bluerooster
567 -
Everything posted by bluerooster
Liquid fuel burner
bluerooster replied to Andrew Golabek's topic in Induction Heating, Oil forges, etc
Alcohol (methanol, ethanol etc.) has a very high octane rating. Thus slowing the burn, and making a colder flame than gasoline. (white gas is simply unleaded premium gas) You must burn almost twice as much alcohol to get the same heat value as gas, for the same amount of air. So, for an alcohol burner you must use a much larger jet. -
bluerooster replied to Mark Ling's topic in Blacksmithing, General Discussion
Worked on the vise project some more. Got the screw and spring temporarily installed. It works pretty smooth. -
I'll probably just weld it on, and cut to length. Yes it probably should have been at less of an angle. And I may change that. but I'll give it a go and see what happens. I didn't think about that at all. But a good point which will need to be addressed. The hinge plates are welded with 6011 rod, then topped with 7014. Finally got to work on it some more today, got the screw assembled, and installed temporarily, made the spring, (actually cut from a Model A spring leaf). all that's left to do is some tweaking, screw protection, fabricate the mounting plate and spring holder-on'r, and install the post. Oh, and fabricate a handle from an old lug wrench. It actually works pretty smooth.
Hey, if it works, right? I got the jaws assembled, and need to add the post. Screw, and nut are ordered. should be here in a few days. 4" jaws. I've ordered a 3/4" acme thread lead screw, with 1/4" travel per turn. Not as fast as I would like, but should work fine. Oh, and mounting hardware yet to be made.
Cool gator. can't wait to see it with a fire in its mouth. Got both jaws for the vise done. (well, forged anyway) Now on to the easy part. cleaning it all up, and making the rest of it, and putting it all together. -
Carbide Burr on Stainless
bluerooster replied to edennis's topic in Blacksmithing, General Discussion
one more thing is the coarseness of the teeth on the burr. Too coarse will chatter when turned too slowly. Too fine will go away quickly when turned too fast. I have some very coarse HSS burrs, for removing lots of material quickly when cutting aluminum, and mild steel. They like to be turned very fast, and fed slowly. The finer carbide burrs seem to like a slower speed than the coarse ones, and can be fed a bit quicker. But with coolant, you can spin them at a pretty good clip, really cut some metal. -
Swinging a striking hammer, rail road swing
bluerooster replied to Glenn's topic in Blacksmithing, General Discussion
And using proper tools and technique, there will be less energy required of you to do the job. -
Friend brought a car by today for some paintwork. Well, it needed bodywork as well. Had some sheetmetal work, and structural work to be done, prior to the paintwork. Glad I priced it accordingly, and had most of what I need on hand. Anyway, no forge time till Monday, when I plan to finish up the other jaw of the vise project. -
I guess I'd better put this in the vise topic and quit taking up space in the "what did you do in the shop" topic. It all started off with a need for a suitable post vise. I'd been looking and what I've found is a Vise that needs to be melted down for scrap will run about $300 because it's rusty. So, I decided to build one. I figure that if a man could build one 100 years ago, I can build one today. I have a chunk of square stock that I decided to start with. It has been a learning experience to say the very least. I have one jaw well on it's way. and #2 is catching up quickly. But requires many heats, and many upsets, and many flattenings, to get the jaw widened enough. I'd started with my hand crank blower, but decided that I needed the rest between heats, so I dug out the hair dryer. Anyway, I started this ambitious project knowing full well I could probably buy one quicker. But, The education I will get is priceless. Got the first jaw ready for the screw hole, Only took about 8 hours at the forge. Now, how to make the screw hole. I could drill it, but parent stock is only 1 3/16" and I have 1" lead screw. So , I decided to slit and drift. Guess what, I have no tools to do that. But, I have an anvil, a forge, and stock to make a slitter, and drift. I guess that's what it's all about. If you need it, and don't have it, make it. Iron in the fire: Upset, and flatten:
Das, the parts were beveled at about 35 degrees or better. And about half the thickness of the metal. Then welded, with 6013, and topped off with 7014. It's been holding strong for 2 years now. I've welded a few loader tracks, that 40 years later have yet to fail. (but they did wear out and get replaced but the weld is still there) As to what I did in the shop today, I started the second jaw for my post vise project. Spent the day heating, upsetting, flattening, ad nauseam. I still have an inch of width to go, but it got hot, And I needed a break. Moving big iron, even nearly white hot,(actually high yellow) is tiring, especially with a hand crank blower. But what I'm most surprized at is the amount of coal used to do the job. So far, one jaw complete, and one well on it's way, and about 10-15 pounds used. And a pile of coke to die for left over. (means very little smoke at start of next session :D ) -
Are they worth getting?
