RogerrogerD Posted January 18, 2019 Share Posted January 18, 2019 Yesterday I picked up this heavy old leg vise. £50 on ebay, along with a pillar drill press for another £20. I’ll do a seperate thread as I resrore that but first to the vise. Generally very good condition, nice straight jaws. A few signs of some odd welding done in the vicinity, but nothing too serious. Probably locked tight shut for 50 years plus, totally seized at the pivot joint. It came apart with a bit of patience, a swim overnight in wd40 magic juice, a spanner, a soft hammer, some wooden wedges and the application of some heat. Thomas Powers advised I may find some pitting and corrosion on the pivot joint cheeks, and indeed thats what I found. Strange. Pics below. Seemed to be the cause of the seizure. Next step will be wire wheeling the lot. With the spring being under compression, tight, for decades I was expecting to have lost some of its mojo, but it seems OK, time will tell when I put it all together again. If it needs a bit of a bend to give it its oomph back, I’m hoping I can achieve that then air cool it rather than have to do any complicated heat treatment. No sign of any makers mark yet. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 18, 2019 Share Posted January 18, 2019 Off to an excellent start. The screw looks good, how are the screw box threads? I bought my first post vise off eBay decades ago. Had to pay more in shipping than the vise cost. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 18, 2019 Author Share Posted January 18, 2019 I was lucky on ebay. Guy selling it was 25 minutes away. Threads on the screw box look fine at first glance, but I need to clean it out and shine a light in there. A little surprised no thrust washer, and on the box side there are the remains of a leather washer. We’ll see how it works when cleaned up and then if I need to, I’ll work a thrust washer out. A few interesting anomalies. 1. The spring bracket was encouraged to stay in place at the top of the leg by a strange bead of weld horizontally on both sides of the leg. The weld wasn't to the bracket just a raised lip on the leg, but held it up. Not great welding. Ground it off. 2. In the bottom picture in the post, showing the pitting on the pivot cheek, it looks like a crack running up, almost as if the leg part was welded originally to the cheek... maybe forge welded? Looks odd and I can’t work it out. Shouldnt be a problem, looks sturdy enough. 3. No makers mark at all...yet. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 18, 2019 Share Posted January 18, 2019 Definitely forge welded on. I smoothed the cheeks and packed grease in any voids to keep them from trapping water. (My outdoor vise had voids...) Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 18, 2019 Author Share Posted January 18, 2019 Ok I’ll follow that guidance, thanks. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 19, 2019 Author Share Posted January 19, 2019 spent the day wire wheeling it. Comes up nice, no makers mark. Now I have the pivot point cleaned up its apparent the cheeks are in matching halves, forged welded together and the two together then forge welded on the leg. Strange. You can see the join but it looks solid. It’ll need a new pivot bolt, and I was flat out of 3/4 inch bolts, so ordered some and they are on the way. Smallest component easily the most expensive. In the meantime, I put the parts together temporarily to test the spring. I was worried that 50 years plus of being clamped tight with the spring under tension would have eased it off. Amazingly it acts perfectly, no need to re-bend it. How remarkable is steel eh? All that potential energy locked in for decades and its still there, springing back into place. Sometimes we forget what remarkable material steel is. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 19, 2019 Share Posted January 19, 2019 Lots of old stuff show build up of wrought iron pieces to get the size/mass needed. I have a vise that shows 3 or 4 bars welded to get the pivot section for the moving jaw; but it's just in width not in thickness. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 21, 2019 Author Share Posted January 21, 2019 Rubbed down all parts with a home made mix of beeswax, BLO and turpentine. Fascinating examining the parts and working out how they were made especially the massive drift of both legs where the screw thread goes. Next step is to finish off the surface treatment. I’ll place all the parts around the edge of my coke forge after I next use it. The heat will warm up the metal and its coating, then cool slowly leaving a nice shiny finish. My hands smell of linseed and beeswax. No better aroma. New pivot bolt should arrive by post tomorrow and then I can put it all together and start thinking about the stand for it. I have a tree trunk in mind. Close-up of the thread, which looks immaculate. Quote Link to comment Share on other sites More sharing options...
stevomiller Posted January 22, 2019 Share Posted January 22, 2019 Yessir, that thread is in much better shape than many I’ve seen. I was lucky both of the ones I kept for myself were nice and sharp just like yours. You have a great vise there, congratulations (and nice restoration detail too). Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 22, 2019 Author Share Posted January 22, 2019 Curing the beeswax and linseed coating on a cooling forge. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 23, 2019 Author Share Posted January 23, 2019 And its back together... strangely it now won’t close tight... I’m having a think about why. Here it is in a temporary mount. My other vice, somewhat smaller, on the other side of the the trunk. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted January 23, 2019 Share Posted January 23, 2019 Could be how the spring is mounted. If mounted too low, as it closes it makes the spring flex longer and it could possibly wedge against the lower jaw. Just one possibility. Obstruction in the screw box? Wrong size pivot bolt? Could be several things. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 23, 2019 Share Posted January 23, 2019 To check the spring: knock out the wedge in the mounting bracket and see if it will close then. If so; lever the spring up a bit before reinserting the wedge. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 23, 2019 Author Share Posted January 23, 2019 i’ll try that, thanks TP. Quote Link to comment Share on other sites More sharing options...
