Finally got started on a hammer
A friend gave me an old axle. I shaved a sliver off it and hardened it. I think the metal will do fine.
I decided to make a small straight peen for starters. Its the only simple one I dont have yet.
Im not sure the order of steps in forging a head (shape, punch, drift, etc.) so I just went ahead and started on the peen side first.
Then upset the head end and work it a little. Today Im going to fuller (I think this is the right term) just behind the head to define it from the body.
I found I should have tapered peen a little because it made a taco shape in the end. Ill have to cut it off when finishing.
The peen took about an hour to hammer. This is tough stuff.
Constructive critisism welcome :)
post-52250-0-52388400-1395844254_thumb.j
post-52250-0-58140400-1395844270_thumb.j
post-52250-0-43205600-1395844286_thumb.j
post-52250-0-71440700-1395844302_thumb.j
post-52250-0-57362300-1395844318_thumb.j
post-52250-0-56276700-1395844333_thumb.j
I was hoping I wouldnt hear that. Thanks.
I was worried I would punch hole then get the peen crooked.
Punching the hole is the place where you most likely can go wrong and have to discard the workpiece; as such doing it first means you don't have to throw away your time spent working the peen.  Pre drilling the *annealed* piece to guide the slitter through can help you get it right.
Im not too good at finding center with a punch yet.
I am going to put it in the mill and pre drill it.
BTW...was fuller the right word/term?
If you use a fuller to do it then fullering is the correct term...
My favorite straight peen has the peen about the diameter of a 1" rod; I'm *happy* to hear that you plan to trim some off that sharp peen!
I do have sharper peens to texture with but sharp is not good for moving the metal as in drawing down a piece on the horn of the anvil using the peen on the top.
Hey, how'd you steal my first pair of tongs?!!! That pattern on the side of them looks familiar......  :D
to find center first using a flatter and (hopefully) striker flatten opposing sides of the blank. This only needs to be a little flat line down the length 1/4" is more than enough. Now you have well registered faces so you can use a pair of dividers to find center. making flat sides really helps keep everything in place when you slit or punch and drift.
Oh yeah, slit/punch and drift first.
Thanks for that tip for finding center Frosty.  I'll have to try and burn that into my brain and not forget something else.
Got it. Ill definatly make the hole first on the next one. The flat is a good idea.
Put it in the mill and centered it and the phone rang. Everyone always needs something when Im busy. Will have to wait till tomorow now.
They are my first pair of bolt tongs. Definatly not made for that size. good ole rebar. I have a few rebar pairs now. Made a pair the other day to hold 5/16 round to make leaf keychains. Seem to be a hit with everyone around here.
Got a 3/8 hole punched through today. Definatly harder to do than I thought. I hope to drift it tomorow.
I had to clean up an old hammer to help. Ive had it for years and never used it. Put a handle in it and smoothed some old scars.
post-52250-0-71036900-1396057895_thumb.j
post-52250-0-35497700-1396057909_thumb.j
post-52250-0-80272000-1396057923_thumb.j
post-52250-0-02549700-1396057938_thumb.j
  • 3 weeks later...
Finally got back to the hammer.
Drifted the hole.
As predicted it a little off. The center of the eye dosent match centers from the peen and head. Guess I have to do a little grinding. Im sure I can find a use for a little hammer.
Already have another peice cut and waiting on the eye punched out.
You might be able to draw the thick side down to match the thin side by heating the thick side more by strategicly placing it to the side of your fire then put your mandrel in place and forge the thick side while supporting the thin side on a flat. You will likely need to work to get everything straight again after you draw down the thick side, and your eye will be larger than before. A fuller is the term you wanted earlier.
Good Morning,
The trick Tom Clark showed me was to drill 3 - 1/4" holes about 1/4" between them, then punch the hole with a slitting chisel. The Handle hole is ALWAYS on center.
If you have the hole punched slightly off center, heat the whole hammer head and quickly quench the skinny side cheek, quickly continue to punch your hole, the hole will move sideways.
I teach hammer making in my Course, it is quite entertaining to watch the unbelievers see the handle hole move sideways. Just Magic.
Neil
  • 2 weeks later...
Thanks for the tip. I got the hole straightened out as good as I can. I think it will work out.
I need to take some more pics before I get it too far. I keep forgetting.
I got sidetracked and made a little double bit hatchet for camping. Ill start a new thread for that one. It was a lot of fun to make.
Back to the hammer now. Ill post pics soon.
if the eye hole ain't quite right, don't ya just use it in the opposite hand ??........just askin'....
I just use my cock-eyed hammer with a little more *side-english*  :ph34r:
