Randy Griffin Posted December 16, 2021 Share Posted December 16, 2021 I found this one today. I don’t have the experience some of you have so a couple of questions. First, what do you think it is? It has the caplet under the base but the markings on the wrong side. 107 lbs and a word by that and a star. No steam hammer marks under the heel but looks like a circle on one side. Rings like a bell on the heel, not as loud at the horn and more of a clunk over the sweet spot. I didn’t have anything to measure the rebound but at least 80% and maybe as much as 90%. What do y’all think? Quote Link to comment Share on other sites More sharing options...
Stash Posted December 16, 2021 Share Posted December 16, 2021 That's a real head scratcher. Looks like it might be cast? I see stamped weight but other markings seem to be proud of the surface. I'm not seeing the star you mention. Definitely a steel face- it's mushroomed, not chipped. It has some similarities to a Samson I saw this past weekend with the blocky feet. Can't explain the pins in the side- probably not factory issue. I'm drawing a real "Huh?" here. Do some wire brushing on it and see what you can find. You certainly can just use- as-is but it is still fun knowing what you're using. Steve Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 16, 2021 Author Share Posted December 16, 2021 The pins are threaded studs with nuts that were welded on at some point. Here’s a better pic with the star. Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 16, 2021 Author Share Posted December 16, 2021 Now I’m thinking Swedish. Frosty where are you? Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted December 16, 2021 Share Posted December 16, 2021 Not sure if it’s it or not, but I just found an anvil brand in AinA called sisco they are made in Sweden and are cast steel, they can have a depressed oval on the bottom or be flat, there’s a picture of one on pg 65 that has a five point star but it looks different, the only thing that makes me wonder is it says they have on handling hole under the heel and that one doesn’t, Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 16, 2021 Author Share Posted December 16, 2021 No. This one doesn’t have any handling holes. I’m thinking cast steel because it has raised markings and stamped. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted December 16, 2021 Share Posted December 16, 2021 Edit, if I had just read the next paragraph over there’s also another Swedish brand called North Star… and it also has a star symbol… I’ll keep poking around and see if I can find any others. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 17, 2021 Share Posted December 17, 2021 Sisco, North Star, Paragon and many others were cast by the Soderfors foundry. Nice score! Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 17, 2021 Author Share Posted December 17, 2021 Actually, I haven’t bought it yet. The guy that’s got it thinks everything is an antique. He will be back next week and I’ll make him an offer. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted December 17, 2021 Share Posted December 17, 2021 You can tell him that an anvil isn't considered an antique unless it is at least 200-250 years old. Up until then they are tools for use. This one is not that old. If you can get it for a few hundred dollars it will be a good score. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 17, 2021 Share Posted December 17, 2021 The Clunk over the sweet spot disturbs me; especially as cast steel anvils are notorious for loud piercing rings. Perhaps the welded on studs make a difference; but I would not pay top dollar for that one. There seems to be some writing near the star any chance of doing the flour trick on it? Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 17, 2021 Author Share Posted December 17, 2021 TP, the writing is made in Sweden. What’s throwing me is the 6 above the weight and the P on the heel. The shape of the foot is between kohlswa and soderfors but can’t find any with similar castings. What does the underside of a soderfors look like? I think the clunk is the studs welded on. It has great rebound in that area of the face. If I buy it I’m not sure if I’ll cut the studs off. Wish I knew what they were used for. Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 17, 2021 Share Posted December 17, 2021 With the threads cleaning up, they could serve as the anchors for some interesting anvil tooling -- hold-downs and such. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 17, 2021 Share Posted December 17, 2021 The question being: did they preheat before welding? Cracking in the HAZ would quiet things down too. (And nothing says "self quench possibility" like an anvil!) Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 17, 2021 Author Share Posted December 17, 2021 You’re right. Didn’t think about that. I wonder how deep I would need to grind to get that crack? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 17, 2021 Share Posted December 17, 2021 Except for dulling the sound I don't think it would cause any trouble in your lifetime. Just another bargaining point. Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted December 17, 2021 Author Share Posted December 17, 2021 37 minutes ago, ThomasPowers said: Just another bargaining point. Yup. Quote Link to comment Share on other sites More sharing options...
