using normal wood
Should I tell people that I forge with coke instead of coal, because I'm converting it to coke as I go along?
maybe just tell folks you forge using combustable long chain carbon molecules ?
I pertty much explain the process to visitors concerning coal to coke aka breeze vs other solid fuels available.
Never tried wood. I used to buy hardwood blocks, about 4" x 1"x1" for fire starters  and never thought  to try them in the forge as fuel source.  I may have to look for any leftover stash and try it.
  • 1 month later...
When I use my Whitlock forge I make sure I have a pile of wood ready.  I have a hairdryer hooked up to mine and it burns like no tomorrow.  It gets my metal glowing red.  I built a coal forge but it was to deep and not wide so it ruined my tips (glowing bright yellow with air burning around it)  If you have free wood its the cheapest way to go.  Takes a little longer, but for a hobby knife maker its fun.
Were you putting your tips down in the fire instead of horizontally up in the reducing zone?
  • 2 years later...
On 1/4/2010 at 1:39 AM, reefera4m said:
One note, during this process you can create a lot of smoke, a whole lot depending on the type of wood. The same as converting coal to coke.
Is there a way to make charcoal without large quantities of smoke? It seems like a necessary by-product, logically, but I have illogical optimism.
I'm in a suburb with a 50 ft yard (thank God) and I'd like to keep the good relationships I have with my neighbors. A wood forge or charcoal-making setup would be ideal as far as fuel supply goes, but it sounds bad for smoke. Even with great ventilation the smoke will still end up in my neighbourhood.
Thoughts?
Edit: this place really gets you thinking. I could, if smoke was a problem, go up to a relative's land 30 minutes from here and charcoal burn once a quarter. Make some kilns, perhaps!
Would a regular fire be too much smoke? You can always build a fire and scoop hot coals from the fire to the forge. If that's too smoky you'd probably be better off going to your secondary location to make charcoal in large batches. I don't know how much smoke comes from a large indirect retort that recirculates the combustion gases to help heat the wood. When I make small batches using a small barrel in a larger barrel it's pretty smoky for about an hour or so until all the steam stops and thick white smoke stops coming out and I seal it up. There's still a little smoke from the fire that is in the larger barrel but not anywhere near the amount that comes out of the smaller barrel that holds the wood to be pyrolized in the beginning.  I think if you have somewhere you can go to make large batches that would be what I would do. Good luck and post some pics of the process if you decide to make a large kiln or retort. I think folks would be interested.
Pnut
Edited by pnut
Wood fires get uncomfortably hot when trying to forge in the coals formed at the bottom and tending the fire to maintain a coal bed to transfer coal to the forge ads a complication. If you google charcoal making, particularly the guys making willow charcoal for black powder you will find some exelent kids.
  • 1 month later...
I think it really boils down to design. I use wood 98% of the time and I love it. I had a friend come out and we used my forge and he kept commenting how nice it was to not have to use tongs on everything cause there was so little radiant heat. He has a couple propane forges. His main one is an Alec Steele design. He says his forge puts out 10x the radiant heat. He also burnt up a knife we were working on cause he wasn't use to how fast it heats stock up... Now, I have been working hard to design an efficient wood fired forge though as I am a sawyer and clean waste wood its plentiful for me. I feel like it has paid off. Here are some really bad sketches of my setup. The length of my air pipe is adjustable kind of like the Whitlox. Note, I “coke” the wood you could say, then rake it up onto the fire.
