) simpler design. I've barely sharpened the blade to a light edge ; I had purchased an old grinding stone but I hadn't restored it yet. The handle is a piece a hand-cut and hand-polished oak, treated with walnut ink and linseed oil. In the end, this isn't a fonctional blade at all. But it's decent for decoration. I gave up twice on it before learning something else while working on another knife and coming back to this one. This was too ambitious for my current skills and equipment ; a professional would be ashamed to craft such a piece, and yet I'm glad I did since it was insightful. Thank you sincereley to everyone sharing their experience on this forum and on the internet, allowing folks like me to learn "on their own". Link to comment Share on other sites More sharing options...
JHCC Posted March 29, 2022 Share Posted March 29, 2022 Nice to see the finished piece. For all its flaws, it's a LOT better than my first blade. (To be honest, though, that's a low bar; any knife that stays in one piece is a lot better than my first blade.) 2 hours ago, Yann Kastell said: The quenching was a failure because my forge is too small to heat the whole blade It's possible to get an even heat on a long blade in a short forge, so long as you keep it moving through the heat and pay close attention to where it's hotter or colder than it should be. 2 hours ago, Yann Kastell said: I couldn't find at all how to craft the pommel as on the original piece, but since time was lacking, I went for a (much) simpler design. You definitely want a thicker butt on the next blade. This design is basically for chopping and slashing, and a handle like this one that tapers down towards the pommel is going to fly out of the user's hand sooner or later. Make sure to keep us posted on the next blade! Link to comment Share on other sites More sharing options...
Gavin Bezer Posted May 31, 2023 Share Posted May 31, 2023 Why am I getting staining on my blades after the knife is finished and has been used in the kitchen Link to comment Share on other sites More sharing options...
Latticino Posted June 1, 2023 Share Posted June 1, 2023 Acids in the food reacting to the surface steel. Call it a patina and enjoy it. Look at most older carbon steel kitchen knives and you will see this. Many view a patina as a desirable thing. Link to comment Share on other sites More sharing options...
anvil Posted June 1, 2023 Share Posted June 1, 2023 I made a damascus blade once and cut tomatoes with it and "lost" my pattern to tomato patina,,, Link to comment Share on other sites More sharing options...
Frosty Posted June 1, 2023 Share Posted June 1, 2023 I sliced potatoes with the brand new Buck sheath knife Dad got me for Christmas on a boy Scout camp out and it still carries the stains. That would've been 1964, I was 12. I don't know what steel it is but it's ash gray and easily cut other knives. Back when I did things like that to show off I had a Buck. Frosty The Lucky. Link to comment Share on other sites More sharing options...
anvil Posted June 3, 2023 Share Posted June 3, 2023 Come to think of it, it might have been potatoes, not tomatoes. Details lost in the halls of time. ;) Link to comment Share on other sites More sharing options...
Frosty Posted June 3, 2023 Share Posted June 3, 2023 Oh tomatoes will etch a blade for sure, there's a reason professional chefs wipe their blades off constantly. Funny how some stuff pops out of that old age fog isn't it? But MAN that knife meant a lot to me and when the first time I used it for real left stains that wouldn't come off was and is memorable. At least I didn't try cutting a bolt with it, I was young and dumb but there were limits even a pre-teen wouldn't cross. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Please sign in to comment
