Justin Keller Posted April 17, 2013 Share Posted April 17, 2013 A while ago I was given an old 6" mechanics vise that was pretty beat up. One of the things wrong with it is that the jaw inserts are missing. I'm planning on making my own, but I'm not sure what type of steel to use. Any suggestions for something that will do the job and isn't really difficult to work with? Also does anyone know what material the original jaws would have been or what the ideal material would be, in case I decide to get a machine shop to make me a set? Thanks, Justin Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted April 17, 2013 Share Posted April 17, 2013 I would go with W1 tool steel because it should be long wearing in this application, its easy to get and you can quench it in water. Second choice would be O1. Quote Link to comment Share on other sites More sharing options...
knots Posted April 17, 2013 Share Posted April 17, 2013 A while ago I was given an old 6" mechanics vise that was pretty beat up. One of the things wrong with it is that the jaw inserts are missing. I'm planning on making my own, but I'm not sure what type of steel to use. Any suggestions for something that will do the job and isn't really difficult to work with? Also does anyone know what material the original jaws would have been or what the ideal material would be, in case I decide to get a machine shop to make me a set? Thanks, Justin What tools do you have ? If you have a drill press this should be an easy task. Commercial jaws have cross hatch texture machined into them. IMO that is not a desirable feature for most of the work that blacksmiths do so I I either make overlay jaw covers form sheet metal, or replace them with mild steel inserts. If you have a suitable size steel bar handy it is an easy job to cut,countersink and and drill the inserts . I find that mild steel works well for me. Mild steel would not likely be acceptable for a machine shop but for the kind of work we do should be OK. If it is a modern, name brand, vice you may be able to order a set. Quote Link to comment Share on other sites More sharing options...
windancer Posted April 17, 2013 Share Posted April 17, 2013 Yup- lust plain old mild steel. Just 'cuz there are lots of specific use steels out there doesn't mean they have to be used. Dave Quote Link to comment Share on other sites More sharing options...
Stephen Olivo Posted April 17, 2013 Share Posted April 17, 2013 lol brass would be my choice or copper depending on what its going to be used on. Make several interchangeable ones for different uses. You don't want to mar a nice piece just to hold it. Many of the ones I have seen have brass pieces instead of the steel ones. Those hash marks have a tendency to mar stuff if your not careful. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 18, 2013 Share Posted April 18, 2013 Yup depends on how you plan to use it whether hard jaws or soft jaws, smooth or checkered are best. I have a post vise with very aggressively checkered jaws that spends it's life with angle iron jaw covers on it. Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted April 18, 2013 Share Posted April 18, 2013 Just remember hardened steel jaws protect the vise from damage and keep the jaws from deforming so they grip evenly. Brass copper or aluminum jaw covers are there to protect the work. This is best practice biased on 100's of years of collective metal working experience. Dismiss this at your own risk. Quote Link to comment Share on other sites More sharing options...
Bob S Posted April 18, 2013 Share Posted April 18, 2013 mild steel is plenty good or whatever you have laying around. Make a few sets while your at it. Drill a few holes for heading rivets or holding special jobs. No need for hardened jaws in my opinion. A picture of the vise would be good. google image search for 'vise jaw inserts' Quote Link to comment Share on other sites More sharing options...
Robert Yates Posted April 18, 2013 Share Posted April 18, 2013 http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Vise+Jaw&op=search&Ntt=Vise+Jaw&N=0&GlobalSearch=true&sst=subset&cm_mmc=PPC:%20MSN%20Main%204-_-Hand%20Tools%3EVises-_-Bench%20Vises%3EVise%20Jaw%3EBroad-_-Vise%20Jaw&ef_id=UW-xMgAAAL@uKF73:20130418174933:s http://wiltonviseparts.com/shop/wilton-jaw-inserts/ Here are two site that should help you out . Sam Quote Link to comment Share on other sites More sharing options...
VaughnT Posted April 19, 2013 Share Posted April 19, 2013 Depending on what you are doing with the vise, I'd certainly consider a set of micarta inserts and a set of brass inserts. Both would have magnets inset into them so I didn't have to use screws. Of course, this is only for finer work, like knifemaking, where I didn't have to torque down on it. Quote Link to comment Share on other sites More sharing options...
Justin Keller Posted April 23, 2013 Author Share Posted April 23, 2013 Thanks for the suggestions guys, I've decided to make my own out of some mild steel that I have handy. I don't need anything too special right now, and the price is right. I'll post some pictures once I have them made. Quote Link to comment Share on other sites More sharing options...
caintuckrifle Posted February 23, 2014 Share Posted February 23, 2014 What kind of curvature or radius should inserts of this type have? or do you just leave them square? Quote Link to comment Share on other sites More sharing options...
njanvilman Posted February 23, 2014 Share Posted February 23, 2014 What kind of curvature or radius should inserts of this type have? or do you just leave them square? Leave them square, unless you have a particular application in mind that radiused jaws would work better. Quote Link to comment Share on other sites More sharing options...
