April 28, 200818 yr Hey everyone who reads this, I am new here. I am also new to the art of blacksmithing, and the basics of metallurgy. Though I am no stranger to manipulating things with my hands, I have a good head start there. I could use any experienced forger
April 28, 200818 yr top of page, click on blueprints, use search feature, tie rope to ankle so you can find your way back out
April 28, 200818 yr Gas or solid fuel (coal, charcoal)? Solid fuel is very simple to build, gas has less of a learning curve to learn fire management. ron
April 28, 200818 yr Author Well... That depends. I would assume the solid fire would be easier to maintain, plus blowing the bellows gives undying satisfaction. Do you know where I could get a solid fuel forge? Or I've seen how simple they can be, I assume I could just build one.
April 28, 200818 yr Go to IForgeIron.com > Getting Started. IForgeIron.com > Lessons in Metalworking > Blacksmithing. Both links will provide you with information on building forges. Irnsrgn is right, tie a rope to your foot before clicking on Blueprints. (grin)
April 28, 200818 yr that is the classic question to which the answer is: learn the basics first, start at the beginner's section and proceed from there.
April 28, 200818 yr Check out the 55 Forge in the Blueprint section. It is a great way to get started and takes little if no funds to build.
April 28, 200818 yr Well... That depends. I would assume the solid fire would be easier to maintain, plus blowing the bellows gives undying satisfaction. Do you know where I could get a solid fuel forge? Or I've seen how simple they can be, I assume I could just build one. easyest fire is propane ...once its going you dont need to do much with it ...where in arizona are you? there is a arizona chapter of abana.... there are a few smiths around here ..If your close to apache junction stop by sometime.... Ime setup in the superstition mountian museum and am there tues - sat 10-4 for another month or so then I head north to (relitively) cooler climate..
April 28, 200818 yr I have to imagine that bellows lose the "undying" appeal after a while. Running a hammer for long hours is work enough.
April 28, 200818 yr A forge really is as simple a task as you can imagine. Look at a few pictures and make one. You really can't go wrong.
April 28, 200818 yr Well... That depends. I would assume the solid fire would be easier to maintain, plus blowing the bellows gives undying satisfaction. Do you know where I could get a solid fuel forge? Or I've seen how simple they can be, I assume I could just build one. Heres how i built my forge coal forge construction *UNDER CONSTRUCTION* I got less than 50 $$ wrapped up in it including firebrick and 200# of coal
April 28, 200818 yr Please use caution when cutting into any closed container. You do not know what was in it before, and even dust can be explosive under the right conditions.
April 28, 200818 yr Author Wow, than you all for the quick replies! I will definitely check all your suggestions out.
April 28, 200818 yr I would like to second the suggestion that you look up the local ABANA chapter. Meetings are free and open and will really speed up your learning as well as let you see other set-ups and how other folks do stuff and give you a place to ask where to find stuff locally.Blacksmithing Organization Web Sites : Blacksmith Group Locations is a good place to start to look for one. I'm sorry you missed the AZ/NM Hammer-In in Feb, (I missed it too as I brought my forge to the SCA's Estrella War near Florence Junction AZ).
April 28, 200818 yr Yesterday, 09:48 PM to Today, 11:24 AM with 12 replies within 26 hours. GS0003 Blacksmithing Groups This is another source for blacksmithing groups in your area.
April 28, 200818 yr Braghtworst, I started out with a brake drum forge. I paid $80.00 to get a stand built at a welding shop, because, at the time, we didn't own a welder. I got the brake drum from a junk yard for nothing. I used my brake drum forge for over a year at an average of 8 hours a week, and I could burn just about any size steel you could put in it. It is still highly serviceable. You can usually get scrap steel from a steel yard for very little cost, and if you have a welder, you could build a brake drum forge for under $40.00. I prefer coal to propane because of the traditional aspect. I also like turning the blower; electric blowers aren't for me. Good luck. The kidsmith, Dave Custer "It's not the fact that you're dead that counts but only how did you die."WELCOME TO CUSTER FAMILY FARM!
April 29, 200818 yr Author I was thinking of just making a forge/kiln out of an igloo-style brick creation mounted on layers of cynderblock. Do you think that will work well? Though that's only by comparison... I'm not looking to do professional work, I just want to make some metal hot and pound on it. From that armature perspective, my search criteria wideness considerably. Is there some state-wide blacksmith second-hand trade store chain? Besides the kiln, I need a good hammer, anvil and tongs to get started, and I have no idea where to look. I was thinking a horseshoeing depot; they use blacksmith tools a lot.
April 29, 200818 yr Author Braghtworst, I started out with a brake drum forge. I paid $80.00 to get a stand built at a welding shop, because, at the time, we didn't own a welder. I got the brake drum from a junk yard for nothing. I used my brake drum forge for over a year at an average of 8 hours a week, and I could burn just about any size steel you could put in it. It is still highly serviceable. You can usually get scrap steel from a steel yard for very little cost, and if you have a welder, you could build a brake drum forge for under $40.00. I prefer coal to propane because of the traditional aspect. I also like turning the blower; electric blowers aren't for me. Good luck. The kidsmith, Dave Custer I've heard of people using simple frying pans and filling it with a special kind of cement, and having an 'open casket' (or whatever you call it) forge. I've seen lots of stuff like that on Youtube, and they can make good steel red-hot. Thanks for all the help everyone! It's great to have experienced advice.
April 29, 200818 yr I built mine from the bottom of a steel barrel. Lined the bottom with clay and made the box with fire brick. I made my own tuyere from threaded pipe and fabricated a counter weight ash dump onthe bottom. I have about $18 in it. I already had the stock for the stand, etc..
April 29, 200818 yr The forge I'm using right now is the center from an old chopper box wheel with a two inch strip of 1/8 inch steel wrapped around it. A few pieces of cast off plumbing and a hand cranked blower. Works great. Finnr
April 29, 200818 yr i suggest making one i used a old wheel barrel some fireplace bricks a bit of scrap pipe from a muffler shop and a hairdryer and it works like a charm
