rdennett Posted January 24, 2020 Share Posted January 24, 2020 If you had to make a forge welded tube a la Wallace Gusler for a rifle barrel, by yourself and without a power hammer, how would you do it? The bit I can't figure out is how to insert a mandrel and make a weld without losing the heat. Also, does anyone know if there is a scarf and what it looks like? Thanks, Rob Link to comment Share on other sites More sharing options...
Steve Sells Posted January 24, 2020 Share Posted January 24, 2020 If you have to ask that question, then that barrel wont be safe to use for anything except looking at Link to comment Share on other sites More sharing options...
rdennett Posted January 24, 2020 Author Share Posted January 24, 2020 Ok, what would you do? Rob Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 24, 2020 Share Posted January 24, 2020 Apprentice to an expert and expect to spend a number of years learning the basics and then getting good at it. As I recall a pattern welding prodigy got around some of the issues by welding the PW over a monolithic core of good barrel steel and then boring it out. Link to comment Share on other sites More sharing options...
1forgeur Posted January 24, 2020 Share Posted January 24, 2020 I would check out a video titled "Colonial Gunsmith" on youtube Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 25, 2020 Share Posted January 25, 2020 First question are you wanting to form a muzzleloading/black powder barrel or a cartridge/smokeless powder barrel? If you are wanting a smokeless powder barrel, all bets are off. Bob Patrick did an article with three methods of forging a gun barrel in the August 2000 issue of Anvil Magazine. If you have a copy you are lucky because the magazine is out of print. But you can subscribe to the online version. Following his instructions and knowing the decades of blacksmithing under Bob's belt, I wouldn't hesitate to fire a gun built with one of his barrels. Link to comment Share on other sites More sharing options...
rdennett Posted January 25, 2020 Author Share Posted January 25, 2020 Black powder. To be clear, this isn't a project I am currently working on, it's just something on my bucket list. I am familiar with The Colonial Gunsmith, first seeing it in the early 80s, and where I first fell in love with blacksmithing. I finally got ahold of Foxfire 5, but haven't heard about that issue of Anvil. My question is how you would handle welding a barrel without a striker or power hammer. Does that article cover it? By the way, I would never get my face near a barrel that hadn't been proofed. Thanks, Rob Link to comment Share on other sites More sharing options...
Randy Griffin Posted January 25, 2020 Share Posted January 25, 2020 This is a really good video on barrel making. Link to comment Share on other sites More sharing options...
anvil Posted January 28, 2020 Share Posted January 28, 2020 A good site. hootalrifleshop Link to comment Share on other sites More sharing options...
jason0012 Posted August 8, 2020 Share Posted August 8, 2020 Bob was the Smith i have seen do this without a mandrel. My process, power hammer or hand, is as follows. Coil your skelp of 3/8×3/4 or so around a 1 inch or so mandrel. Coil the whole thing. Taper the ends so they lie nice and square. Starting at one end, weld first with an end bump and then across the face in a bottom swage or v block. I use the v block a lot. Rotate as you hammer in the direction of the coil. (So it twist tighter as you turn) by the time a 1 inch id coil is reduced to solid seams, it will be reduced enough to clean up to a .40-50 cal. Bob was quite specific, if you can still see the seam in the final forging, it likely has not welded... Link to comment Share on other sites More sharing options...
jason0012 Posted August 12, 2020 Share Posted August 12, 2020 I have found the article from anvil magazine on Bob Patrick, and can post it. Would that violate any rules? Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 12, 2020 Share Posted August 12, 2020 Do you have permission from the copyright owner(s)? Link to comment Share on other sites More sharing options...
jason0012 Posted August 12, 2020 Share Posted August 12, 2020 no, and no idea who they might be- that is why I asked. Link to comment Share on other sites More sharing options...
George N. M. Posted August 12, 2020 Share Posted August 12, 2020 Thomas and Jason: I'm not a patent/copyright specialist attorney but since Jason would not be gaining any monetary benefit and it would not harm the interests of the copyright holder it would likely be considered as falling under the "fair use doctrine." If the copyright holder could be identified, either the author or the magazine publisher, it would be a courtesy to contact them and ask permission even if it isn't strictly required. "By hammer and hand all arts do stand." Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 12, 2020 Share Posted August 12, 2020 Posting the complete article to me would seem to not come under fair use. Posting a link to the article placed online by the copyright holder should work if that is possible. I too am not trained in copyright law however. I would prefer not to involve this site in any legal hassles as they tend to be tedious and unpleasant. Link to comment Share on other sites More sharing options...
anvil Posted August 13, 2020 Share Posted August 13, 2020 I suggest you see if you can find "Journal of Historical Armsmaking Technology" vol 1-4. Published by Western Kentucky University and the NMLRA. It's a line by line, side by side translation of a Prussian publication circa 1750 from the armour at the Royal Potsdam Armoury. Many pics, very detailed on forging all musket parts including tooling, woodworking and much interesting info such as the swarf from where the swords etc were ground was forge welded together and then forged into heavy cavalry breastplates. Lest I forget, including bayonet making. A true gem. With the gunsmith of Williamsburg vid, it's truly a step by step walkthru of literally lock, stock, and barrel. Link to comment Share on other sites More sharing options...
Please sign in to comment
