Just bought this Peter Wright Anvil. What is the weight in lbs?
 How do you figure out the weight in lbs of this English anvil?
post-11874-0-06280200-1385429950_thumb.j
post-11874-0-51412600-1385429956_thumb.j
If The numbers I read are 0  3  16 .Your anvil weight's 100 lbs.
First number = cwt or long hundredweights, or 112 lbs. 0, 1, 2, 3, 4 or more(!!) possible
Second number = quarter hundredweights, or 28 lbs. 0, 1, 2, or 3 only
Third number = pounds, 0 to 27.
So, 3 x 28 = 84, + 16 = 100.
From the charming folk who used pence, farthings and quid for money. The cwt is 8 stone.
That's the right weight according to the English 100 weight. But they're not always marked right. May want to weigh it and check it. It'll probably be close.
Easiest thing to do is to put it on the bathroom scale.
If the scale is close to right, you get a close to right weight for the anvil.
It sure looks heavier than 100 lbs.  Before I read the other posts, I was thinking 150 to 200 lbs.  Looks are deceiving.
  • 5 years later...
I'm having a hard time understanding how to figure this out. I know this thread is old but I'm trying to determine the weight of a peter wright. It's numbers are 0, 2, 25. So am I right thinking that should be 81#?
Note that the common bathroom scale will weigh those sized anvils and be at least as accurate as the stamped weight is. (Stamped weight tends to be slightly off when weighed on a modern calibrated scale---like is used to sell feed---in the USA there will be a sticker on it stating it is legal for trade use.)
I don't own the anvil, someone posted it on craigslist without stating the weight, but it had the imprints.
  • 3 years later...
Hi,
   Was just given my father’s Peter Wright Anvil.
Stamped: Peter Wright
                Patent
                England
                Solid Rought
 numbers are: 1,2,7
Any info on this would be greatly appreciated.
thanks in advance.
Cheers,
Guy.
As John McPherson said in a post back in 2013 (above in this thread....) use this formula:
