Another what's this question
Seen hanging on the wall outside an old Cornish smithy, and the person who sent me the picture would like to know what it is,
Suggestions so far,
Ear ring for one of the Cornish giants, maybe Cormelian,
Piskie tether if you catch one
Counterweight off hand powered bellows to balance air pressure and make the bellows easier to pump.
Or maybe you know the real use?
Others possibilities invited.
BMP file replaced with JPG
post-2529-0-63758000-1383518652_thumb.jp
Greetings John,
Here comes my 2c worth..  I think it is a weight for tossing a rope into the crotch of a tree so that you can secure it for cutting..  A simple loop makes it so it won't get stuck and fall to the ground with the rope..  That's what I got...
Jim
kinda looks like it might just be a counterweight. maybe for a self closing door, or a curtain lift of something. something that the speed needs to be easily adjustable based on the job at hand. weight pulls the door closed, but when it's hot, you just pull the weight off the ring and it stays open. Want it to close faster or stay closed on a windy day? add more weight.
I think this is probably the best option so far, I also was thinking along those lines, as well as the bellows counterbalance,
the size of the crook on top would indicate it neeeding to have easy access to wherever it fits,
Thanks for all the responses so far
A hook for retrieving buckets accidentally dropped down a well?
1. Throw hook down well
2. With a rope, lower smallest person you can catch down into well to grab the hook.
3. Hope the bucket catches on the hook while you pull small person back up
4. Repeat until successful
