WoodFireMetal Posted August 4, 2019 Share Posted August 4, 2019 I mostly like my dirtbox/brake rotor hybrid forge-on-wheels I recently built, but it’s a bear to try and lift it alone into my truck to take to occasional demonstrations. I’d like to lighten it up some and wondered if there is a plywood or drywall like sheeting that would be resistant to the heat coming from the rim of the brake rotor, any loose coke floating around. FYI, I don’t know welding yet, so that option is out. I’d like to remove the dirt, use a few firebricks to hold the rotor in place off the box’s wood floor, and have just enough bricks under the sheeting to keep it stable with coal/coke on top of it, flush with the rim of the rotor. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 4, 2019 Share Posted August 4, 2019 I don’t think I would try cement tile backer board. And I can’t say any ply wood would work either. I built a side blast forge that is a wooden box filed with brick and dry cat litter. I have also seen onebuilt with a steel plate for the bottom and loose brick. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 4, 2019 Share Posted August 4, 2019 its time to use sheet metal for the deck on the portable forge like the rest of us use Quote Link to comment Share on other sites More sharing options...
pnut Posted August 4, 2019 Share Posted August 4, 2019 Can you cut a round hole In a piece of sheet metal? If so cut the hole a bit smaller than the rotor so the rim of the rotor keeps it from slipping through the sheet metal. You could drill pilot holes around the edge of the sheet metal to secure it to the box. Pnut Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 4, 2019 Share Posted August 4, 2019 Use the top off of a top load washing machine. The lid will provide a wind break , and when done you just close it up and it keeps things covered. You can get washers and dryers for free and they have a lot of good sheet metal for projects. Quote Link to comment Share on other sites More sharing options...
WoodFireMetal Posted August 4, 2019 Author Share Posted August 4, 2019 2 hours ago, pnut said: Can you cut a round hole In a piece of sheet metal? If so cut the hole a bit smaller than the rotor so the rim of the rotor keeps it from slipping through the sheet metal. You could drill pilot holes around the edge of the sheet metal to secure it to the box. Pnut What would I cut it with? I have a hack saw, but it wouldn’t turn a round shape. I have a dremel with those EZ change-out cut-off discs. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 4, 2019 Share Posted August 4, 2019 Chisel and hammer, time to start thinking like a blacksmith ;-). Sharpen the chisel so it has a slight crescent shaped edge, it cuts oh so much beter. Be aware that many chiseles are all to soft and tho easy to sharpen they dull fast. Keep the back dressed. The back can be ground or if it has a long enugh handle you can forge the mushroom back before it gets to bad Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 4, 2019 Share Posted August 4, 2019 Do you have a cold chisel and a hammer? I have cut the shifter humps out of 4 speed cars in the wrecking yard with a hammer and chisel. Goes pretty quick with a good sharp chisel. I see Charles had the same idea at the same time I was typing. Jig saw, recip saw, torch, plasma cutter, grinder, ..... lots of options Quote Link to comment Share on other sites More sharing options...
arkie Posted August 4, 2019 Share Posted August 4, 2019 See if you can buy or borrow a substantial jig saw/sabre saw like a Milwaukee, DeWalt, Makita, Bosch, etc.... use HSS blades (high speed steel). I have cut circles in 1/4" mild steel plate that way. You may need to use a couple of blades, depending on length of cuts. The Dremel won't make it with the thin discs. Cold chisel, like others suggested, will work fine. Quote Link to comment Share on other sites More sharing options...
WoodFireMetal Posted August 6, 2019 Author Share Posted August 6, 2019 Touché, to the hammer and chisel comments :-) I’m a newbie, for those that don’t know yet. I haven’t had a need or project that requires cutting sheet metal yet, but I guess now is as good a time as any. The only chisels I own, so far, are small ones purchased from big box stores that I use to make veins in leaf keychains. I assume they are not intended for cold usage. I was given a coil spring as a gift. Would that be useful for making one? I believe Black Bear Forge has a video or 2 on making them so I’ll look into that, unless there are better video references to watch? What gauge sheet metal should I use as the dirt tray replacement? Is the big box store a reasonable place to buy some, or is it going to empty my wallet? The jig saws I own are also your average DIY quality, so I don’t know if that’s suitable for metal cutting. Quote Link to comment Share on other sites More sharing options...
Dasher Posted August 6, 2019 Share Posted August 6, 2019 To cut sheet metal, you just need to make a hacking knife out of whatever you have around, an old heavy,[ as in thick] knife, power hacksaw blade, even an old large flat screw driver, you just mount the sheet securely, and penetrate and cut the sheet along your line by striking the back of the knife with a lightish hammer, just like sawing but instead of going in and out, you just drive the knife along your marked line, you will be surprised how accurate you can get with care. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 6, 2019 Share Posted August 6, 2019 Like I mentioned above, pick up a junk washing machine and strip the outer casing off. They pop off after just a few screws. Lots of flat sheet for projects, and you can get a dead washer for free. Quote Link to comment Share on other sites More sharing options...