bluerooster replied to Dillion Brian Grant's topic in Blacksmithing, General Discussion
brand new picks can be had for ~$40, complete with handle installed. Wrenches of that size also not what the asking price is. But, It's at least 20 years old. :rolleyes: I've got a box full of Craftsman tools that are getting close to 100 years old. I found that the lifetime warrenty isn't worth the paper it's printed on. Had a broken socket, guy at the Sears store told me it wasn't a Craftsman tool. When it was plainly marked "Craftsman", with a part number. But it didn't look like the new tools. I've also got a few Snap-on tools that will probably be declined should they ever break, due to their appearance. (probably worth more as functioning antiques) But, I have the catalog they came from, and the receipt. :D -
Ringo said "i've got an 'ole in me pocket." My anvil is a chunk of steel, 4"x8"x12". I came into a need of a hardy hole, so I added one to it. I welded a chunk of 2"x4"x4" to it, after I'd cut a 7/8" square slot in it. \ and what it looks like today -
Score!! SWMBO was cleaning out under the kitchen sink. I got a full box of borax, 2 gallons of old peanut oil, (for quenchant), smells like fried turkey when hot steel is quenched. a packet of mouse bait, and a full container of sevin dust. Rest went in the bin.
I don't know what you call it; "windmill, railroad swing", or what ever. But for driving stakes I prefer that circular motion. The weight of the hammer does most of the work, all I'm there for is to guide it. -
My anvil is embedded in the stump. That holds it in place quite well, and I can easily move it, or reposition it, on it's side, or end. It's held in place by it's own weight.
Chimaera: Can you add a hardy hole to your existing anvil? As to cutoff wheels, I've found that the harder the material, the longer they last. I can cut 52100 with one 3" disc all day, but for mild steel of same dimension, I go through many discs for the same amount of cutting. Agreed, don't force it, just let the big dog eat, and you will have a nice cut, and disc will last longer. -
All this remodel/renovation talk has me worn out. I've been doing a renovation on a large barn for the past 7 weeks. And looks like we have a week to go. But the owners have a house that needs the floor shored up in the crawl space. On tap for Tuesday morning. :eek: (I hate crawl spaces) Anyway, spent the weekend finishing the straight run of privacy fence for the swimmin' pond. And built/installed the gate using the hinges, and thumb latch that I'd made from various pieces of scrap. Today I had more stuff to do, and errands to run, so I didn't get much forge time. But I did get the screw hole slit, and drifted on the vise jaw. That's about it for forging anything. -
Finally, today I built the gate for the hinges and thumb latch I made a couple months ago. Got it installed, and works just fine. -
made some headway on the vise project. Got the jaw formed, and ready for poking a screw hole in it. By the time I had a slitter, and drift made of proper size, it was late in the day, the iron was cold, so i decided that I'd best get to getting ready for work tomorrow. As I work away from home 4 days a week, it takes some getting ready. I have to make sure everything around the house is good to go without me, then I have to get all my stuff together for work, gas up the car, etc. So hole punching will wait 'till next week. -
Rule of thumb; "If it doesn't rust, a torch won't cut it". -
Fabricating a post vise from scratch is indeed an undertaking not for the feint of heart. I figure that the education that I get from this project will be a valuable resource to draw on at a later date. For the upsetting, I have an anvil on the floor, and an 8# hammer. I upset to a little over the thickness of the parent stock, then flatten two sides back to original thickness, and go again. The most difficult part so far has been waiting on it to get hot the first time. I don't let it go black before re-heat. As to jack screws, The jacks we use for gear swings etc. are hydraulic. But Acme threaded rod is pretty cheap, and there is a variety of nuts to use with. New jaw plates can be had pretty reasonable as well. If all goes well, I should have that half well on it's way, and hole slit, and drifted to size by end of next session. A fine start, and I like your well organized scrap bin. Looks just like mine.
