What do we know about Taps and Dies?
There was an article in Fine Woodworking magazine that discussed this, back in 1983.
  • Replies 61
  • Views 18.3k
I don't think my old issues go back that far, but I'll see what I can find online. It could be an interesting read. Thanks.
Al (Steamboat)
I thought this was taps and dies? Tangent woodworking comment mislead or did the train jump track?
2 hours ago, ThomasPowers said:
Do your OHJ go back to the 3 hole punched days?
 I started collecting Old House Journal maybe a year or two before I published an article in one of their 2013 issues. I do have some Fine Homebuilding issues that go back quite a bit further than that.
Hmmm. Taps and dies. That sounds familiar. :) Topics do tend to "evolve" around here...happens a lot. I'm perfectly happy going back to the taps and dies "thread" though.
Al (Steamboat)
On 11/2/2018 at 5:53 AM, Steamboat said:
The Japanese have a special name for this joint. Check this link: http://www.aisf.or.jp/~jaanus/deta/j/jigokuhozo.htm
very interesting, and reinforces the need for definitions. What pops into my mind for a blind tenon is a situation that the length of parent stock, think picket or stretcher with a tenon integral on each end cannot fit into the space. Thus, the solution is a blind tenon, a stud applied thru the top of the mortise and secured one way or another into a hole in the picket/stretcher. Then the "blind" tenon can be headed over and, in the case of a railing, the rivet head detail is not interrupted.  check out the joinery I used here. The tenons are not peened over. This is a roller for a stand. the roller is 3/4" round sleeved with 1" tubing. There is 1 forged tenon and 1 "blind" tenon on the other side. The roller assembly fits in easily and I do not have to stress the roller frame. because I use a "starting" tap, and a bottoming tap, the threaded stud is screwed in and fully bottoms out. Thus heading the tenons is quick and will last indefinitely, and the sleeve will be free to spin.
There may be other solutions to this problem, but I've not come across any better to date.
I've considered Thomas's solution of stock removal but in a small hole, a chisel won't work. And to wallow out with a drill bit would wallow out the top which adds far too many other unacceptable problems that must be delt with.
The use of a dremel type tool may work, but certainly would not be quicker than running a tap thru twice. And without a doubt the cost and longevity of two taps and and a tap wrench are far exceed clear of any power tool within my experience.
However, this thread has brought forth another viable option and that is a split stud and a wedge.
And that's exciting!
For what it's worth, I made a series of shop stands that are all hand forged with the joinery left obvious to show the "story", not to leave one wondering how it was done. Thus my tenons are left proud and my welds are obvious.
It is supposed to be about taps and dies -- hence the title of the thread.
The funny part is that a moderator just hit me with a "demerit" for spamming, yet here are all these people spamming away, cluttering up a thread with nonsensical comments that have absolutely nothing to do with the subject matter being discussed.  This is the kind of stuff that makes the search function here even less functional.
Since you all want to talk about woodworking on an ironworking forum, let's at least try to keep it within the of the subject being discussed in the thread.
Here's a very nice video on making wooden threads -- with information I'd never heard before.  Love the bubbles!
https://www.youtube.com/watch?v=nbY6El9Pzcs
If you want to talk about tenons in wood furniture, please feel free to do so in another thread.  If you're curious about how far back in time someone's magazine collection goes... again, feel free to start a line of discussion around magazine subscriptions.
Sorry, Vaughn. I have a 'tenon-cy' to get carried away sometimes. Getting back to the "threading thread," I have a few suggestions that I find useful:
First of all, I use thread cutting oil, which helps cut cleaner threads and makes the dies and taps last longer. It seems to help reduce the effort as well. I really can't say which cutting oil is "best," because I really don't know. I've used several different brands successfully. Just make sure that the cutting oil is recommended for your application and follow the instructions and safety guidelines.
While I'm threading a rod, about once every three or four new threads, I unscrew the die, brush off the swarf with an old toothbrush, and then screw the die back on and continue to cut more threads, repeating this until I'm finished. A little patience usually pays off. Preventing the swarf from building up will help make cleaner cuts and help prevent flakes from getting wedged between the die and the threads. I use a similar approach when using a tap to thread a hole. If it's a blind (closed) hole, you'll have to figure out how to get the swarf out after the tapping is done. I usually use a liquid aerosol cleaner with a long, thin plastic tube attachment. Be sure to follow the instructions and safety warnings when using aerosol cleaners and solvents. If you leave cutting oil in the hole it can affect torque readings,  threadlocker effectiveness, etc.
