melonkernel Posted September 11, 2008 Share Posted September 11, 2008 Hi, i am from Finland, and here you won't find a hamburger patty press in a (at least local) store. So i would need to make one i guess. (So i can feed my newly purchased Weber Grill [which by the way is lovely]) I can get stainless steel pipes. Has anyone here made one? I am thinking of something like the attached photo. (If i want to buy whole-meat patties here, they are around 1 Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 11, 2008 Author Share Posted September 11, 2008 oops, i posted this in the wrong "general discussion". The admins may move this thread as they see fit. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 11, 2008 Share Posted September 11, 2008 I don't know anyone in America who uses one. We always shaped the hamburgers with our hands. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted September 11, 2008 Share Posted September 11, 2008 A tortilla press would work but they probably don't have those in Finland either... Quote Link to comment Share on other sites More sharing options...
the_sandy_creek_forge Posted September 12, 2008 Share Posted September 12, 2008 We had two in the restaurant where I worked through high-school and college. One was a hinged ordeal that was more hassle than it was worth, not to mention getting it apart to clean it! (healthcode and whatnot...) The other was basically two discs that fit inside a tube (made of some kind of plastic) Set down the tube, put the bottom disc in, put in burger, and smoosh it flat with the top disc. The top disc had a handle on it, so once the patty was made, you held the handle, lifted the tube up while keeping the discs in place and voila! hamburger patty. But, unless you're running a restaurant, I wouldn't worry about perfect patties. Just make a 1 pound ball of burger, squish it a bit and throw it on the grill. -Aaron @ the SCF (who's fully aware that a 1 pound burger is precisely 4 times as fattening as a 1/4 pound burger....but it's Oh so Good!) Quote Link to comment Share on other sites More sharing options...
azmike Posted September 12, 2008 Share Posted September 12, 2008 how about a stainless steel ring about 4 " diameter x 3/4"--use your hands to form (can also be used to fry eggs in for a egg sandwich) Quote Link to comment Share on other sites More sharing options...
triw Posted September 12, 2008 Share Posted September 12, 2008 When I worked in kitchtens we used mayonaise jar lids (gal. size) wax paper on the bottom and top and press the lid ovet to form the patty very quick and very cheap. Quote Link to comment Share on other sites More sharing options...
orgtwister Posted September 12, 2008 Share Posted September 12, 2008 i got my hamburger press as a gift from harbor freight they have two types ones 2.00 and others 10.00 they have a web site i don't know if its worth geting them from there personaly i don't use it i do the same as thomas roll it in a ball squish it. you could just use a piece of stainless pipe or tube or pvc pipe of the size you want about 2 inches or so high and make a center press for it it may be hard for you cut stainless for that fit i would get (if you have them there)a plastic cutting board and make the center out of that. and get a stainless pull knob and put in the center Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 12, 2008 Share Posted September 12, 2008 Use two saucers (small plates) and form the hamburger patty between them. Waxed paper keeps the hamburger from sticking. Clean up us just washing the two saucers. Quote Link to comment Share on other sites More sharing options...
rthibeau Posted September 12, 2008 Share Posted September 12, 2008 apparently you want to do this for your own use..this is good. Canned goods, vegetables, beans, whatever........find one the size you want your burgers, find a second just slightly smaller that will fit inside the first very close. Do not open the second one. Open both ends of the first, clean it out, put the amount of burger you want in the first (open) can and place on flat surface. Put second (unopened) can inside first, push down to form round patty......repeat. Clean cans for reuse later or keep supply on hand. Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 12, 2008 Author Share Posted September 12, 2008 Hey, thanks, i got a great deal of good advice fro you all. I intend taking on the quest of making the ultimate pattie ;) Quote Link to comment Share on other sites More sharing options...
Finnr Posted September 12, 2008 Share Posted September 12, 2008 I remember seeing burger presses turned from maple as a kid. Which is rather a while ago but I think it would still be workable. Finnr Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 12, 2008 Author Share Posted September 12, 2008 I could saw a large hole in a thick massive (hard) wood board. Then we have a hole, and a plug. those could then be shaped and polished to become a nice hamburger press. (hmm, an alternative not involving hammers and fire ... ) Perhaps something like this: Quote Link to comment Share on other sites More sharing options...
ironrosefarms Posted September 12, 2008 Share Posted September 12, 2008 At the restaurant I worked when in high school we rolled the meat out with a rolling pin on top of waxed paper then cut the patties with either a knife (square patties) or a large soup can for round. Worked very well and we could put out a bunch of patties in a short time frame. Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 12, 2008 Author Share Posted September 12, 2008 I think i will go with that approach. And now for the actual patties. ... What do you prefer to put in them? Here, a lot of people put breadcrumbs and egg to make them stay together, but recepies for hamburger patties do not include them. (Hamburgers: The Patty - The secret to the perfect burger) But other than onion and spices, do you put other stuff in them, or is it "all about the meat"? Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 12, 2008 Author Share Posted September 12, 2008 Or, i will try the different approaches you all suggested and stick with the most convenient one, that makes the best patties, which includes as little mashing up the meat as possible while still giving it the perfect shape and making them store-it-in-the-freezer-able. Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 12, 2008 Share Posted September 12, 2008 VG0071 All American Burger IForgeIron.com > Vulcans Grill has over 70 foods listed and how to make them. Vulcans Grill is open to anyone that wants to post their way to prepare a food or dish. Blacksmiths do have to eat you know. (grin) Quote Link to comment Share on other sites More sharing options...
