Posted
A guy I worked with at the shop, grew up in Pennsylvania and worked the oil fields as a welder, he would repair grader blades quite a lot. They get hardfaced so cutting them apart is a torch or plasma cutter job. They are also going to be wearing on grinding medium a lot more than a mild steel and just chew up any kind of cold saw or bandsaw blade.
I would guess the procedure to be disassembly into a workable size by torch, forge and hammer work as close as possible followed by grinding and re-tempering.
Posted
thanks, from the pics I saw it looked like they welded the lower one to a hardy, and then made a bolt arragment to form a shear, with a handle. The book said he could cut 1/2" hot with just the lever action, and would use a hammer if he needed more.
  • 6 months later...
Posted
I saw someone in my local club (New York State Designer Blacksmiths Assn) use Grader Blade and made a shear much like the "tailgate shear" that Centaur sells in its catalog. Check out the pic in the catalog for details. 3 slots cut in each half of the shear. 1/4, 1/2, 5/8 or whatever. a twist or possibly a nudge with your GP hammer and it shears off like butter.
I'm gonna fabricate one as soon as I can nail down a free piece of grader blade.
Bill
Posted
I have a couple pieces of cutting edge that I have been thinking about using for a shear one of these days so I would be really interested to see what you make, so please post pics of it and let us know how it works out.
Thanks,
welder19
Posted
Bill
Visit your local state highways shop. Bring a box of donuts and ask if you can have a worn blade. Talk to one of the mechanics of operators, not the front office.
Frosty (AK Dot retired) :cool:
Posted
Frosty, you forgot the "bring a big truck" part.
I once had a small welding company near my house&shop and If I wandered over late on a Friday with a project and a cold sixpack, the *boss* would come out and help get it done for me.
At the ornamental iron fab shop near where I worked I used to have free access to their scrap dumpster; I always made the secretary a hand forged trinket; spent time talking with the fab crew, etc. Used to take home several hundred pounds of drops and share them with the local smithing club.
Being nice and *asking* works!
Posted
If I need that much, I convince the foreman stuck with the scrap run to drop it at my place.
Being nice, which includes being considerate of their time and not bothering them if they're busy, does in deed work.
Telling a shop foreman you're a blacksmith and are going to make COOL things from it when he wonders why in the WORLD you want those little pieces of scrap is good PR. Especially if you bring him/er one of those cool things later on.
You can get good mileage from the mystique of a blacksmith just like I do being an Alaskan when I'm in the lower 48. Of course I enthusiastically double up on the mystique being an Alaskan blacksmith.
Then again I'm shameless.
Frosty
Posted
Frosty,
The donuts thing never occurred to me. At least not in this instance. I'll give it a shot. One of those shears would make a fine addition to my shop.
Bill
Posted
Another source of metal I find is a couple guys who run landscaping and mowing services. Each year I get a good sized box of high quality mower blades in a variety of sizes along with wore or broken tooth shanks from grader boxes along with rake tines and who knows what else. All just for asking and the occasional forged item.
I never thought of donuts for the highway crew, know a lot of other state paid employees who can be bought by donuts though!!!;)
Posted
Naw. The forge cart belongs to Lincoln Log Cabin State Historic Site. A couple of other fellows out there built it. Now, I'm the only smith that they have. It was built from plans for a Rev. War artillery cart forge. They modified it a little. But it works great and sure fun to work from.
  • 9 years later...
Posted
Sorry to disappoint your but grader blade is abrasion and impact resistant which makes it almost useless for anything but grader blades and skid shoes. Do a search on "Vascowear" for the particulars on a common brand. What makes it abrasion resistant is a significan't % of tungsten carbide granules held in a high carbon steel matrix. It eats grinders and belts like candy, you need blue wheels to do anything to it.
It doesn't hand forge worth spit and I've never heard of anyone getting anywhere.
Don't worry most smiths I know who had access to grader blade have some around, I do. It just seems like too good to let go to the scrappers but that's the best place for it.
Posted
The square holes make for nice adjunct hardy holes.  I even found one ancient one that was the same size holes as my large anvil!  Grader blade was also considered a great material for torch cutting scrolling forks from---the handled ones at one time.
Posted
Ended up using a cutting torch at work to cut off enough for a hot guillotine, going to finish that today. Also cutting out a cutter to fit in the hardy hole and a bending fork as suggested. Seems that if it's tough and abrasion resistant it should make great hardy tools.
Posted
At the community college I learned smithing at they used some as the top surface on some home built anvils that were being made. We had a steady supply of scrap 1.5"-2" thick plates from Kaiser Steel that they sold for ten cents a pound. They had an anvil pattern set up in the torch and when all of the parts were cut, you just stacked and welded with the big innershield welder.
Posted
Sure will and it'll teach you to NOT part the stock on the hardy because a grader blade hardy will put serious cuts in your hammer face. Get the stock thin on the hardy then bend it back and forth to part it. We all miss though and need to dress our hammers. The smart guys here have mild steel hammers to use on punches, chisels and the hardy so the forging hammers and tools don't get beaten up.
When you grid the blade, use a cup stone on a disk grinder and to it at red heat or you'll spend bunches on grinding disks.
