Everything posted by Buzzkill
My knife needs a handle
You probably already know this, but I wouldn't recommend ever putting a knife with that type of construction and handle material in a dishwasher. As long as you don't use anything known to be toxic it shouldn't be a problem on the handle. Once dried/stablilized there shouldn't be much of a chance of transferring anything dangerous to the food. Another thing to keep in mind for your slabs for scales: Straight perfect grain is boring. I did this with some walnut on my property for one of my early knives. It looks decent, but because there is no variation in the grain, or knots, or anything else eye-catching it's just kinda "blah." If that's what you're after then don't let me dissuade you. If you want something with a little character then maybe find a spot with a knot or small branch. If it's honey locust you might even be able to find a spot with an ingrown thorn.
Handheld induction heater to forge?
For use as a small forge, the short answer is no. Those are nowhere near powerful enough to hit forging temperatures in anything approaching a reasonable amount of time. We have one in the shop, and they work reasonably well for their intended use if you can get the coils where you need them. However, if you use too big of a coil on a smaller nut that is enough to decrease how well/quickly it heats up. If I have some spare time maybe I'll run out and see if/how long it would take to get something up to forging temperature, but I'm not sure it's even possible. The handle portion of those does have a fan in it for cooling off the electronics, but I believe there is a duty cycle recommendation. As quoted above, they also have thermal shutdown protection features.
Freezing Propane Tanks. A Different Solution
I use a 2 tank hookup kit from Mr. Heater (F273737). To that I added a propane regulator to control the pressure of the supply line to my burner. I've used that setup for several years now with no major complaints.
Vevor 2 Burner Gas Forge tubes glowing and fire in the choke holes after couple hours usage
I have never used that forge or those burners, but what I can tell you for sure is that you had flames burning in the mixing tube. You do not want that. The flames should always be at the forge end of the mixing tube and never inside the tube itself. Because your burners are top mounted there will always be heat rising up through the mixing tube when you shut down the burners. However, in use the mixing tubes should be roughly ambient temperature and certainly cool enough to touch without concern about being burned. If you want us to help diagnose your issues take some still shots from the side right after you light your burners. It's best to do that in moderate to low light rather than sunlight so we can see the flame characteristics. That will tell us a lot. You can also take another picture or two a few minutes later when the forge starts to glow, but the initial flame in a cold forge is the place to start.
Edge bar splitting
Maybe nothing. If you haven't already, you should watch the video that JHCC linked to above. The first time I saw this phenomenon I thought it was delamination at the weld seams, but closer inspection revealed the hard core split down the middle and the welds held. The only quasi-remedy I've found is to use a thicker core and thinner cladding if you want to use a non-hardenable material on the outside. Unfortunately that means you have less material you can grind away and still get the effect you are after, so you have to forge pretty darn close to final shape if you go that route. In the video he suggests that applying clay on and near the spine for the quench may decrease or eliminate the phenomenon as well. I haven't personally attempted that approach, but it's certainly worth a try.
Reasonably priced Induction Forge for Hobbyist to purchase?
Do a search for "15KW induction forge" using your favorite search engine. That should bring up a number of options for you to start exploring.
Forge heat treat baffle design
In another thread you were specifically talking about heat treating stainless. If you are using a good stainless alloy for knife blades you may need to bring the steel in the 1900 to 2050 degrees F range before quenching. You also may need to hold it at a high temperature for an extended period of time depending on the specific alloy. A muffle with a little bit of charcoal in it is not likely to prevent decarb in that scenario. A lot of people who heat treat stainless alloys use a stainless foil pouch with as much air pressed out as possible and a small amount of something flammable to consume the remaining oxygen in order to protect the stock from decarb. I'm not sure it's a problem to have the spine touch the muffle floor though. In order to try to get even heat I can understand why you wouldn't want a blade leaning against a wall of the muffle, but there are fairly easy ways to accomplish that. I've used small pieces of insulating fire brick in which I cut slots to hold blades where I wanted them. As Frosty suggested, you can also use kiln furniture, and I believe there are some knife making websites that actually sell pre-made items to hold blades while heating for quench or during tempering cycles.