Justin Caradoc Posted September 12, 2008 Share Posted September 12, 2008 I like to put A-1, minced garlic, and a pinch of cyane pepper in my burgers. I only use a tea spoon of the A-1 per pound when it is cooked the flaver gets stronger. Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 13, 2008 Author Share Posted September 13, 2008 I tried yesterday to make some patties using the top cut off a plastic container and a jar as the press. it worked fine and i made some nice patties, 100g, 10cm diameter and half a centimeter thick. I placed the circle on silicone topped cooking paper sheets, and put 100g of meat in them an pressed, then stacked them onto each other and put them in the freezer, using the papers as separator. They were however a bit difficult to separate once they were frozen. I probably should press them first on a separate paper, then add put them between separation-papert and onto the freezer. My next plan is ofcourse to grill some of them tonight. But now my project is this: Make a pattie press using stainless-steel pipe and a plastic cutting board as orgtwister suggested, and then make additional stainless-steel-pipe parts 10cm diameter and 2cm "high" to make bun-makers. With 9-12 of these at the same time in the oven one could easily make the perfect buns as well. Quote Link to comment Share on other sites More sharing options...
rustyshackleford Posted September 13, 2008 Share Posted September 13, 2008 I would use the stainless for this project. 1.Find a base about 1/4"=1/2' thick, make it circular with a tab on the back. 2.TIG on a vertical hinge to this tab. 3.Find a similar size stainless tube, cut it about 3" tall, then mark an inch from the top, and cut most of the way through the pipe, leaving a 1" square tab. 4.Opposite of this tab, and at the bottom, weld your other hinge tab, making sure it seats with the other properly. 5.Bend the 1" tab at the front down, finish the hinge at the back, and 6.Find a disk that will fit into your pipe. Attach a knob to this and clean it all up. When using, press the patty, then twist the disc as you lift it, to break any suction. hope it makes sense, ask if it doesn't! Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 13, 2008 Share Posted September 13, 2008 When you finish making the hamburger patties, put a sheet of waxed paper on BOTH sides of the patty, then stack them together. That is paper, patty, paper, paper, patty, paper, paper, patty, etc. When frozen the paper separates easily giving you a paper, patty, paper section that you can place under a stream of warm water to heat and easily separate the paper from the patty. Quote Link to comment Share on other sites More sharing options...
keykeeper Posted September 13, 2008 Share Posted September 13, 2008 I have a hamburger press that is an original tupperware, NEAT LITTLE TOOL!!!!!!!! I'll see if I can get some pictures, let's you make as THICK a burger as you please.Yeah, Tupperware rocks, Sam! On another note, I like to make burgers with these additives, for about 1 pound of ground meat ( any red meat will do!): -one tablespoon or so of Worcestershire Sauce -healthy dose (teaspoon or so) of Garlic powder -some dried minced onion (tablespoon works well) -couple shots Tabasco sauce -dash of black pepper -teaspoon or so Beef bouillon powder or soup base powder measurements are approximate, usually I just fudge the amounts until I think it looks good and will taste good. I very rarely measure when cooking. mix all ingredients thoroughly into the meat, make into about 3 big ole honkin patties, grill until cooked through. MMMM, MMMM, MMMM, I love being a carnivore! Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 14, 2008 Author Share Posted September 14, 2008 Hey, awesome tips, everyone... I grilled the patties i made along with commercial ones i had bought earlier (the expensive whole-meat talked about, that are supposed to be the best around here) They were similar in shape and handling (flippability) but mine were oh-so-much-tastier and the commercial ones were much more rubbery. And my wife agreed aswell. (And the ones i bought, i thought until now were the best patties ever made) thanks again... question: How many of have decided to make hamburgers during this discussion? Quote Link to comment Share on other sites More sharing options...
melonkernel Posted September 14, 2008 Author Share Posted September 14, 2008 I would use the stainless for this project. 1.Find a base about 1/4"=1/2' thick, make it circular with a tab on the back. 2.TIG on a vertical hinge to this tab. 3.Find a similar size stainless tube, cut it about 3" tall, then mark an inch from the top, and cut most of the way through the pipe, leaving a 1" square tab. 4.Opposite of this tab, and at the bottom, weld your other hinge tab, making sure it seats with the other properly. 5.Bend the 1" tab at the front down, finish the hinge at the back, and 6.Find a disk that will fit into your pipe. Attach a knob to this and clean it all up. When using, press the patty, then twist the disc as you lift it, to break any suction. hope it makes sense, ask if it doesn't! I might have to re-read it a couple of times to fully understand. but no i am off from the computer. => family Quote Link to comment Share on other sites More sharing options...
NateDJ Posted September 15, 2008 Share Posted September 15, 2008 The hardwood press looks great, you could forge some really nice hardware for it and make it look very elegant! Set it beside your other grill tools and use it for a drink holder if nothing else.:D Quote Link to comment Share on other sites More sharing options...
