April 10, 200818 yr I'm wanting to set up a shop in my neighborhood and, of coarse need to keep the noise down. I've got about 3/4 of an acre to play with. I'm already in contact with a sound insulation company and think that the only problem I'll have is the banging of my power hammer. If I were to pour a seperate, 3" deep slab, would that help? What about hard bolting a 4"-6" thick base plate to the existing power hammer base to increase the mass under the ram? Any suggestions or ideas would be really appreciated. thanks
April 10, 200818 yr Probably the biggest thing to check out would be the local ordinances regarding "quiet times"..... Many areas have specific hours they REALLY enforce the laws.... At our current house, one of the neighbors does motorcycle repair/customization out of his garage (or runs a chop-shop, not sure which!), and ALWAYS shuts down by 10 PM.....
April 10, 200818 yr How thick is your existing power hammer base? And what size and type of power hammer are we talking about? Are you in the middle of the city, or in more of an out of town setting? I live on the edge of Las Cruces NM and have a 155 pound Big Blu, a KA-75, and a 25 pound Little Giant planted on the corner of my 1.2 acre lot. I have learned that there is no stopping the noise from the 155# hammer. It even shakes things in my house which is 100 feet away! The KA-75 is not as bad, but is still clearly audible in the house (or so my wife says). The Little giant is not so bad, especialy if I am using the drawing side of the combodies at anything under full throttle. It dose get loud if I switch to the flat side of the combo dies, but the slab under the Little Giant is 16" thick 29" wide and 53' deep, so there is a bunch of mass under the hammer to help soak up the hit. Im with MooseRidge on this. I don't worry about the sound, but I am sure to stop running the power hammers after 8:30 or 9 out of respect for the neighbors (and local law enforcement).
April 10, 200818 yr also how are your neibors??? if your reasonable on your hours and are nice its usualy not a problem in my opinion.I had a 50 lb little giant that sat within 2 ft of property line the neabors garage was 7 ft away! It was a attached garage and no complaints in fact I asked if it bothered him and he said "what hammer?" he had a garage band that would practice on weekends tho so he might not hear so good anymore!! The secret I think is be concencious and work reasonable hours ..good luck!
April 10, 200818 yr Soon as you open the doors/windows for ventilation most sound insulation for wall and ceilings is useless. Isolated mass for the hammer foundation will help.
April 10, 200818 yr I'm wanting to set up a shop in my neighborhood and, of coarse need to keep the noise down. I'm facing the same situation at the moment. I'm planning to build a smally hobby shop next summer and I'd like to get power hammer as well (see Russian hammer thread). There are two different things you are dealing with a power hammer: noise and vibration. Neither of the two will make the neighbours happy. To kill (or at least reduce) the the vibration I'm planning to make a 2 cubic meter (roughly about 2 cubic yards) concrete inertia block under the hammer. The block should be isolated from the floor but also from the ground. I'll probably use EPS frost isolation plates for that. Noise is a bit trickier. As noted once you open a door or window the noise will get out. And even if you keep them shut you will still have a chimney. Anyway, I will try to make the walls as silent as resonable possible. I'll probably go for a double wall construction with triple gyproc sheeting on both sides and about 15-20 cm (6-8 inc) insulated air space between them. That should theoretically give a 40 db noise reduction even at 30 Hz (and better above that).
April 10, 200818 yr A row of trees between you and then neighbor will stop a lot of noise, as will a solid fence. You may want to look at the ground conditions where the hammer is located. Loose ground will absorb the vibrations, where rock will rattle the neighbors teeth. Water levels in the ground may be a consideration.
April 10, 200818 yr Put a layer of sand and gravel in the hole before pouring the base and use that compressed foam insulation on the sides of the hole, making sure you put at least 2 thicknesses of concrete expansion joint stuff between your existing floor and the hammer base. Also put 2 layers of soft 2by lumber between the concrete base and the hammer, one laid longways, the other crossways and bolt the hammer to the slab with some valve springs from a big diesel engine between the hammer base and the anchorr nuts. Use self locking nuts . Remember the ceiling, a good noise reducer used in some plants that have large stamping equip and hammers is they hang cloth banners from the ceiling with a weighted bottom in a random pattern thruout the building. Noise is vibrations that move thru the air and bounce off of flat hard surfaces, or resonate thru them. Inside sheeting with lots of holes will stop most of it. You might try pegboard fastened to firring strips attached to your regular walls. 2 by 6 walls with fiberglass insulation will also hinder noise transfer thru your walls and depending on the size of your shop a window airconditioner will keep it fairly cool.
April 4, 201115 yr Towards figuring noise levels surrounding a blacksmith shop, does anyone have some decibel ratings for various power hammers? A chart would be ideal, but a few responses including size/type of your hammer and decibels (at least an estimate -- here's some info for comparison: http://www.gcaudio.com/resources/howtos/loudness.html) would be better than nothing. This could help those of us who are planning shops. Obviously, dB rating is only the one parameter of importance when planning a shop, but there doesn't seem to be much info available on this.
April 4, 201115 yr ... If I were to pour a seperate, 3" deep slab, would that help? What about hard bolting a 4"-6" thick base plate to the existing power hammer base to increase the mass under the ram? Any suggestions or ideas would be really appreciated. thanks pouring only 3 inches is a waste of your time as a minimum of 4 inches is required for any concrete, even a side walk is 4 inches, for a hammer it will be gravel in short time. think how many feet deep.
April 4, 201115 yr Been about *3* years since the question was asked perhaps asking what he did and how it worked would be appropriate.
April 22, 201115 yr Posted 11 March 2011 - 08:32 PM first off health and safety blah blah blah certain ranges of vibrations over extended time periods is not good fr your health! yes even small ones O.H.S 3rd edition. should be on net some where. in order to suppress vibrations, installations should be deep and massive foundations laid below the foundations of the building separated from all structural components. so mount your hammer on a suitably sized and reinforced concrete foundation and anti vibration mat. mat must go between hammer and foundation and base so b loads of concrete boys the pit should be a aprox 8" larger than the foundation block. the walls and floor of the pit should be sufficiently thick and reinforced to be strong enough to cope with the dead weight plus live loads the base mat needs to be rated at the weight of block + hammer. well it's a very cut down version but I hope it helps. you can also cast in hold down bolts. the block should be cast out of pit (and a tip cast in lifting hooks) as ropes are hard to get out under a block that weighs 700 kgs + Hope helps
April 22, 201115 yr Towards figuring noise levels surrounding a blacksmith shop, does anyone have some decibel ratings for various power hammers? A chart would be ideal, but a few responses including size/type of your hammer and decibels (at least an estimate -- here's some info for comparison: http://www.gcaudio.com/resources/howtos/loudness.html) would be better than nothing. This could help those of us who are planning shops. Obviously, dB rating is only the one parameter of importance when planning a shop, but there doesn't seem to be much info available on this. I dont mean to sound as sarcastic as I probably will but... Really? I mean a powerhammer of any size produces noise and of course most bigger ones are going to produce more... Ive been told that you can feel my 3B hit a 100 yards away in school by my shop, but it cant be heard at that distance.. my feeling is that info is not available because noise is not a consideration when buying a powerhammer from a commercial standpoint and they are not really marketed to hobby/personal users (with the exception of maybe the big blu and they are pretty quite as far as hammers go) I think you are going to have a real hard time finding any data on noise levels and no such thing as a chart unless some end user has taken on the task out of personal interest...
April 22, 201115 yr Large hammers tend to go into places where they may be one of the *quieter* tools around!