PID controlled forge/heat treat furnace setup
The appropriate lining thickness depends on a few things. If it's a small forge where you are dealing with odd-shaped pieces, and/or you are a little clumsy, then you need a lining that can take a little abuse - which translates into a little extra thickness. Generally speaking, it's a good idea to have the floor a little thicker than the walls due to the constant abrasion of stock being moved in and out. The thicker your lining is, the longer it will take to bring the forge chamber up to temperature - which translates into extra fuel cost. The upside is that if you do long forge sessions with a thicker lining it will act a little bit like a "heat battery" in the sense that once hot it will retain and radiate heat back into the forge more than a thin lining. So, ultimately how you plan to use your forge determines what is best for you. If you are dealing with mostly straight pieces where you are unlikely to gouge the walls, then thinner is probably better. This is especially true if you will usually be doing relatively short duration forging/heating sessions. Personally I do not see any real advantage to going 3/4" thick. For the floor that's not outrageous, but even there it's a little on the high side in my opinion.
Oatey high heat (2500 degree) furnace cement bubbling
Congrats on a successful pour! Sounds like you are well on your way to a long-lasting addiction. There is definitely a sense of accomplishment and satisfaction that you can get from working with your hands to create something you like that you just can't usually get by sitting at a desk. If you have the time and ability to post a picture (or a few) of your build and your casting I'd love to see it as well.
Fuel consumption
I don't run 2 burners, so I don't have a direct comparison. However, when using a single burner with a 3/4" mixing tube I get 10+ hours from a BBQ size propane tank for general forging. My forge is a little smaller than yours though. When forge welding that time drops significantly. Generally speaking, a .023 mig tip would be appropriate for a 1/2" mixing tube. For a 3/4" mixing tube I'd be running .030 or .035, depending on a few different factors. All that to say you're probably in the ballpark for a 2 burner setup in my opinion. If someone else who is running about the same size forge with 2 burners chimes in you should definitely give their opinion more weight.
Various Questions With My Gas Build
It also looks like someone used a lathe to cut out the threads, but then left an abrupt lip on the air intake. If the burner has the performance you're looking for it's probably not a big deal, but "features" like that can cause extra turbulence which may negatively impact the functionality of the burner and/or the air to fuel ratio at different pressures.
If your build is based on the video you linked to you should end up with a well-built forge. The only issue I had is the consistency of the castable refractory. To me it seemed there was too much water, and that could make for a weaker lining. Whenever I've used Kastolite 30, it is not able to be poured like that when mixed the way I understand is correct. However, it's a small item and we aren't applying a lot of structural force to the lining, so it will probably be ok. I've never used any type of glue to hold the blanket to the shell either, so I have no idea if there's any real benefit. Other than that, it appears to be a well thought out, designed, and constructed forge. I like the removable floor and the sliding stock support - although that ideally would have a handle of some kind to help slide it in and out. Those tend to get hotter than is comfortable to grab with a bare hand while the forge is in use. When you say "heat treating stainless steels" what exactly do you mean? If you are referring to ramping up and reaching prescribed quench temperatures it could/should work well for that. If you want to be able to temper as well you will probably find it difficult or impossible to maintain temperatures in the 200 to 400 degrees C range with the same forge/burner combination you used for achieving quench temperature. You may be able to run a significantly smaller burner and use the same forge body, but for me electric is the way to go for tempering. Other than that I'll just mention that most of us started out with a forge larger than needed because of the mindset of "better to have it and not need it than to need it and not have it." However, for many of us, that forge sits gathering dust or has been tossed out. Now when I think about rebuilding/modifying my forge it's always along the line of trying to figure out the shape with the lowest volume that will still allow me to do what I want to do. If you are going to be making stainless blades 15 inches long you may need that extra length, but it does come at the cost of significant extra fuel consumption. What you are suggesting isn't crazy big. It's just a bit bigger than would be recommended for forging. When you throw in the heat treating aspect you have to decide whether it's worth the cost to have the extra length or to stand there and pump the blade back and forth through the forge to get an even heat before quenching.
