bluerooster
565 -
Everything posted by bluerooster
Solid bar is heavy, and if not large enough will sag under it's own weight. Tubing is lighter, and for same OD, and span, and will sag less. 4130 thin wall tubing of about an inch, or inch and a half should do the job nicely, and won't weigh much at all. Then you can fire up the forge, and make finials, and hangars for it.
more to do with wood, but a friend carves ducks, (decoys) "It's easy. just cut away anything that doesn't look like a duck".
bluerooster replied to Mark Ling's topic in Blacksmithing, General Discussion
Haven't done much at the forge lately. Been knee deep in head gaskets on an ML320. Ended up with a "day off" from it today, so I broke down the forge, and installed the new firepot. Now I need to make up a sturdier stand for my "new" (old) Champion blower. I have a plan for that. And may do it tomorrow. JD, for a first ever hook, that's a nice one. I like the twist too. Now get to work makin' more, that anvil ain't shiny enough. -
Making a keychain with rusty old nails!
bluerooster replied to TechnicusJoe's topic in Blacksmithing, General Discussion
I liked that video. I'll have to give it a go. -
Stopped at the flea market today to get a pic of the Buffalo 2E but the guy wasn't there. But all is not lost, and picked up a Champion that works, from another guy. And for cheeper.
Thanks for the info. The motor on the unit in question is way different from the motor in the thread posted. Puts me in mind of a GE washing machine motor.
55 gallon drum makes a fine hood, another mabe 30 gallon for a flue pipe. and yer good to go. You can mount the 55 to the hearth, and cut an opening to acess the forge. Here's what I have, and it works well to draw the smoke up and out.
I like that welding table. I want one now. Sure beats my old wood table by far. -
Was at the flea market last week and came accross a blower. A Buffalo 2E. The impeller and housing appeared intact, motor is seized and no speed control. Guy wants $100 U.S. Is it worth it? Pretty much just the impeller, housing, and motor mount. No stand. I didn't think about getting a picture. But will tomorrow.
welding spring steel to mild steel
bluerooster replied to Laughing Dog Forge's topic in Blacksmithing, General Discussion
GMAW is just fine if done properly. But as you mentioned, it's too easy to make a pretty bead that doesn't hold. -
Thomas, you're right, the chrome did present a problem. But I did manage to get it to stick together except one end that simply refused. I figured I'd sacrifice that end, It's to be a pocket knife anyway. I drew it out and folded it, got that welded, and that's when the wheels fell off. As I was drawing for the second time, I noticed cracking throughout the billet. I don't know how deep the cracking went, but the chunk of steel is pretty much worthless now, so I decided to play with it for a minute. I drew out to about 3/8x3/8, and put a twist in it. That showed me all the flaws. Everywhere there was a crack, it opened right up. I dropped it into the "bucket of shame", put the fire out, and went to the house. And so goes it in the life of a beginning smith. -
Gone swimming in the slack tub
bluerooster replied to aaamax's topic in Blacksmithing, General Discussion
Sounds like you feed your cats too much. -
What about cooling tongs, and punches, and watering the coking coal? -
JHCC; I did. And the chrome may present an issue. But the contrast should be awesome. I've had good success welding it to it's self in the past. But this will be the first time trying welding to a 10xx. I'll try almost anything, once. -
Wearing sneakers, I was gas welding a rear body panel in a Mustang. Moved the torch to hammer the weld, and saw a flash out of the corner of my eye. I had directed the torch at my shoe, and set it ablaze. With both hands full, (one with hammer, and one with torch) I was forced to stomp it out with my other foot. That was 1985, I have not worn sneakers since. Ever. All my clothing is 100% cotton, and boots are leather. No more plastic clothes for me. As to welding, and grinding. I've had hot stuff jump into my shirt, down my pants, in my ear. Welding overhead while laying on your back, can teach you all kinds of new dance moves.
I have a can of brazing/welding, good for brass and steel commercial flux. But thought about making some anhydrous borax. I have plenty of borax, and a pot to melt it in. But I'm open to suggestion. Nice work Alexandr. :D -
Spent a couple hours at the forge today. Thought about trying my hand at pattern weld. I don't know if this will work, but I'll give it a go anyway. I have a chunk of 52100 (bearing race), and a bar of mud flap hanger, (presumably 1060-1080). I figure I'll attempt to mate the two into a billet and see what happens. Pic 1 is the 52100 that I started with. Second is the flap hanger ready to form a billet with attached handle, and the 52100 drawn down and squared up. Third is the billet cleaned, stacked, and wired together, ready for welding. Tomorrow, I'll clean out the forge, and see if I can bang 'em together. Had another chunk of bearing race that decided it wanted to become a hawk bill blade. I've gotten it to the point where I'll grind from there. It will be a small blade compared to the size of stock. So I can save a piece for something else. -
Put my hand crank leaf blower, blower project on hold, and fired up the forge. Made the second half of tongs, got it punched and fitted to the first half. I still need to draw out the rein on the one, and weld rein to the other. I made it short. (didn't allow enough stock) Oh BTW, Great work, all of yall. Mabe when I'm 83 I'll be able to do that. -
Wanted to work at the forge this weekend. But power went out Thurs. at 5am, and has been off until today about noon. No power, no blower. I did set about the task of fabricating a hand crank blower from an old leaf blower. I got it well underway. Just lack a reduction gear, for the crank. -
As mentioned before, I would probably clay up to the cut out, then scoop out a depression at the grate. You can mound the fire, to get it as deep as needed. And can easily rake the fuel into, or out of, the fire.
How much do you pay for coal?
bluerooster replied to P. Bedard's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
It's $30 for a 50 pound bag at the farrier supply. Only place local to get any. But at least it's sometimes clean and not too much clinker. -
Texas charcoal making
bluerooster replied to wirerabbit's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
I was going to ask about Mesquite. It's a weed where I come from, and must be eradicated at all cost. It burns hot in the stove, as fire wood, and will dull a new chainsaw in a cut or two. It is quite dense, so I suppose it must be turned into charcoal slowly, and in small chunks. -
Nothing better to do today. made a couple punches, and a watering can.
