Ryanw Posted November 4, 2021 Author Share Posted November 4, 2021 Funny enough I ran out of propane while warming up the forge. Made it really confusing when I turned up the regulator and the psi started slowly going down instead of up. Great timing on my part. Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 4, 2021 Share Posted November 4, 2021 I had some students over a couple of Sundays ago, and we had just enough gas in the tanks to get the forge close to working heat. I then switched over the tank from the oxypropane torch, which gave us enough forge time to just barely finish the lesson. We make do with what we have! Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 4, 2021 Share Posted November 4, 2021 Gee, Imagine THAT! Join the club Ryan, the craft is full of recurring little mysteries like that. It'll really get to you when you're standing there tapping the gauge wondering why it's going down as you open the regulator . . 20 years from now. Then you get to groan, slap your forehead and promise yourself you'll remember next time. . . Right. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 4, 2021 Share Posted November 4, 2021 This is why an in-line fuel gauge is such a wonderful thing. Not always particularly accurate, but they do give a pretty good indication of when you're close to flaming out. Quote Link to comment Share on other sites More sharing options...
Ryanw Posted November 4, 2021 Author Share Posted November 4, 2021 Its been a fun hobby to get into. First we built a forge but the burner was terrible. So we built a burner but the forge was terrible. So I built a better forge properly. Today I couldnt get the burner to light because I was starting it too high pressure. Then I fix the burner and figure out the best method and boom I run out of propane. Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 4, 2021 Share Posted November 4, 2021 There's a brass plug on the regulator for a gauge. Counting the turns will get you close for the next session. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 4, 2021 Share Posted November 4, 2021 Always helps to have an "extra" BBQ tank on hand as the places that fill the 100# tanks are never open on Sunday! Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 4, 2021 Share Posted November 4, 2021 Wow, Wasilla isn't as far out in the sticks as I thought! I can get my 100lb. filled at two places within about 5 miles but the best prices are closed Sunday. Those are Fisher Fuel and Petrolane, here almost in Wasilla AK. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Ryanw Posted November 4, 2021 Author Share Posted November 4, 2021 An extra bbq tank for me is just buying 2 instead of 1 cause thats what ill be running on for a while with my forge. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 4, 2021 Share Posted November 4, 2021 You may have more folks using propane for their houses than we do. When we moved in there was an electric kitchen range. I finally talked my wife into stop complaining about it and buying a propane range and then finally talked her into buying a NEW propane kitchen range with no pilots. She decided on the upgrade to a large tank and delivered propane on her own. (I got the nearly full 100# tank we had previously used for cooking for use in the shop!) Quote Link to comment Share on other sites More sharing options...
Frosty Posted November 4, 2021 Share Posted November 4, 2021 Propane is everywhere up here, even in the bush. Used propane tanks for next to nothing is the norm for yard, garage, etc. sales. If you take them to be tilled at one of the distributors rather than a gas station they just exchange them. The only time I have to wait to get a tank filled is my 100lb.ers. They exchange them so every full tank leaving their yard has a current certification stamp on it. Propane tanks and filling stations are more common here than snow shoes. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted November 5, 2021 Share Posted November 5, 2021 Your pardon; I had mixed your thread up with another one...old age, tsk, tsk. My burners and all of the other speed burner designs I've played with, differ by size at their bottom and top ranges, but run very similar through most of their turn-down ranges. So, tarting out between 15 and 20 PSI is always a safe bet. Afterward, play around in the low and high ranges beyond it, mostly just for familiarity. The gas orifice sizes in high-speed burners (even high speed linear burners) are dependent on the inside diameter of the mixing tube. I used MIG contact tips for .023" welding wire for 3/4" burner sizes. Nowadays there are tips for .025" welding wire that are more appropriate. What size are your burners? Quote Link to comment Share on other sites More sharing options...
Ryanw Posted November 5, 2021 Author Share Posted November 5, 2021 I have 1, 3/4 burner with I believe a .030 contact tip. Im not entirely sure because I didn't make that section of the burner and the only record I have is a scratch pad with it written on it. Ive only ever ran it 4-8 psi. I just got more propane today so im going to raise it up and see how it changes. Quote Link to comment Share on other sites More sharing options...
