ADHD-forge Posted July 20, 2019 Share Posted July 20, 2019 so a couple of weeks ago i made a skillet and now i would like to make a sauce pan to go with it. but i'm not quite shore how to go about it, i found that when you want to raise the edge the whole thing goes daddy wompus and flexes and moves all over the place and you don't know where to start first. seen as the pan would be about 8cm deep and have a bottom diameter of about 16cm. would i try and "roll" the edge over my stake or first make a depression with my hydraulic press and the finish it over the stake? i'm afraid the because of the high edge it will crumple. any thoughts, tips or reference material i should look in to ? thanks Quote Link to comment Share on other sites More sharing options...
Gazz Posted July 21, 2019 Share Posted July 21, 2019 I did some raising in school and that is the process you will need to use to make a sauce pan form. This video shows the the basic start of what you want to do. To make the sidewalls straight or 90 degrees to the bottom you will get and have to deal with a sort of a wavy or crenulated edge but this will work out into added height with more work over he stake; Quote Link to comment Share on other sites More sharing options...
Kuja_torra Posted July 22, 2019 Share Posted July 22, 2019 Just for reference here is a simple video on how a factory would go about making a pot. I would try to make forms like they have and use heat instead of brute force. Quote Link to comment Share on other sites More sharing options...
SFC Snuffy Posted July 23, 2019 Share Posted July 23, 2019 I've no experience in this, but a web search didn't show me much. If you're looking for a video of a comparable technique you might try armorers' videos of helmet-making. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 23, 2019 Share Posted July 23, 2019 The techniques are the same for sheet steel as for silver or tin. You'll need to crease the perimeter from the circle marking the bottom to the outside edge. Once creased you "Shrink" by driving the creases flat again, upsetting the material shrinking the radius and drawing the side up. It requires definition of the transition from bottom to side, it won't go where you want without direction. I didn't find anything about tools or technique in a quick search though the book, "Metal techniques For Craftsmen," by Oppi Untract isn't a detailed how to but it covers the very basics with photos and illustrations. Amazon has a copy now. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted July 23, 2019 Share Posted July 23, 2019 When you raise the sides you will have extra material that will need to be trimmed off. The technique I saw was to make circles about 1" apart and start in the center and work out over a stake. This was done cold. Quote Link to comment Share on other sites More sharing options...
John B Posted July 23, 2019 Share Posted July 23, 2019 Thickness of the material will have a bearing on what techniques to use, and a fair amount of annealing may be required, or do it hot. Similar method to your your skillet, just has higher sides. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2019 Share Posted July 24, 2019 Make a series of equally spaced creases/flutes and then working hot upset the flutes into the material next to it. Only heat the area you will be working to avoid scale losses. Repeat until madness takes it's toll. You will end up with a thicker edge than the original starting stock. I would suggest looking for raising information for jewelry making as it's a standard technique there. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted July 26, 2019 Share Posted July 26, 2019 This can be applied to any item of any size in use. The rim is thinned to keep weight down and also to keep the rim from getting to thick. Quote Link to comment Share on other sites More sharing options...