I'd like to echo Kozzy's comment about buying quality taps and dies. I don't have a specific brand to recommend, but at the minimum, get "high-speed steel" rather than "carbon steel." They're pricier, but in the long term they're more economical because when used properly, they should far outlast the cheaper ones. If you want even greater longevity and better threading characteristics, you could buy high-speed steel taps and dies with titanium nitride coating, which is especially recommended if you're threading stainless steel, which can be challenging to thread. Make sure that your cutting oil is recommended for stainless steel, and go slowly when threading stainless. It's still no cakewalk to thread stainless, but that should help. There are a lot of other coatings available, but titanium nitride is the most common.
If you want to thread a rod that has mill scale or forge scale on it, remove the scale right down to clean metal before threading. Your dies will last a lot longer and you'll get cleaner threads.
There are high-performance tap and die materials available, such as cobalt steel for threading hardened steel, and special taps and dies for threading titanium, etc., but for most purposes high-speed steel (preferably with a titanium nitride coating or similar) will work great and last a long time when treated nicely. Taps and dies for use with mills and lathes and other machinery bring up a whole new list of possible options too lengthy to mention here.
Also remember that there are different "chamfers" of taps, which refers to the number of tapered (or incomplete) threads at the starting end of the tap. The most typical are "taper" (or "starting"), "plug," and "bottoming," but there are other names and variations on these. The taper tap makes it easier to start tapping a hole and helps you align the tap within the hole. The plug tap is good for most general-purpose tapping, and the bottoming tap has full-diameter cutting threads just about all the way to the starting end or "front" of the tap, which lets you cut threads almost all the way to the bottom of a closed or "blind" hole. I think that a bottoming tap should only be used when necessary, since in my experience I think it produces a slightly rougher thread finish and requires more torque than the other chamfers. When I need to use a bottoming tap, I first tap the hole as far as I can with a plug tap and then just use the bottoming tap for cutting the last few threads at the bottom of the hole.
Getting your taps and dies started in correct alignment is perhaps the most challenging thing about threading. Some die handles (aka, wrenches) have built-in adjustable centering guides to help start the die straight. To make a simple jig for starting taps in holes, use your drill press to drill a nice straight hole through a 1"-thick piece of hardwood and clamp the wood flat on the surface of the object to be tapped, with the hole in the wood directly over the hole that you want to tap. The hole in the wood serves as a guide to start the tap straight. This general idea can sometimes be used in conjunction with a threading die as well. There are a LOT of other ways to get the tap or die started in proper alignment, but I'll leave those to your imagination.
I also recommend buying adjustable dies that allow you to make minor adjustments to the thread diameter to produce the kind of fit that you want in the female threads of a nut or threaded hole.
I could also mention that there are special taps and dies for reconditioning threads that are a bit rusty or slightly damaged. You may hear terms like chasing, repairing, rethreading, restoring, etc. and there are a lot of variants among these dies, which I won't go into here. Just remember that these can't perform miracles. If the threads are too damaged, replacement may be the best or safest option. Also, be SURE to clean debris out of the threads before using a thread reconditioning tap or die.
I'm sure I've forgotten to mention a few things, but that might give you a couple of useful ideas, and I hope that we're back on topic now.
Al (Steamboat)
On 10/27/2018 at 10:18 AM, VaughnT said:
Were tapered taps commonly used back in the day?  How rare were drills that punching the hole was the best option... yet they could make such nice tapered taps?
Or were the tapered taps used for something else entirely?
From the photo you included of the tapered taps, it appears that they are tapered continuously along the full length of the cutting threads. You might have a closer look to see if there might be a very short section at the large end of the threads where there is no taper. However, at this point I am assuming that they are tapered all the way, and if so, there are a number of possibilities as to their type and purpose, but I cannot give you a definitive answer.
I did find some information in Handbook of Small Tools, by Eric Oberg, 1908, which you might find useful. There is a 40-page chapter on "taper taps," which describes a number of tapered taps, such as:
  • "Pipe Taps"
  • "Taper Boiler Taps"
  • "Patch Bolt Taps"
  • "Mud and Wash Out Taps"
  • "Blacksmith's Taper taps"
  • (A few other types of tapered taps are described as well.)
It's possible that your taps don't specifically fit any of these categories, but it's a start. Here's the link:
https://books.google.com/books?id=nplKAAAAMAAJ&pg=PA257&lpg=PA257&dq=blacksmith+tapered+taps&source=bl&ots=S6IaJIlAwp&sig=yZ8Ho9E8xddezQvYpdTNP-Mszmc&hl=en&sa=X&ved=2ahUKEwjese-XtbzeAhWig-AKHchOAQQQ6AEwAXoECAgQAQ#v=onepage&q=taper taps in general&f=false
Al (Steamboat)
On ‎10‎/‎30‎/‎2018 at 3:04 AM, anvil said:
The other is bottoming taps. The "usual" kind you buy are starting taps and the working end is tapered.  They do not cut threads all the way to the bottom of a blind hole. Bottoming taps are flat cut and will cut threads to the bottom.
we call these plug taps and starter taps, we also have intermediate taps, plugs are for finishing a thread, starter taps are for starting, and intermediate taps are for rough cutting where it will be temporary. I absolutely hate taps and dies because I always learnt with plug taps and cheap dies that would not cut for the life of them.
