Shop Mottos
  • Replies 80
Case of Beer: $15.
Ton of Coal: $25.
Truck bed full of Stock: $50.
Having the day off and pretending the steel is your boss: PRICELESS!!! :)
I do like this one though:
"I have found that I always learn more from my mistakes than from my successes. If you aren't making some mistakes, you aren't taking enough chances." -John Sculley
  • 4 weeks later...
  • 1 month later...
As in my signature I have a sign hanging inside my shop over the door that reads: "The early bird gets the worm, but the second mouse gets the cheese". Interpret it as you will.
Other greats:
The road to success is crowded, the extra mile is lonely.
Anything in life worth having-is worth working for. -Andrew Carnegie.
Logic will take you from A to B, imagination will take you everywhere.-Einstien
May you be in Heaven a half hour before the devil even knows your there-Irish Toast.
Eagles may soar, but weasels don't get sucked into jet engines.
If you need credit to buy a beer, you don't need a beer-you need a job.;)
Two other quotes I like to use are:
Quality is like oats
If you want good oats
You must pay a fair price!
If you don't mind oats that have already been through the horse
Well, that comes a little cheaper!
And the second, which really doesn't have to do with Blacksmithing in particular:
You can't make yourself look bigger,
By making another man look smaller,
Because the lower you knock a man down,
The lower you have to be to hit him!
When I worked as a diesel fitter in the mines there were a couple of classics: "Cut your way in, weld your way out"; and "Never put put your finger where you wouldn't put your ol' fella first"!:o
Cheers
So, are you saying, "don't pick your nose?" :rolleyes:
Frosty
