patrick72 Posted July 27, 2013 Share Posted July 27, 2013 I have a short piece of track that was given to me and am setting it up vertically to use as an anvil. My question is would it be a good idea to heat treat it so that it is hardened first or will it work harden over time? Thanks for your input. Quote Link to comment Share on other sites More sharing options...
Donnie Posted July 27, 2013 Share Posted July 27, 2013 Use it as is. If the hammer only strikes hot metal, I don't see anvil hardness as much of an issue.............opinions vary Quote Link to comment Share on other sites More sharing options...
K. Bryan Morgan Posted July 27, 2013 Share Posted July 27, 2013 Get a copy of "The Complete Modern Blacksmith" by Alexander Weygers. I got my copy at Barnes & Noble. There is an entire chapter dedicated to railroad anvils. Besides that, there is a huge amount of information in this book that every blacksmith should know. Its a must have in any blacksmithing library. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted July 27, 2013 Share Posted July 27, 2013 Good Morning, If you wear it out, another chunk isn't too far away. I think that a life-time wouldn't be long enough to wear it out. You may want some different configurations, that is acceptable. just my $0.02 :) :) Neil Quote Link to comment Share on other sites More sharing options...
njanvilman Posted July 27, 2013 Share Posted July 27, 2013 When rail is made, the top running surface is flame hardened. The rest is left soft so it can flex as the weight passes over. The side and bottom areas would not be hardened. However, the type of steel in rails is designed to work harden. The more you use it, the harder it will get. Quote Link to comment Share on other sites More sharing options...
Pete Buchanan Posted July 27, 2013 Share Posted July 27, 2013 k morgan is soooooooo right, if you dont own that book .you should. honestly any smith should have a copy of it......... Quote Link to comment Share on other sites More sharing options...
Dan C Posted July 27, 2013 Share Posted July 27, 2013 The piece I have mounted vertically I just used as is. If I ever need to I could grind away some til flat again but don't need to after a yrs use. Quote Link to comment Share on other sites More sharing options...
philip in china Posted July 30, 2013 Share Posted July 30, 2013 I use quite a bit of RR line and have never needed to harden it for any purpose- except as a demo on differential hardening. Quote Link to comment Share on other sites More sharing options...
SReynolds Posted July 31, 2013 Share Posted July 31, 2013 I knew that name sounded familiar...I had to run-off and see if I own that book. Yep! Too bad though, as I don't use it. It is really indepth and detailed. If I learned everthing in there, I wouldn't be very good at much else. I'd hate to be the guy who wrote that book. He had something to be real proud of; accomplished blacksmith. But just think of all other other things he missed out on in life attempting to be the expert at something............... I guess I look at things differently...I dunno. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 31, 2013 Share Posted July 31, 2013 SReynolds; I fear you are QUITE mistaken about Weygers: From wikipedia: Alexander Weygers was a polymath Dutch-American artist who is best known as a sculptor, painter, print maker, blacksmith, carpenter, United States Marine, philosopher, Aerospace engineer and author. (His wikipedia entry is worth a read: (a few excerpts)) : Weygers was born in Mojokerto, Dutch East Indies He graduated from Hanze University of Applied Sciences, Groningen in mechanical engineering and from a Dordrecht vocational university in shipbuilding. He also briefly attended the Royal Academy of Art, The Hague In 1941 he entered the U.S. Army and his command of Malay, Dutch, Italian, German, and English led to his assignment to the intelligence operations He received a patent from the U.S. Patent Office for his discopter in 1944 and his design has served as the prototype for other similar disk and hovering aircraft that have been developed up to the present day. "Alexander Weygers as a modern Leonardo da Vinci..." and continued, "...He commands attention because he is a success by any standard of excellence in half a dozen professions... a sculptor of heroic dimensions, an inventor, a marine, mechanical, and aeronautic engineer, an artist with a camera, a designer and illustrator, and a virtuoso practitioner of endgrain half-tone wood engraving. He is also blacksmith, machinist, carpenter, electrician, plumber, toolmaker, and beekeeper. He is further a teacher and a reluctant prophet upon whom the admiring descend." Before 1940 his work was included in the collection of the Smithsonian Institution in Washington, D.C. and was recognized as an artist of national significance. ------------------------ What horrors if *you* should live so limited a life! Quote Link to comment Share on other sites More sharing options...
