October 2, 201312 yr I cold twist 3/8" Square Hot Roll stock 10 feet at a time. This gives an even twist the whole length. Cold roll doens't twist evenly. The tool is a large Tap holder.
October 2, 201312 yr with my larger twisting wrench I once twisted a RR spike cold---not annealed or forged either. I've found that I can buy cold twisted stock cheaper than I can make it. In fact I am usually found untwisting twisted scrap that I've gotten for free to make tent stakes from---usually leave one twist in it to help with holding in the ground.
October 2, 201312 yr I agree Thomas , I have a ton of R & R spikes that I have been hammering out for tent stakes with a twist and making them longer with a hook type head folks round here love them . Sam
October 2, 201312 yr Sam, I've tried carving heads on some of my RR spike tent stakes; originally for the practice and now for the fun when folks notice. With my old fullering powerhammer making a long tentstake from a spike took me 2 heats
October 3, 201312 yr RR spike heads make natural snake heads. Ought to be good for a double take sending someone to pull your stakes. Hmmmm? Frosty The Lucky.
October 3, 201312 yr Greetings Zbear, I have twisted many many square bars in the past... I my old shop I was able to twist 3/4 square bar 15 foot cold with my eagle roller with adaptors.. I made a slick twisting machine from 2in 3/8 wall square tube with a torque multiplier from a truck lug bolt system.. 16 to 1 ratio... I used a ring roller style wheel to drive it and square sockets for the drive connector.. I could add up to 20 ft of extension .. The holding end was a modified pipe vise... Cold roll square stock will twist even but you must have a consistent and even drive.. The metal will get warm.. Ever wonder why the metal does not change length when twisting... Next time you twist heat a small section with the torch and reverse twist... All twist are at the weakest link or the hottest it will not change the original twist or unwind it... Have fun Forge on and make beautiful things Jim
April 29, 201412 yr I use a chevy 1 ton tranny with a granny first, and power it with a Rigid 300 pipe threader. I have twisted 2, 3/4"square, and two 5/8" square together to make a sort of cable10' at a time, as i usually dont need more.
April 29, 201412 yr I use a chevy 1 ton tranny with a granny first, and power it with a Rigid 300 pipe threader. I have twisted 2, 3/4"square, and two 5/8" square together to make a sort of cable10' at a time, as i usually dont need more. I would love to see your set up, that sounds fantastically Frankenstein.