It's kind of tough for us to answer the question of how to mount the burner without being able to see much of how/where your latest forge is placed. Without trying to sound too sarcastic, you *do* have a forge. If you have some flat steel you can always heat it up and bend it into the shape you want to hold your burners where you want. If you've progressed enough to punch a couple holes and set a couple rivets it shouldn't be horribly challenging for you. There are many ways to hold them in place without welding. One easy solution is to use hose clamps to fasten the burners to whatever you built to support them. Some people have used conduit clamps. Baling wire would even work. Your imagination is the limiting factor. All you have to accomplish is reliably holding them in position.
Question about controlling spatter
Thanks for all the replies. I have some of the gel stuff, but it can get a little messy sometimes (or I can get messy with it). A dry spray coating seems like a better option to me. I do far more stick welding than MIG, so I don't have much experience in that area.
I have a question for some of you experienced welders out there. I was told that hairspray does a good job at keeping MIG splatter from sticking in the nozzle or to stock. Obviously you'd have to wait for it to dry, but I was curious if anyone else had ever heard this or if I need to get the other leg pulled to even them out.
Doctor's Orders
Yep, the best people are leaving, retiring, or dying off. A few years ago when I had tendonitis I was with my wife for an appointment and she mentioned my tennis elbow. Without missing a beat the doctor asked if I wanted a shot for it. It was not my appointment, nor was I even officially a patient of his, but I had a problem and he had a treatment. I'm guessing he may have gotten some blowback if the bean counters knew he had done that, but he made an immediate impression on me and I knew after that I would see him for anything from the shoulder to the fingertips (his specialty). Sadly, he passed away a few years ago. The other doctors in the same practice are good, but they are not him. I don't think a single one of them would treat a person before knowing they could bill the treatment. He did it without hesitation.
Burner Tuning Question
The easiest solution may be just a hole in the center of your bolt head to allow a small amount of fuel air mixture through.
Love the flame shape. That looks awesome! I haven't fired up my forge much in the past few months, but now I'm gonna have to resist going into tinker mode when I get back out there.
Permenant magnet chuck for tacking and grinding
I'm fairly sure that if I tried to use the one I got on a surface grinder the stock would slowly drift on the chuck while in contact with the grinding wheel. I can slide the piece of angle stock I mentioned before along the length of the chuck with a little effort. I'll be contacting the manufacturer, but if I have to pay much for shipping to send it back to them there's a good chance I'll take it apart instead.
Sounds like it's either a bad design or a quality control issue. I'm tempted to take it apart and see if there's any way to adjust the magnets that move inside. It could be that the moving part is off by a quarter inch or something similar. Sorry, I don't know the terms for the different parts of that tool. I can feel some pull about 1/8" of a turn from the off position, and the hex key does rotate pretty much a full 180 degrees from the "off" to the "on" position.
I recently purchased a relatively cheap Chinese magnetic chuck. It's 6" x18" and weighs nearly 50 pounds. In the "off" position there is no attraction to magnetic steel at all- as would be expected. In the "on" position I can fairly easily remove a piece of angle iron that is about 6 inches long, 1/8" thick with 2" sides. That doesn't seem right to me. I figured I would be able to lift the entire chuck into the air by pulling on the piece of steel with the chuck in the "on" position. However, I have no prior experience with these, so I don't know if I have unrealistic expectations or a substandard chuck. Any thoughts from those of you who have experience with these?
Tips for Damascus?
Same as drawing out any other piece of stock. Make sure it's plenty hot. Use a radius edge of your anvil with half on/half off hammer blows. Alternatively use the horn of your anvil instead of an edge of the table. You're just trying to maximize the force on the minimal amount of surface area - and have that force directed so it lengthens rather than widens your stock. The only real difference with damascus billets is the potential for failure at the welding surfaces. However, if you did a good job setting your welds and you keep your steel hot it should be pretty much the same as mono-steel.
