September 27, 200916 yr How about suggestions for soup cans. I use them for holding chisels and beeswax. I use the lids for the candle holders and catching drips. I know there have to be many more uses for these miracles of engineering! :D
September 27, 200916 yr I use coffee cans with plastic lids to keep odors down when I am degreasing and soaking parts. It really does help, even though the lid becomes soft after a while. I also use cans for keeping track of nuts and bolts for reassembly as I take apart. Works much better than the rain channel or something. I prefer those magnetic pans, but only have one. Phil
September 27, 200916 yr Targets. My Dad made some flowers out of the lids. You torch the ends to form sort of a 4 bladed propeller , stack 2 offset to each other. braze a stem on, and fold the petals up some. There are tons of tin can crafts, from lanterns to camp stoves.
September 27, 200916 yr I like to buy soup in them. I always keep a few around the shop for whatever I need one for. I've considered making a little rack maybe a lazy susan, to hold several, maybe 6 or 9, tipped back at an angle for handy working tool storage. Think of a wine rack with cans holding chisels, chasing tools or whatever. I plan on making a similar rack to hold the square kitty litter buckets for power tool storage. Keep them in sight, handy, cords untangled, and out from under foot. On wheels of course. I'll also cut them up if I happen to need a piece of steel that size. Mostly though, crush and haul to the dump. Frosty
September 28, 200916 yr I use soup, coffee, juice, etc cans to store stuff in like the rest of you guys. But the one use that is very useful, is to use them as molten aluminum molds. If you have leftover aluminum after pour. It makes real good turning material, because it's already round. One idea I haven't tried yet, but will soon is to prop a piece shafting vertically inside the can then pour around it. That way you have the shafting cast to aluminum disk. This could be used to build a belt grinder drive shaft and wheel. The coffee cans will make 6" diameter wheels. Depending on how deep you pour the aluminum as to how wide the wheels will be. Just and idea. Larry
September 28, 200916 yr I used to punch holes in the bottom and mount them on a handle to wet the fire to control the size and temperature. Before I had a shop with a head I used to pee in an empty can then thow it out the door when no one was looking and then pray for rain. I always hated it when guys would pee in the slack tub so empty soup cans were handy, hence the expression going to the "can".
September 28, 200916 yr Author :) I used a pee can for 3 years because those 2 am trips to the outhouse were terrible, especially in -10 weather.
September 29, 200916 yr what you guys forgot about useing a soup can to fix your rusted out tail pipe
September 29, 200916 yr I use a powdered beverage can with air tight metal lid to soak items in expensive volatile solvents. eg xxxxxx old sharpening stones loaded with oil and grit in thinners; come out almost new. AndrewOC
October 29, 200916 yr I put water in them to quench small parts in. I also used two soup cans painted black as part of the intake for my 93 RX7. Attached K&N filters to them. Worked pretty good. Russell
October 29, 200916 yr coffee cans make great mold forms for casting - just cut out the bottom and pour in your investment - voila!, ready for the kiln . . .
October 29, 200916 yr Yeah, cans are good for one offs for casting flasks, but not more than one burn out and pour.
October 29, 200916 yr Old tuna cans made great flasks for sand casting using a hose clamp to hold them together and the seam line to line them up. Lots of stuff doesn't need a large flask! For chisel cooling I made a little holder that holds a can and clips to the turn up on my forge table---piece goes into the forge and chisel goes into the can. Note for high alloy tools an empty can works too.
November 22, 200916 yr Fasten the soup cans close to where your belt grinder is and just loop the unused or used belts if you save them over the can. You can sort by size, grit, etc.. this way.
November 22, 200916 yr My "dipper" or "sprinker" for the forge is made from an old soup can. Most use out of something I got for 50 cents...EVER!
July 17, 201016 yr i cut em up for mozzi coil holders, the quench thing, tool holder, circular bolted leg clamps on the old forge, shims for the blower mount on the forge, edge liners and stiffening in leather work, charcoal and coke powder dipping, reflector type candle holders, a replacement circular valve on top of the head of a air compressor, billy tins and cooking, cockroach traps, gasket for a fuel pump on the landrover, patterns for small parts, bigger ones for charcoal cookers, money boxes for small change, ashtrays...yada yada. amazing how a pair of scissors or tin snips can transform the humble tin.
October 7, 201015 yr I'm rough on stuff. Soup cans are too flimsy for me but I cut open the little disposable propane bottles that go with the hardware store torches. The bottom halve makes a very nice "can"
October 10, 201015 yr If our economies get much worse we can always hold they out to passers-by saying "any change sir?" Ian
