September 29, 201015 yr Nice job as usual If I made one it would probally need to be a little taller Mike Tanner
September 29, 201015 yr Good Morning all Very elegant as usual 3B. I see you revisited the Habermann bend. Are you getting ready for Valentines Day? -grant
September 30, 201015 yr Good Morning all Very elegant as usual 3B. I see you revisited the Habermann bend. Are you getting ready for Valentines Day? -grant Thanks Grant, but Lyle did most of the work on the stand. I do use that bend as much as possible. It is one of the greatest things I learned from Alfred Habermann. Valentines Day? I'm on my way to New York right now to demonstrate with Lyle, LDW, for the Northeastern Blacksmiths Association. http://ashokancenter.org/
September 30, 201015 yr What did you use for the patina on the vise when you finished it? Thanks! I took it apart and wire wheeled it and then wiped it with oil cold. I started a fire under the stand and finished it with vegetable oil hot.
September 30, 201015 yr For those of us who don't know what a Habermann Bend looks like could you share a clearer photo of the spring ... please.
September 30, 201015 yr For those of us who don't know what a Habermann Bend looks like could you share a clearer photo of the spring ... please. Tim -check out this thread -grant
September 30, 201015 yr Cool project. I have a 4 inch vise that already has the leg missing so I wont feel like I am hackin on good tools. Thank Brian and Lyle. Tell Karen hello and enjoy NY. Should be pretty and decent weather this time of year.
October 25, 201015 yr Hi All, I just wanted to thank Lyle and Brian for this great vice idea. I had a vice I have been wondering what to do with. These is what I came up with I did not have to buy any materials all was from my pile. This has been a great learning project thanks to Lyle and Brian I have made a very useful vice alot of great ideas.Here is some pictures. Gaylan Veater
October 25, 201015 yr Author You definitely had a plan before you got started. That is great. It is a fine looking vise, and larger than the one we built. Brian has pointed out its at a great height for rasping wooden handles. That cut away on one side of the jaw, and not cut away on the other is so useful. And recessing the slot so your stand has a better center of gravity with the vise is a big help too. Id give you a 10. Good going, its a pleasure to see someone think so far ahead. You even put a finish on the whole thing. That is pride, and well admired.
January 7, 201214 yr I just found this on the bay. It looks a little rusty and can't see much of the screw. You don't have to cut off the leg and the price may be right.
January 7, 201214 yr He has a real shipping charge on it, I expect it will have some bids and not go for the opening bid. Looks like a good vise even without the leg. The exposed screw looks really good, but who knows what the rest of the screw looks like. Probably worth the chance, but you might do better locally instead of shipping it out of CA (unless you can local pickup) Phil
