May 19, 201610 yr I have a Norton #6 coming in and I have to build a bench for it in the next few days. I would greatly appreciate seeing what others have done so post some photos. Thanks
May 20, 201610 yr Here's a picture on my #4 just after I refurbished it. A #6 might be to big to go on a table with wheels like mine.
May 20, 201610 yr Author Nice. I have 4 36" 6"x 6"x 3/8" square tube drops from a project a while back that would be perfect for legs. I agree about the wheels. Yours is a beauty.
May 20, 201610 yr Greetings Jake,/ Lawn Jockey Super nice restoration., Now lots of tools to make.. It's cool to use your fly press to make tools for your press.. You will find the wheels are great for transport but you will have to anchor it to the floor or the wall.. Lots of energy ! Forge on and make beautiful things Jim
May 31, 201610 yr The table was picked up at an old Southwestern Bell surplus sell in Dallas for $250.00 if I remember right. It was a working pallet jack that moved up to ten thousand lb reels of telephone cable in the factory in St Louis. When I was done with making a cable reel trailer that was a self loader I had this chunk of iron left over. It became a catchall. Any flat surface 28" X 46" around me becomes a catchall. The deck was machined 1 1/2" plate with 1" X 2" bracing a hundred percent welded underneath. 800lbs of great table when things need to be shaped with hammers, leverage, and heat. It is the perfect base for the P-5 from Kane and Sons.
June 2, 201610 yr Author I have table envy. I got a 3'x4' piece of 1/2 plate for my top. The legs are 6"x6"x3/8" square tube. Additional bracing is 2"x2"x1/4" angle. I assembled it upside down so tomorrow I will flip it over with the loader and weld the few spots that are better accessed from above. Then it is time to drill some holes. Then it is fun time getting it in my temporary shop and even funner (I will always be grateful to W for increasing my vocabulary) will be getting the press on top of the table. I haven't measured it yet but I believe if I take the roll bar off the tractor I can get everything in place using the forklift tines on the loader bucket. If that doesn't work I will have to get creative.
June 2, 201610 yr Author I got it in the temporary shop using the tractor. As expected I had to remove the roll bar to get the tractor to fit. Excuse the mess, we were just stuffing things from one side to the other trying to get it in. I will work on bolting it down tomorrow and then setting up a plate for tooling over the weekend.
June 2, 201610 yr What is the height of the table of the fly press before adding an additional tooling plate? I'm guessing 36-40"?
June 2, 201610 yr Author The table top is currently 29 1/2" but will be 30" when the pads under the legs are installed. The base of the press is 4" thick. So that will be 34". The tooling plate will be 1/2" thick.
June 2, 201610 yr You may want to put a hole through the plate before securing flypress to it so any bits/slugs that go through the centre hole (particularly if punching) do not build up and cause problems,
June 3, 201610 yr 2 hours ago, John B said: You may want to put a hole through the plate before securing flypress to it so any bits/slugs that go through the centre hole (particularly if punching) do not build up and cause problems, Uh, great idea. I had a punch fall into the hole when changing it out and it took some real work to get it out. I barely fit going in and didn't want to fit coming out. I was ready to get the tractor to lift the press when I tried one more time with the .035 mig wire noose with success.
June 3, 201610 yr Author At 850 pounds I don't want to lift it any more than I have to. How are you guys fastening the tool plate? I have been thinking about two different approaches. The first is to get some large flathead machine screws, counter sink them and sleeve them so as to fit the t slot snugly. Then for the nuts make something up like a unistrut nut. The other thought is to use large allen screws. I would drill the plate with two holes large enough to clear the screw heads. Then I would plug weld a steel strip the width ot the t slot across the plate underside. Then drill clearance holes for the allen screws. Again, make some nuts up like unistrut nuts. There are several variations of the two approaches.
June 3, 201610 yr I remember moving into my shop out here by chaining the pallets to the trailer hitch of my pickup and pulling them across the desert and into the shop one by one. Luckily I could still drive out the other end at that point...My screwpress is on the factory table and that is bolted to 4"x4" skids with the ends trimmed to make runners. (and that is currently on round stock rollers. Doesn't move much in use, surprisingly.)
June 3, 201610 yr 8 hours ago, LawnJockey said: How are you guys fastening the tool plate? I have been thinking about two different approaches. The first is to get some large flathead machine screws, counter sink them and sleeve them so as to fit the t slot snugly. Then for the nuts make something up like a unistrut nut. The other thought is to use large allen screws. I would drill the plate with two holes large enough to clear the screw heads. Then I would plug weld a steel strip the width ot the t slot across the plate underside. Then drill clearance holes for the allen screws. Again, make some nuts up like unistrut nuts. There are several variations of the two approaches. I used strips of steel the width of the T slot and as thick as would fit and move smoothly in and out, by a couple of inches long, drilled and tapped them for screwthreaded rod, and had various lengths of said rod for different tooling, Cheap version of T nuts and studs, you can use more to set up length stops etc or add extra clamps, you will need nuts for the threaded rod
June 3, 201610 yr Author Great minds think alike. The upper portion of the T slot is a little over 3/4" the lower portion (The top to the T) is 1 1/2". I am going to weld two pieces of 3/4 square bar together in a cross. One piece will be 1 1/2" long and the other maybe 3". Then I will drill and tap them where they cross. Simple almost instant T nuts. My main concern it that I may knock the tooling plate out of alignment when loading heavier pieces and thus there could be some troublesome variation, like with railing parts. If the T nuts alone don't make it stout enough I can always clamp on additional 3/4 material to the bottom of the plate, remove the plate and weld them on on the ends.
June 23, 201610 yr Made mine with 3" thick-wall tubing legs and I-beam top frame. 1/2" plate top with tapped holes for jigs - haven't seemed to use any of them so far. I left a wide hole under the center and added an adjustable platform underneath to use it as a traditional press. Has been great for pressing hammer handles, bearings, etc.
March 7, 20179 yr I got the stand together with the press. The stand is made out of flimsy angle iron that I reinforce a bit with flat and square stock. It is bolted to the concrete. I made the stand top out of wood because I had no money to buy a metal plate. The "fly wheel" bar of this press is 1.5 metres long. Stand metal frame is 90 cm tall x 90 cm long x 56 cm wide. The stand top was made with 5 cm thick boards I had available. Since I am a small guy (only 1,60 m tall) I am ok with the press height. But my sons are 1.82 m tall and have problems with the height of the weights (that I am changing now to lead weights to make them a bit more compact). If I knew that today, I would have added 10 cm more to the total stand height.