Perlite and kastolite
This confuses me. For both the rigidized fiber blanket and the refractories I've used, they actually turn completely white when they are properly fired. With use the forge interior will take on some darker colors from the steel and impurities, but not as a consequence of proper firing sequence in my experience. You're switching gears here. It's best to pick a design that is known to work and stick with the routine developed by people who have successfully used the design. I don't know if you're talking about insulating fire brick or hard fire brick. They are completely different animals as far as their use in a forge goes. When did vermiculite enter the conversation? If you keep bouncing around with all these ideas you'll probably end up confusing yourself and spending far more money than you will if you zero in on something and stick with it. The forge pictured by Frosty is a proven excellent little forge which is very reasonable to build, uses no blanket, and does not require any welding or special tools. If you want to go the brick route it's a good choice.
I suspect this is the source of your problems. You stated you have a propane tank size forge. There is no circumstance I can think of that would require quarts of rigidizer. Normally we suggest people add food coloring to the rigidizer so you can see how far it has penetrated into the blanket. It does not need to be drenched and dripping. If I understand you correctly, the blanket layer pulls away from the Kastolite and leaves a gap between the two, which is what concerns you. However, if you follow the steps listed on here and you are applying the materials correctly this should not happen. Install a layer of blanket. Apply rigidizer. Completely dry that layer of blanket with direct flame. Install the second layer of blanket. Apply rigidizer. Completely dry that layer. Now spritz the surface of that blanket with water before you apply the Kastolite directly to it. Enclose the whole thing in a plastic bag or tub with some water and or/wet towels for a few days. Let it air dry for a day or two. If you have an incandescent bulb drop cord with a 40 or 60 watt bulb you can put that inside for a day or so to help drive off excess moisture. Then you need to finish off by running flames in the chamber briefly at first. If you see steam escaping stop immediately. Gradually you should be able to fire the burners longer and longer until you are able to get up to a glowing forge interior. I don't apply plistex/matrikote, etc. until after I have been able to fully fire the Kastolite, but I don't know what other people do. You're assuming the insulation is the problem - and you may be correct. It's also possible that your burner(s) is not up to the task or that you have wide open ends on your forge or that you are not running high enough pressure to bring your burners to their full potential. The only times I have used perlite in a build have been under a layer of insulating blanket. I wanted a flat floor in a cylinder shaped forge, so perlite let me easily transition from the curvature of the shell to flat, but I still used the blanket over the top of it, and then Kastolite on top of that. If your forge and burner are functioning properly, I'm fairly sure that a thin layer of Kastolite will not insulate well enough to avoid melting perlite directly behind it. If they are mixed together you will just end up with a weak porous layer. Kastolite already contains little spheres designed to help with its insulating properties. You don't need to add anything to it. The dangers of ceramic wool fiber are real, but they can be eliminated for all practical purposes by using the correct techniques. There is another option which reportedly does not have the biopersistence and respiratory consequences of kaowool. It is called Superwool. I have used it and have noticed no significant difference in functionality compared to kaowool, but I still rigidize it and seal it with Kastolite even though the manufacturer claims it does not have the harmful effects of other blankets.
File jig
I built something similar years ago. I agree with Latticino. You'll probably want something with a little more accuracy on the eye end. I used a rod end bearing for the eye portion and of course the appropriate size round stock to slide through it. There's pretty much zero play that way and your file strokes stay very stable. For small to medium blades this can work well. For large blades you can run into the limits that the eye will allow you to swivel. It looks like you're set up about right so that the file will be centered on the cutting portion of the blade rather than the center of the blank. That is the right way to do it. The next crucial thing is to ensure that the blade remains supported and stable while you're working on it - and that when you flip it everything is complementary to the first side. There are a couple good options depending on the handle style being used. For full tang knives one of the easiest ways to hold the blank down is to run a screw through one of your pin holes. Two is better. You also want a stop at the spine so you can ensure the same precise bevel angle when you flip the blank. This can be a screw, a nail. a board backstop, etc. as long as it doesn't interfere with the file while in use. You should mark the center of your work area on the board so that you can make sure your beveled area is centered when you flip it. You can just put a small mark on the center point of the spine that lines up with that and then when you flip it line the marks up again. As Latticino said, you may need to support the tip or you can get a bit of a spring action if you bear down on the file, and that can throw off the edge geometry near the tip.