Al, good info!  No harm meant with my earlier comments.  I appreciate the solid knowledge you're sharing, wood or metal! ;)
Got three complete tap sets in the mail the other day.  Minty fresh, never used Taper, Plug and Bottom for all three!  I'm still hunting for an old-school set of the 1/2-12BSW, but there's no hurry.  The hunt is half the fun -- even if it's for something I'll probably never use!
IMG_7030.thumb.JPG.29b3c5f1047a2ff9145548e7a279ecc3.JPGIMG_7032.thumb.JPG.d46026ed334e325e56c71fc39bf46e66.JPG
Already got a small project in mind that'll require my 3/8-16 tap and die.  Not sure it'll work, but I'm sure it'll be fun to try.
  • 3 weeks later...
I absolutely love these old-school educational videos.  I don't know who they got for narrating all these things, but that guy's voice takes me all the way back!  He did a lot of work for a lot of movies back in the day!
Greenfield Tap & Die
So if you every wanted to know something about taps and dies for threading.... sit back and enjoy twenty-six minutes of glorious 1950's cinematography!  :D
One thing that hasn’t been mentioned about Taps and Dies is that Taps is what the trumpeter plays after someone dies.
That was a very good introductory video, Vaughn. Good imagery, classic narration, and very clearly spoken, unlike a lot of newer videos. Pretty much all of the information is still applicable today, although there are some newer materials and surface treatments that have come along since then.
:rolleyes: Hmm.
Al (Steamboat)
Ain't that the truth.  I always wondered why they called them "gun" taps, and now I know.
That channel on YT has several nice tutorial movies on various things.  The piece on the Verniers and Micrometer was very educational, but a Steel Rule is about as far as I ever need to go in measuring things.  I use my steel rule and combination square all the time in the shop.  No soapstone or silver pencil for me!
How automatic threading heads work!
Me too. Can't beat a 6'metsl folder.
And my scribe trumps soapstone and silver pencil hands down.
Amen, Anvil.  Amen.
I never have understood the preference for the latter when you seem to spend so much time sharpening them only to wear them down to a nub on the very next mark you make.  :D
Yea, and that danged ole chalkstick gets eaten up by the chalk monster faster than a dog on a bone and became my most expensive consumable!!!  :)
Looking around, I found a supplier of taps and dies out of Poland. Most of the stuff I'm finding for a decent price is from china and I really don't like buying from them any more than I have to.
I need to get a 1/2-13 set just so I'll have them around if I need them.  Almost bought another tap/die set until I saw that it also had the 1/2-12BSW in it.
What I might do is buy the round dies that'll fit the stock I already have.  Then I can make up a wood box to hold them all pretty like.  I won't need many since I don't do a lot of threading.  But it's something to feed the addiction!
There is a lot of high-quality tooling coming out of Poland, and I've found that the pricing is generally pretty decent. Vaughn, I think that as you collect more taps and dies, you'll probably be using them more often. There is a tendency to use other means of fastening things when one doesn't have the capability to cut the thread sizes needed for specific jobs, but having a full set of taps and dies gives you more options.
As to soapstone markers, they aren't much good for precision work, but I often use a flat soapstone stick (in a holder) for markups for welding. Soapstone has a high melting point, and the whitish lines show up pretty well through a darkened welding lens. I frequently draw a soapstone line parallel to the planned weld so that I can see a bit farther ahead when laying a bead, with the line acting like a guide. It's also good for indicating start and stop points, stitch welds, plasma cutting guidelines, etc. One drawback in some situations is that the soapstone line rubs off easily, but that usually isn't a problem for me. On stainless, I often use a black marker instead.
Al (Steamboat)
Vaughn, I wouldn't touch tools from China. Not just because of current politics, but you get what you pay for.
Steamboat, soapstone in a fab shop is fine. However in an architectural blacksmith shop, chalk is fine for drawings on a table, but not near as precise as what's needed for layout.
When Building  mortise and tenon railings, you are either right on, or you are screwed.