Teddybo Posted January 23, 2019 Share Posted January 23, 2019 You sure it’s not a Peter Wright ? I’ve had issues where the screw box gets at a angle then hits the moving jaw or the sping isnt shaped to make it fit the part it wil be skidding up and Down and instead binds Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted January 24, 2019 Author Share Posted January 24, 2019 It could well be a Peter Wright. But no markings anywhere. Quote Link to comment Share on other sites More sharing options...
arftist Posted February 3, 2019 Share Posted February 3, 2019 Did you accidentally rearrange the thrust washers? Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted February 3, 2019 Author Share Posted February 3, 2019 It didnt have a thrust washer when I got it.... I found a modern one on line for just a few pounds that weirdly has the right dimensions. and its on order, but tbh I’m scratching my head. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 3, 2019 Share Posted February 3, 2019 So you've loosened the wedge and still wont close. Have you thoroughly checked there are no obstructions in the screwbox? Mouse could have hid a wallnut in there before assemby. :) And that without the front jaw,that it screws in past where it stops with the front jaw in the assembly? Also checked that the new pivot bolt is not possibly too large pinning the bottom to the other pivot block acting as a stop? There are only a hand full of things that could cause that issue. Quote Link to comment Share on other sites More sharing options...
David Thomas Posted February 4, 2019 Share Posted February 4, 2019 If the screw is the issue, you should be able to close the jaws by hand. If you can't. look to the checks at the pivot. A new bolt could have tighten things up to where the cheeks are pinching at the leg. Remove the screw and spring and see of the jaws can close completely to confirm. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted February 4, 2019 Author Share Posted February 4, 2019 Yep the jaws will close completely if I squeeze by hand so it must be the mouse’s walnut in the box... I’ll take a stiff bottle washer to it this afternoon. So I gave the screw box a thorough clean out, and regreased it lightly. Refitted, no different, still not quite closing. On a whim I then took it apart again and refitted it with the “key” on the screw box down rather then up...and guess what, it closes.... I can't think that there is any negative on which way up the screw box is fitted.. the space it slides through between each jaw is slit snd drifted and not precisely machined, and there’s space for the key either way. I didnt expect that. I dont recall which way up it was when I first got it, because I wasnt looking, and I cant make it out on the photos I took. Ah well... it works, and for the heck of it, I’ll try a cheap thrust bearing thats on its way. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted February 4, 2019 Share Posted February 4, 2019 Glad you got it figured out. Ugh, that issue briefly crossed my mind and I never wrote it out. Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted February 4, 2019 Author Share Posted February 4, 2019 (edited) So I think this will work without a thrust bearing or washer if it has to. But in an idle moment I measured up the dimensions for a thrust washer. Came to 45mm internal dia and 65mm external dia.(sorry, a Brit here working in metric). I could make a washer up easily enough I guess, but I fed those dimensions into ebay and amazon , just for the xxxx of it, in case I could get a washer cheap through amazon. Not surprisingly I drew a blank, I had assumed those dimensions for a 100 year old or more object would be esoteric. But, but...at the bottom of the page was offered a thrust bearing, of exactly those dimensions for the princely price of £4.55 (about $6). So for that price I ordered it... arrives from China shortly. How weird is that? Jeez, i would expect to pay twice thst for a simple washer of those dimensions. If I fit one of these (with a thickness of 14mm) the vice will close with the key up or down... not sure if the thrust bearing will cause the handle to flop about. We’ll see. I’ll report . Edited February 4, 2019 by Mod34 Edited for inappropriate language Quote Link to comment Share on other sites More sharing options...
RogerrogerD Posted February 6, 2019 Author Share Posted February 6, 2019 New thrust bearing from China arrived. Not bad for $6. Works a treat, but going to back it up with a washer with a bigger outer diameter (85mm) Quote Link to comment Share on other sites More sharing options...
David Thomas Posted February 6, 2019 Share Posted February 6, 2019 Didn't realize you were getting an actual bearing. The vise needs the friction of solid washers to keep the jaws from loosening under a load. The bearing removes that friction. You may notice the vise won't be able to keep a tight hold, especially while hammering on if you use a bearing. Quote Link to comment Share on other sites More sharing options...
