Tin Roofing
Hello I recently aqquired some small pieces of tin roofing and I was wondering what I could use them for, I also would like knowing what the dangers are of using it if there are any thank you very much in advance
19 minutes ago, ThomasPowers said:
What type of "tin roofing"?
tbh idk if I understand you question, al I know is it is the thin dull gray tin roofing that has the raised folds to let water drain off
A lot of people call various metal roofing "tin" when in reality, it is not made of the actual metal tin. A lot of the stuff is actually steel or aluminum.
Are you sure this is actually tin? How malleable is it? Does a magnet stick to it? Try melting a little piece of it. Steel, aluminum, and tin all have WAY different melting points, so you should be able to tell with a fair degree of certainty that way.
well I know it isn't aluminum cause it has rust in spots and I haven't tried the magnet or the melting, how will I know if it is tin and not steel?
If it's truly tin, a magnet won't stick. However, it's probably galvanized steel and therefore should NOT be used for anything involving significant heat.
If it has rust (red iron oxide, Fe2O3) then it is likely steel, or at least contains a decent amount of iron.
If its a dull grey, its likely galvanized. Do not attempt to melt it, zinc is bad bad bad.
I wouldnt even bother with the magnet either. If it has enough iron to create rust, it will be magnetic.
I'm assuming you mean corrugated roofing... but there are other forming patterns that might work for some things and not others.  In all cases, if it was galvanized (which is likely) put an exclamation point or three behind that "...Bad bad bad." mentioned above when speaking of heating it.
I'd save such a thing for alternative projects rather than smithing.  Here are a couple of examples of planters.
29a807fd626ed79e08e12eeb3cbb329b--corrug943f78be8ff5578abc8b4468dafc7024--cement
Tern Metal Roofs, Propanel roofs, corrugated metal roofs; I've heard them all called "tin". so is it  UUUUUUUUUU or U------------U--------U-----------U or |__________________|_________________|  ?
Basically any of them I have not used for smithing.  I did used some strips when building a bloomery once to hold the outside together while it dried.
My shop uses pro-panel as that was what was free but it's all full sized pieces.
Use it for bird house roofing for rustic birdhouses and fund your "take over the world" process by selling them.
haha lol I can see it now after I take over the world I can write a book
Steps to World Domination
Get metal roofing
Make Bird houses from said roofing
Sell bird house
fund world takeover
There is more than one way to become the Evil Galactic Overlord---or to fund your forging equipment....
BOW DOWN TO MEEEEEEEEEEE FEAR MY BIRD HOUSE BUILDING PROWERSSSSSSSSSSS!!!!!!!!!!!!!!
I'm sorry but I know several Birdhouse Building Powers! (check my name again)
Lol I know that's your name lol, hey, world domination partners?
I'd use it for roofing/siding on a shop or overhang.... Just saying. Other creative ideas are great but I'd want to add some space to work.
I have enough space for now at least, (my workspace for everything except grinding is an outdo overhang that is 23 feet lengthwise and 12 feet wide and both of the 12 foot wide sections are open and 1 of the 23 foot wide sections is open so as faras space is concerned I'm good already,
You'll Never hear that from me lol.
lol obviously you know what I mean lol, heck id love to have an indoor workshop that is 2400 sqaure feet that opens up to an outdoor overhang shelter that's 1000 square feet and has a roof over everything but it wont happen anytime soon sadly
Me either! I didn't even know that was possible. LOL!
again I would love more space but let me rephrase it, if i claim more of my dads garage and yard he would go crazy lol
We understand. :lol: we'd just never say such a thing. One day.....
yup don't you just love those 2 word, one day, one day ill make a living doing this one day ill have a bigger shop ect.
Do an image search for "corrogated panel art projects", and let your bootstrap business empire begin!