In a fab shop, just get a bigger rod works.  ;)
I noted the smiley face, so I won't take that comment verbatim :), but seriously, even in a "fab shop," I would consider any work to be unacceptable that was cut or fitted so poorly that it would require extra weld fill to make up for the sloppiness...but that's just me. And there are other operations that take place in a fab shop that require higher levels of accuracy in measurements than most welding operations.
Otherwise, I agree with you.
I find that a line made by a sharpened flat soapstone stick can be "relatively" thin (say about 1/32" to 1/16" thick) which is certainly adequate to serve as a guideline for hand-held welding and plasma (or oxy) cutting operations. I have a pretty steady hand, but even when following a straightedge with my plasma cutter, I probably waver more than 1/16" at times.
Other fabbing operations, however, like shearing, for example, usually require more accuracy, in which case I use more accurate marking methods.
As I already alluded to, I would not attempt to use a soapstone stick for precise layout work. One needs something that will produce a very thin line and produce that line consistently. For more precision, I often use layout fluid and a diamond-tipped or carbide-tipped scribe. Having different colors of layout fluid is also recommended, since you can choose a color that contrasts best with the metal surface color. You can get an 8-ounce bottle of layout fluid for about 10 or 12 USD, which will make a lot of markups.
And of course, when going beyond what most people would consider the fab-up stage of a project and getting into subsequent high-precision operations, my machinist measuring tools come into play (micrometers, dial gauges, gauge blocks, digital readouts on my vertical mill and lathe, etc.). I don't have CNC on those machines, but since most of my projects are one-off personal projects, I don't consider it to be much of a handicap.
This is marginally off the taps-and-dies topic, but I guess it ties in insofar as marking accurately for drilling, tapping, etc.
Cheers,
Al (Steamboat)
Sounds like you have a lot of experience as a fabricator/welder and related fields.
Great input.  Thanks.
On 10/29/2018 at 3:59 PM, Kozzy said:
Finally, if buying new dies and taps, it REALLY pays to buy quality.
So any recommendations on on a good quality brand to look for. I tried researching reviews and whatnot, seems like just a bunch of lay persons saying yeah it worked once, or it did great in aluminum or plastic...
I initially bought a set of harbor freight stuff YEARS ago... made out of chineseium... and this was the first time I used them, broke 2 of the 1/4X20 taps making this:
went to Ace and got a single Irwin brand tap and it barely made it through. Pipe tap turned into a spiral tap by the time I was done... all BEFORE I had hardened the steel, I suppose I should have fully annealed it, but was just lazy I guess.
Anyways, this project was a blast, and I would like to do more like it in the future, but would need a real quality set.
My collection of taps and dies is such a mish-mash as far as manufacturers go that I really don't have any favorite maker that stands tall above the others. That reflects the way that I usually buy those tools, which I would call "semi-haphazard." I visit used tool stores, flea markets, pawn shops, garage sales, surplus outfits, etc., quite often, and if I run across tools that interest me, and if the price is right, I buy them.
Obviously, high-speed steel will outperform the cheaper carbon steel threading tools over time, and titanium nitride and other coatings will further enhance their performance (as will proper thread-cutting oil). And there are a number of exotic "cantaffordium" alloys out there as well. Good quality taps and dies are not cheap when new, but you might be surprised how easy it is to pick up good used ones for half a song and a dance.
Here's my simple approach: I keep a small 14X loupe (magnifier) in my truck's glove box, which I use to check the edges and surfaces of any kind of used or old-stock cutting tool that I'm considering. I avoid anything with dinged, chipped, or rounded/worn cutting edges. The magnifier also lets me have a better look at the tool's finish quality, because a high-quality finish "tends" to suggest better quality tools (not always, but often).
Buying good used threading dies is usually easier than buying good used taps, not because there are more dies around, but because the critical edges and surfaces of dies are more protected against dings from being stored improperly or from being dropped on hard surfaces. Taps tend to get banged up more because of their exposed critical areas. They might look OK at a glance, but often a magnified view will show small, but significant defects. I've gotten a bunch of very nice taps and dies for a few bucks each, and sometimes cheaper. One minor problem is that when I run across some interesting tools I can't always remember what size(s) I may have been looking for, so I often end up with duplicates. A notebook would be a good idea.
If you need a particular size right away and can't wait, at least splurge for a high-speed steel tool and threading oil, and then build up the rest of your collection over time. It won't take long before you have a massive set of these things. Just remember to store them with some protection around them.
Glad to be of some service. As to experience, I had a few years of professional fabrication and machine shop experience back in my college days, but no matter what various paths my career may have followed over the decades, I've always enjoyed designing, building, restoring, or modifying things for all of my adult life and most of my misspent youth. I'm also a lifelong tool junkie.
Al (Steamboat)
